Question about Nokia 6500 Slide Cellular Phone
Incoming calls dont show names which are aleady saved
Incoming calls doesnt show names just "call"
its either because you don't have caller Id
if thats not the case
call your service provider and they will take it from there.
Sep 30, 2011 | Nokia E63 Cell Phone
Incoming call name/number already saved in mobile not displaying in nokia x3.
sir, kindly check whether if that number is saved in any other name also, if a number is saved 2 times in different/same name then the name will not be seen while calling or messaging. check both phone and sim contacts.
sir dont forget to rate my answers.
Dec 29, 2010 | Nokia X3 Cell Phone
In samsung corby sometimes am getting call from unknown number. There is no contact in the name of unknown.Still i am receiving as 'Unknown'
Always happens. If there is no saved contact number there will show the number with 'Unknown' name. If you want to save the number with any name, then you might do that and after that if that number calls, it'll show the saved number.
Sometimes there are some incoming call that indicates only 'Unknown' with no number at all or '0000000000' that means callers have chose to hide ID or that is a VOIP call. Many operator permits to hide ID but not all.
Nov 08, 2010 | Samsung Cell Phones
Dear Sir, I am using Samsung SJ700 mobile phone.And sometimes I get incoming call with no number displayed on the screen. It just shows incoming call. Can you pls help me in sorting out this...
This happens when two or more similar (saving one number with different names) contacts is saved on your phonebook, i.e. if you've saved my number on the sim card with a name and at the same time you have my number (same number) on your phone's memory, the caller id will not be displayed, you'll only see the "Incoming Call" or "Call". So I would suggest you to please check the phonebook and delete (keep only one per number) if there are multiple similar contacts saved on your phonebook.
You can also reset the phone to Factory default, in case there's no problem with your phonebook/contacts.
Good luck.
Thanks for using FixYa.
Aug 14, 2010 | Samsung Cell Phones
Incoming phone number displays but not the name in
Some nokia set has this kind of problem as we dont store the names with '+91' . This problem can be solved if the no is saved with '+91'.
thanks,
saumya.
Aug 04, 2009 | Nokia E63 Cell Phone
Incoming callers names dont show up..
Check and see if your contacts have the country code added to the front of their mobile numbers.
E.g Samoa (00685) mobile number or (+685)
NZVF (0064) 21XXXXXXXX not 021XXXXXXXXXX
Keep me updated with your progress.
Jun 04, 2009 | Cell Phones
Nokia 6650 flip phone will not show contact name on incoming call
Make sure you have the incoming number in your address book. If you don't only the incoming number will show up.
Mar 25, 2009 | Nokia 6650 Cellular Phone
Could not get the calls in my phone
Dear Madhavi
1) Problem in incoming call will be issue of network error, check with the operator service provider or try typing *#3370# for increase network receptionn but it will drain ur mobile charging
2) contact not displaying will be occur due to low memory problem but continue with restarting & keep backup of ur cause it will be helpful incase if they have not retrived by restart
3) You have duplicate entry saved in phone & also in sim card in that case phone dont shows name & shows only no. So please delete & try to keep contact only in sim or phone memory
Hopes above solution will be helpfull
Please revert ur comment or rate above solution
Regards
Pin2
Mar 02, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
Motorola v3i
you would have to saved the contacts on your phone memory then assign ringer id to them and pics as well.
Nov 07, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Nokia 6500 Slide Cellular Phone Logo
35 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
