SOURCE: Dishwasher doesn't stor filling
If the dishwasher's water flow doesn't automatically shut off, the float switch is faulty or the timer is stuck on "Fill" or the water inlet valve is stuck open. To test the float switch, you'll need an inexpensive volt-ohm meter (or multi-tester). 1) Unplug the dishwasher. 2) Reach into the cabinet and lift the dome-shaped plastic float switch. If it doesn't lift, remove the plastic top from the stem, scrub the stem clean, and then replace the dome. If it moves up and down freely, go on to step 3. 3) Note which wires are attached to the float switch's terminals and, using small pieces of tape, label them for later reference. 4) Set the volt-ohm meter's dial to Rx100 and touch the two probes to the terminals. When you lift the float, the tester's needle should show an infinity reading and, when you let the float drop, the needle should show 0. If it doesn't, the switch is broken and will need replacement. Unscrew it from the tub and replace it.
SOURCE: whirlpool dishwasher adp550
f4 is a drain error, machine is still sesing water has not pumped out after 4 minutes of draining
1st check and see if water is still in bottom of machine if so check for blockeges under sink where drain hose cnnects to drain pipe.
if water has drained out you may have an water sensor fault or worst case an electronic control board fault
to reset machine hold the start button in for at least 3 seconds and it should do a drain and stop
SOURCE: G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
SOURCE: My admiral capacity plus washer
I had this happen last year to mine. Check the hose that goes to water level adjustment switch. It may have a hole or crack in it. It may be small and hard to find but if there are any leaks in this hose the switch cannot sense the water level because it works on pressure through the hose to the diaphragm on the switch. You will need to remove the top panel of the washer to access this. I was able to replace the hose with some I had on hand. Saved me big $$$!
SOURCE: My whirlpool dishwasher is flashing 8 times - I
Hello, I have a Whirlpool DWF A10. The machine starts then stops after a short while and the indecator light flashes 7 times. What does this mean? Any body come across this?
