Question about Dryers
I have a Kenmore Elite HE4 gas dryer. It works fine, but leaves small streaky marks (looks like grease?) on some of my clothes - usually silkier, light colored clothing. I have searched the inside of the drum to find what could be causing it, but it looks perfectly clean.
  • ekuriloff Jul 24, 2009
    No, no smell and I don't believe the marks are burns (though I'm not sure) as I am able to wash some of the marks out - but not all.
  • jennerina
    jennerina May 11, 2010
    Do you smell any type of burning smell when the dryer is running?
  • 864 Answers
The clothes are getting pinched between the drum and the housing. Check the gasket(s) where the drum turns on the housing at the front and back. If the gasket is worn there is a small gap that clothes can get pulled into. The marks are from the worn metal. Lighter weight clothes are more likely to get caught. The gaskets can be replaced by removing the drum.
Posted on Jul 24, 2009
My kenmore elite he4 dryer is not heating up to dry the clothes
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 10, 2010 | Kenmore Elite HE4 Electric Dryer
Hello I have an 2004 HE4 Nat Gas smartheat quick pack 9 model 9587 / 110.9586. It seems to be leaving brown markings or streaks on the clothes more and more frequently any ideas on how to best deal with...
the felt seal part number 697694 could be worn,if the drum sags down from the felt wearing down it forms a gap and the clothing can even get stuck in gap,some dryers have glides that wear down and some ride on a back bearing,but the problem usually is from a part wearing down and a gap forms from it and it damages the clothing,hope this helps
Nov 06, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite He3 dryer..fine on timed but leaves cloths wet auto
find the metal sensors in the drum
scratchem up with sand paper
especially if you wash rugs, sneakers , or anything with acyrlic
Oct 05, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 gas dryer, no heat at all
The ignitor may be bad or the thermal fuse may be failed.
Aug 27, 2009 | Kenmore Elite HE4 Electric Dryer
Brown marks on clothes from kenmore elite dryer
i used to be sears repairman ask him if there is a recall on your pacfic model .. betcha there is on the dryer drum tell him u want the whole drum replaced on dryer u know exsisting problem having on this pacfic dryer remember satisfaction gaurented or money back...
Jul 12, 2009 | Kenmore Elite HE4 Electric Dryer
Brown marks on my light coloured clothes
I just noticed My Frigidaire doing the same thing. Using a lightly soapy damp cloth, I cleaned the interior, paying particular attention to the small gap between the drum and the housing. I also took apart the lint pre-filter and screen and cleaned them. There was a filmy build up of the same colored substance. I suspect that dryer sheets are leaving a waxy residue that over time is sufficient enough to rub off on lighter colored, primarily synthetic, fabrics.
Jul 11, 2009 | Kenmore Elite HE4 Electric Dryer
Brown marks on the clothes
Yes, the felts are what seals the unit and allows the drum to turn without much heat loss. The felt can become damaged and the clothes will get caught between the drum and the housing leaving these marks.
Apr 09, 2009 | Kenmore Elite HE4 Electric Dryer
My Kenmore Elite gas dryer only heats some of the time
Took the bottom front panel off and cleaned the dust from there and cleaned it out real well. An animal had nuts in the vent from out side. Put new hose on and started it up and is working fine.
Thank you anyway. Lynn Miller
Jan 09, 2009 | Kenmore Elite HE4 Electric Dryer
Brown streak on clothes
It could be from scorching due to getting too hot. This may be the start of a problem for you.
It is best to judge how long clothes need drying for before drying them. If they are left too long, sometimes the heat builds up.
Try a smaller load in there, and if you can reduce the temperature any then do.
Often it's just overloading is the issue.
Hope this is a solution for you, If so, Please rate as Fixya! Thanks.
Jun 18, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
108 people viewed this question
Top Dryers Experts
