When power button is pressed, all that happens is the "standy" or read light signals on and off continouosly, however the screen does NOT come on while the audio of a distorted screen comes off and on.
Can someone please advise?
It's been having this problem for a week.
Thank you!
This Chassis line had a lot of issues with hair-line cracks in the Horizontal Circuit along the right side near the High Voltage Transformer and Heat Sink. It has also had issues with cold solder connections in the Horizontal Drive Circuit especially the Horizontal Driver Transformer. These issues have many times caused a massive Power Supply and Horizontal failures if not repaired.
I hope this helps,
Skyassoc
Hi, When did you replaced lamp last time in your Sony KDF-42WE655 tv? It sounds lamp got weak, unable to fire up and need to be replaced. Let me know your findings to help you out. Thanks.
when the system is powered on hold the power button down until you hear it beep twice, I am unsure if this is what you were talking about or not but it should reset the system to factory settings
Pull the power cord. Make sure the three-position switch with "REC/Standby/PLAY" is in the middle position, then plug the cord back in. Wait a minute, then press POWER. Now load a disk and wait 1 minute for it to read the Table of Contents (TOC). Either it will show the tracks, or it will say 'empty disk'. Let us know what happens from there, okay?
