Question about AT&T CECT Unlocked i68+ Quadband GSM FM Mobile Phone+Free gift Smartphone
Same problem i-68+ will read the card but not dial out or text
I have brought this phone into 5 AT&T stores and all I get is that this phone is not from them so they can't help me. They play with the menu but an't figure it out. There are networks to select in the drop down 2 for AT&T and 1 for Cell One are on there I also tried my friends T-mobile sim and same thing I bought 3 phones and none dial out, receive, or text. sim loads to the phone and dials just keeps telling me call failed or something about unable to connect. Any help will be appreciated.
John
Need to program new phone numbers
The manual is available here: www.uniden.com/pdf/CEZ260om.pdf. If you search google for "uniden cez260 corded phone manual" it is the first result.
You can find the instructions in the fourth column of text under "Storing a Name and Number in Memory"
Here is the text from that section, but I can't promise the copied text is accurate. Check the pdf at that address if anything doesn't work.
1. Press STORE. LOCATION? shows in the display.
2. Press the desired memory location (0 to 9 or quick call buttons A, B, or C.) NOTE: Press LEFT or RIGHT to scroll through 0 - 9 or quick call buttons A, B, or C to select a location.
3. Press STORE again to con? rm the memory location. NOTE: Use Delete to erase existing memories or to correct errors.
4. Use the number keys to enter the telephone number (up to 32 digits) and then press STORE to save. (The unit will not dial a phone number in this mode.) The cursor automatically moves to the text line for name entry.
5. Use the number keys to enter the name of the person associated with the telephone number you just entered. More than one letter is stored in each of the number keys. Press the keys multiple times to scroll through the letters for that key. For example, to enter "B," press "2" twice. Press LEFT two times to create a space. NOTE: The ? ashing cursor automatically moves to the next position or you may press LEFT or RIGHT to move the cursor to the next position.
6. Press STORE to save the name.
7. To enter another name and number in a di erent memory location, return to step 1 and repeat this process.
Storing a Pause in Memory
The REDIAL/PAUSE button has dual functionality and becomes a pause button when pressed in sequence after the STORE button. It is valid only when storing a number into memory locations. Use the REDIAL/PAUSE button to insert a pause when a delay is needed in an automatic dialing sequence (for example, when you must dial a 9 to get an outside line or when you enter codes to access your long distance company).
NOTE: A pause is 3 seconds in length and you can store more than one if a longer pause is needed. Changing a Stored Number Repeat the storage sequence under Storing A Name and Number in Memory, and press DELETE to delete the old number before entering the new number.
Erasing a Stored Name & Number
1. Press STORE.
2. Press the memory location (0 to 9 or quick call buttons A, B, or C) to be erased.
3. Press DELETE.
Copying Caller ID Memories to User Memory
1. Press LEFT or RIGHT to view the caller number and name you want to copy.
2. PressSTORE.
3. Press the memory location (0 to 9 or quick call buttons A, B, or C). The number ? ashes if there is a number already stored in that memory location.
4. Press STORE to enter Edit mode, and then pressSTORE again to edit the name. NOTE: Select a di erent memory location by using LEFT and RIGHT to scroll through 0 - 9 or quick call buttons A, B, or C.
5. Press STORE to con? rm and save. Wait three seconds to exit.
NOTE: If the name you want to enter is longer than 12 characters, only the ? rst 12 characters will be copied into memory.
Storing a Redial Number to Memory
1. Press STORE.
2. Press any key (0 to 9 or quick call buttons A, B, or C) for the memory location. If a number is already stored in the memory location, it will appear on the display. Use LEFT and RIGHT to select a di erent location.
3. PressSTORE again to con? rm.
4. Press REDIAL/PAUSE, and then press STORE again.
5. Enter the name, if necessary, and then press STORE to con? rm.
Copying a Redial Number to Memory
1. Press REDIAL/PAUSE while on-hook. Redial number will display along with PICKUP PHONE.
2. Press STORE.
3. Press any key (0 to 9 or quick call buttons A, B, or C) for the memory location. If there is a number already stored in the memory location, it will appear on the display. Use the RIGHT or LEFT buttons to select a di erent location.
