Question about Garden
NEED WIRE DIAGRAM FOR RELAY AND SURROUNDING WIRES FOR 139655000 GDO.
  • spoof4239 Jul 24, 2009
    I have been on e-bay & direct to Chamberlain.
    No good.
  • 336 Answers
Click on below link, this is the expand view diagram. Number 47 is the relay but I don't have the wiring diagram. You could try their service line .. and maybe they have a tech that can help you (1-800-366-7278).
http://www.searspartsdirect.com/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2f00032509-00001.png
Thanks,
Jeep Brainy
Posted on Jul 24, 2009
    President:
  • 1,129 Answers
There may be a service manual on ebay motors, these manuals are on cd and have extensive information, schematics and electrical component locators in the software, give this a try, if you cannot find your manual go to a dealer and they may be able to furnish a copy of the electrical diagram.
Need a wiring diagram for a kluger Please
Go from battery+ to new fuse, to switch, to new relay. Wire relay to provide current to lights when energised.
Jan 21, 2015 | Cars & Trucks
Need headlight wiring diagram for 2013 Kia Rio,want to fit spotlights
you will have to fit a relay into the system. Tap a wire into the high beam power wire for the headlights. (Piggy back connection) take this wire down to the fitted relay to a coil pin on the relay. connect a wire to the other coil pin of the relay and return to the dash area to an control switch through it then to an earth point.. Run a wire to an inline fuse directly from the battery ( fuse close to the battery as it is a high current line) down to one pin of the relay. connect up the power wire for the light to the opposite pin on the relay and connect the earth wire of the light to an earth point
According to road regulations you cannot have spot lights on by them selves and they must only operate in conjunction with high beam operation.. The setup as I describe allows you control of when the spotlights will be on ( switch in the dash) and if on will be extinguished when low beam is selected as per regulations. The relay ensures that the trigger wires do not carry full light amperage so light gauge wires can be used and only the power wire from the battery to the relay to the light need to be heavier gauge.
Sep 11, 2014 | 2013 Kia Rio
What wires are hooked up to left & right posts going to & from starter rely on 1987 f250 4wd straight six
You don't need a diagram. The batt Pos goes to one side and that is also the power side for various other tasks. The second heavy stud goes to the starter. You just have the smaller supply cables on the wrong stud.
Aug 10, 2014 | 1985 Ford LTD Starter Relay
How to use volt meter on 1987 chevy v10 custom deluxe with v6 4.3l engine?
The pump relay has 5 wires or terminals.
You may not be able to see the wires under the fuse box so this may not help much without being there in person.
The green and white wire is power from the computer to activate the relay.
The red wire is a test line to power the pump from the battery.
The orange wire is power for the pump thru the relay.
The black and white is a ground for the relay.
And the gray wire is the line to the pump.
You would use the meter to check for power from the computer when you turn the key on - it should power the relay for 3 seconds.
Then check for power from the key switch on the orange wire with the key switch on.
You should be able to jumper the red wire to a power source and make the pump run.
The relay has a diagram on the side that shows the switch and magnet inside with the terminals numbered.
Feb 08, 2013 | Cars & Trucks
Where is the headlight switch relay
The wiring diagram below shows what you need to end up wiring to make this work, so if you know how to read a wiring diagram and feel like "skipping ahead", just go click on the thumbnail for the wiring diagram and check it out in full size, full color glory. It's shown for a four headlight system - if you have a two headlight system on your car, pretend the two inner "high beam only" headlights aren't there and you'll be fine. The wire colors shown here represent a typical GM vehicle (the green and tan wires, along with some of the black wires) as well as the proper/correct/desired wire colors to use on any new wiring you do (the red and some of the black wires). Also, this is shown as a typical "Bosch style" automotive relay with the connections numbered as such. If your relay is not numbered like this, then just identify the wires by function and go from there.
Note that in the original version of this diagram, I had the labels for the right side headlights reversed - it has since been corrected thanks to a sharp-eyed reader who pointed out the mistake to me. The wiring diagram was always correct, but the headlight labels may have been a tad confusing to some. Apologies for the mistake.
Jan 18, 2012 | Cars & Trucks
Where can I find a wiring diagram for a 1.9TDI Golf as I may need to replace the wires to the starter motor
So why do you need a wiring diagram ,their is only one wire from solonoid on starter to the relay ,which depending on model which you havent stated or year ,some have the relay under the bonnet in the power distribution box and some its under the dash ,easy job to do
Dec 06, 2010 | Volkswagen Golf Cars & Trucks
I need a wire diagram for a 1981 harley davidson superglide for the starter wireing
The wiring is simple for a starter. You have a starter solenoid on the bike and a starter relay. When you press the button to start your bike, the button has a wire that runs to the relay. This triggers the coil in the relay and pulls the contacts in. You have three wires that run to the relay for the starter. One hot wire, a trigger wire from the starter button and a wire from the relay to the solenoid. When you press the button, the relay pulls in and makes the wire going to the solenoid "Hot".
The solenoid has three wires going to it. The large battery cable goes to the "long post" of the solenoid, There's another battery cable going to the starter from the bottom of the solenoid, The wire from the starter relay goes to the small terminal of the solenoid. The small wire from the starter relay is the trigger wire for the starter solenoid. When this wire goes hot, it magnetizes the solenoid and pulls the plunger inward. The plunger bridges two large contacts in the solenoid to put high current voltage to the starter.
If you need a schematic, contact me directly at wd4ity@bellsouth.net. I cannot send a file via this medium but I can direct e-mail. Remind me of what you need when you contact me.
Good Luck
Steve
Aug 08, 2010 | Harley Davidson FXD - FXDI Dyna Super...
Wiring for Bosch Hologen Fog Lights? Wiring harness has 5 wires from relay, Red to battery, 2 Black - 1 to each light?, 1 Yellow to?, 1 Blue to?, & where do the xtra Black and Green wires go to? These...
Look on the relay for the terminal numbers.
Terminal 30 goes to the battery positive.Red Wire
The two terminal 87 go to the fog lights.Black Wires
Match the color wire with what you have on the relay connection for the rest of the wires.
Terminal 86 should connect to your low beam headlight.
Terminal 85 should go to the fog light switch.
The fog light switch should connect to the terminal 85 and the other terminal on the switch will connect to ground.
Dec 21, 2009 | 1987 Nissan Pickup
Need link to 1998 isuzu rodeo relay/fuse diagram
http://www.bulldogsecurity.com/New%20Wires/New%20Wires/Wires/isurodeo96-03.htm
http://images.google.com/images?q=1998+isuzu+rodeo+electrical+diagrams&oe=utf-8&rls=org.mozilla:en-US:official&client=firefox-a&um=1&ie=UTF-8&ei=5h6gSbHpEYKEsAPjwIDHCQ&sa=X&oi=image_result_group&resnum=1&ct=title
HEre are two different links hope they work for you
Feb 21, 2009 | 1998 Isuzu Rodeo
Garden Logo
63 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
