Question about V, Inc. VIZIO RP56 Rear Projection Television
Low volume output on direct tv
When i hooked up my vizio tv to direct tv using hdmi the volume is very low. Is there a fix for this?
2 Suggested Answers
  • 1779 Answers
SOURCE: low volume even when on 100 on a brand new vizio
Try running the cable straight from the wall into the set and see if it's ok. If not, then I would exchange the set.
Posted on Oct 10, 2009
My cable box is hooked up but no signal can u tell me whats wrong
If you hookup your TV directly to the coaxial cable, bypassing the cable-box, do you get a few channels? If so, then the coaxial cable is carrying a signal, which is good.
How are you hooking the output from the cable-box to the input(s) on the TV? Coaxial output port on box to coaxial input port on TV?
Red/blue/green "component" outputs on box to matching inputs on TV? Red/White audio outputs on box to red/white inputs on TV? HMDI output from box to HDMI input on TV?
You have to "tell" the TV which of the inputs:
* coaxial (with TV set to Channel 3 or 4)
* component
* HDMI
to "listen" to.
Oct 24, 2014 | Samsung PN60E6500 60-inch 3D Plasma TV
Hdmi cables input 1,2,3,4 which input goes to the tuner, direct tv box, blue ray on vizio E550i-AO
The choice is entirely arbitrary. You may connect any accessory to any HDMI input. I recommend you connect the device you use most (probably your direct TV box) to HDMI 1, your second most frequently used device to HDMI 2, and so on, but it's really a question of your own preferences.
Mar 18, 2014 | Vizio E550i-A0
My Vizio blu ray won't play through my Pioneer receiver. The picture cycles in and out so I have it hooked up properly but something is not right (could the wi-fi be the culprit?). I had a different...
I'm not sure of your exact setup but I will try to help. The Blu ray player probably has a couple of options as far as output. Two I would have to figure being; HDMI out and a DIgital optical out. I'm assuming you are going into the receiver input then out to tv because you have multiple inputs to tv. If you don't have multiple outputs to tv you could get video straight from blu ray to tv and audio out to reciever then out to tv. HDMI would be your best bet because it handles video and sound. To do this, you would have to have a HDMI in/out on your receiver and a HDMI in on your tv. If you can't do HDMI for audio then there should be a Digital optical output on your Blu ray which could go to your receiver, providing you have the input. If you could provde the model numbers for the units. I could probably be of morre assisiiance.
Mar 10, 2011 | Audio Players & Recorders
I just purchased a Sherwood RD 6513 reciever, I'm trying to connect a hd cable box (motorola dch 3200), dvd player (sony dvp ns710h) and a rca hd tv (l32hd41). I connected hdmi cords from both components...
Hi! I will be more than glad to assist you. I f you are going to hook up your cable box - motorola to the sherwood receiver, connect an hdmi cable to the back of the motorola cable box, there is only 1 hdmi output there, then connect the other end to the sherwood receiver on the hdmi input, then connect another hdmi cable to the hdmi output and the other end goes to your rca hd tv.
for the sony dvp, you have only one hdmi out, connect an hdmi cable to the back of the sony dvp if u have another spare. connect it to the hdmi input of the sherwood receiver. there is only 1 hdmi output at the sherwood, so u need to use a component cable to be connected at the back of the sherwood receiver component output then the other end goes to the component input of the hd tv.
if you dont have anymore hdmi cable to hook up your sony dvp, u can use component cable, the connection will goes like this, connect a component cable on the output of the sony dvp and the other end goes to the sherwood component input then connect another component cable to the component output of the sherwood and the other end goes to the rca hd tv on the component input.
I hope this will solve your concern, if you have any question, u can get in touch..
Aug 21, 2009 | Televison & Video
Vizio SV470XVT will not output Dolby 5.1 from optical out..
TV's only will output 5.1 from HD stations. If you have a DVD player, XBOX 360, etc connected through HDMI, then the TV will only send stereo PCM through the optical out.
Jun 17, 2009 | Vizio SV470XVT 47 in. LCD TV
Connecting samsung home theater to samsung lcd tv and direct tv
Need to get more granular on this, Does the volume work HT remote, for like radio, cd, ipod audio? For you to use the tv audio through the HTB the tv's audio settings should be on the "fixed" output option. This gives a line level to the Amp independant of the tvs volume adhjustment. Otherwise you will need to adjust tvs volume 75% or so before the audio amp will reproduce a good volume. Turn down audio amp prior to making any adjustments. Let me know thx
Nov 23, 2008 | Samsung SCH-a650
Just shuts off
Most likely the unit is detecting an internal problem with it's circuitry or problem with a speaker and is shutting itself off to prevent further damage. You can try disconnecting all the speakers and trying again. If it stays on, then you probably have a bad speaker or shorted wire somewhere. Connect them one at a time to find out which one. If the unit still shuts off, then you've got internal problems that require a professional Mr Fix it.
Hope this helps, and please rate my advice, good OR bad.
Feb 04, 2008 | Harman Kardon AVR 525 Receiver
Hdmi not working
You need to set up the out put of your DVD player. First hook up a non hdmi output to the tv, either component or coax. You don't need to hook up the audio. You should get a picture from this connection. Then you can go into the menu and set your hdmi output to match your tv, probably 1080i. You may have to turn your volume up higher when using the hdmi cable than not. I hooked my audio up directly to a surround sound and don't use the tv's speakers.
Dec 01, 2007 | RCA DRC-285 DVD Player
Televison & Video Logo
681 people viewed this question
Top V, Inc. Televison & Video Experts
Jim Goldsmith
Jim Goldsmith
Are you a V, Inc. Televison and Video Expert? Answer questions, earn points and help others
