Question about Plumbing
The water is not coming out hardly at all and the hot water will not work either so I pull the hoses off and the water is fine coming to the faucet and I pulled part of the faucet apart and now the faucet runs better but still now hot water. What should I do?
    Problem Solver:
  • 8 Answers
The shut off valves may be old and clogged. Place a hose on the valve and turn it on. watch for water and pressure. be sure to place the hose in a bucket to catch water. you will need to
Posted on Jul 24, 2009
  • mark loving Jul 24, 2009
The hot water side has low water pressure. The
start by making sure the valve that supplies hot water to the sink and dish washer is fully open. If there is low hot water pressure in any of the other kitchen/bathrooms, then trace the line to see where the pressure drops. If it is only in the kitchen, it should be an old valve, (causes restriction)Good Luck.
Oct 10, 2009 | Whitehaus Kitchen Single Handle Faucet...
I have very little water press on the hot water side
Dis-assemble the faucet to get to the valve. The handle comes off and you access the valve from the top, usually by removing a screw on ring.
You will robably find contamination in the hot side of the valve.
You can find instructions on the Moen website.
Sep 09, 2009 | Moen 7310 Legend Single-Handle Kitchen...
We have pressure on the cold water side but not on the hot. The faucet in the bathroom sink has hot water pressure.
make sure your water valve is working properly undo line and open valve if its working than take apart faucet and check for debri
Jul 17, 2009 | Moen 7310 Legend Single-Handle Kitchen...
My washer works on any wash cycle that does not use hot water. However, if I choose a hot wash setting, it starts and begins the cycle then stops. The door is locked but the cycle stops running.
Make sure that you are getting water out of the hot side. Close both faucets, and remove the hot side washer hose. Have something at the ready to catch the water. A bucket will do fine. Inspect both ends of the hose. Usually, there is a screen there to catch any sediment. Inspect the hot connection to the solenoid valve at the back of the washer. There's usually a screen there, too. If you note any specks of debris, pull the screen(s) out and clean. Reconnect the hose to the hot faucet. Pointing the open end at the bucket, open the water valve, making sure that you are getting water there.
>> If you are getting plenty of water at the faucet and through the hose, the problem is probably the solenoid valve. Replace, but unplug the washer first.
>> If the water supply is lacking, you have plumbing issues.
Regards, --W/D--
Jul 14, 2009 | Frigidaire ATF6000ES Front Load Washer
New faucet, sprayer hooked up right, no water going into hose?
check the sprayer handle by disconnecting and blowing into it and pressing sprayer handle and/or for possible kink at main body or hose by disconnected sprayer point hose into sink and turn on water. If no water the the diverter in main body is not working properly and needs to be reassembled or replaced
Jul 01, 2009 | Price Pfister Marielle Kitchen Faucet with...
Hot water stopped working Cold is OK
may be the new facuet see if the hose is clogged detach it from the sink turn on the water and see if it comes out into a bucket if it does than its your new facuet
May 12, 2009 | Plumbing
The hot water stops coming out of faucet
if this is the faucet in picture, turn off water, pull out cartridge and inspect for any debris in cartridge or valve body, if not, turn on hot water to see if water is getting through valve body. May have kinked line or debris from or in angle stop line.
Apr 12, 2009 | American Standard Kitchen Faucet 6310 020...
Low pressure and flow on hot water side of single handle faucet
It could be one of two problems, one simple, one serious.
  • Easy fix
  1. Turn off hot water angle stop under sink to faucet.
  2. Remove supply line from hot angle stop.
  3. Place end of supply line in a small bucket to catch some water.
  4. Turn on cold water for a couple of seconds and backflush debris from faucet.
  5. Reconnect supply line.
  6. Turn on angle stop and test
  • Complex fix
If you have steel pipes you may be experiencing reduced flow due to corrosion in your pipes. Reduced hot water pressure in the kitchen faucet is usually the first sign since this is the faucet that is most used in the home.
Repiping is a job for a professional. Another symptom you may need a repipe is orange colored or rusty water.
Nov 14, 2008 | Delta Faucet Plumbing
Plumbing Logo
110 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