4. Press STORE twice.
5. Enter name, if necessary, and then press STORE again to con? rm and save.
Dialing Numbers Stored in Memory
1. Press DIAL.
2. Press a memory location button or use LEFT or RIGHT to scroll through stored memory locations to ? nd the desired number. The number in that memory location displays.
3. Press SPEAKER or pick up the handset to dial the displayed number.
OR
1. Lift the handset or press SPEAKER.
3. Press DIAL again to dial the stored number.
Jun 11, 2015 | Uniden CEZ260 Corded Phone
I can't send and read text messages on my iPhone 5
Back up your iphone and take it to the Apple store, the phone cam out less than a year ago and Apple will give you a new one for free. But you have to plug it in to your itunes and back it up to your computer first.
Mar 25, 2013 | Cell Phones
How can I recover deleted texts and pictures from a pre paid Verizon phone with no Sim card
Lost your photos on Android phone & need to recover deleted pictures, try GT Recovery for Android - the World's 1st Data Recovery Software for Android smart phones.
It can directly recover deleted pictures, photos lost due to deleting, restoring factory settings, flashing ROM, rooting, etc., from SD cards inside Android devices. It let you preview the deleted photos before recovery. Watch the video tutorial to learn how to retrieve photos from Android phone easily with simple clicks.
Key features of Data Recovery - GT Recovery for Android:
Preview & selectively retrieve photos and video lost due to any problem
Support all Android phones/tablets, like Samsung, HTC, LG, Motorola...
Only read and recover the data, no personal info leaking, 100% safe
Aug 18, 2012 | Cell Phones
How do I load a Globe prepaid to my Champ Duos when after I send 223, the numeric disappears for me to be able to type in the card no.
Hi, To load value for Globe Prepaid:
  • Dial 223 and press Call (Green Key). Please follow the voice prompt.
  • Enter the Call & Text Card No. and press #.
  • Enter the Call & Text Card PIN and press #.
  • A voice prompt will then confirm that the reload attempt is successful.
I hope this helps.
Thanks for using FixYa.
Sep 13, 2011 | Cell Phones
How do i operate speed dial on razr
The user manual for the Moto Razr V3 is at: "V3 GSM Motomanual" Motorola http://www.motorola.com/mdirect/manuals/V3c_9496A74O.pdf
Pages 68-69 of the manual (which correspond to pages 70-71 of the PDF file) state: "Calling With 1-Touch Dial To call phonebook entries 1 through 9, press and hold the single-digit speed dial number for one second. You can set 1-touch dial to call the entries in your phone memory phonebook or the SIM card phonebook: Find the Feature M> Settings > Initial Setup > 1-Touch Dial Press To 1 S scroll to the location you want 2 SELECT (+) select the location" Page 8 (page 10 of the PDF file) indicates that the symbols (represented by "M>", "S", and "SELECT (+)") mean the menu key, 4-way navigation key, and SELECT. Page 51 (pages 53 of the PDF file) explains how to store phone numbers in the phonebook -- which you can then call with 1-touch dial.
Aug 24, 2011 | Motorola Mobility RAZR V3
I unlocked a verizon blackberry 9630, once i put my tmobile sim card in it, it lets me send n recieve texts and recieve calls but it doesnt let me make call it say emergency calls only, how can i fix this?
Turn the phone off, count to 5, then turn it back on. It should find the nearest tower for a signal. A bad SIM card won't do this either like one person said. He/she was lied to at the store or by Customer Service. I used to work for AT&T Wireless & this Emergency Only issue was a big one. A bad SIM card won't allow you to place or receive calls or text messages. T-Mobile runs on the GSM network like Cingular/AT&T does. Just remember to turn the phone off for 5 seconds, then turn it back on. Here is the code to reset...*2767*3855# If this is helpful to you, please rate it....
Jun 24, 2010 | Cell Phones
MOTORIZR Z3 - Message Memory Issue
One of my few complaints about my Z3 is the low message capacity. I have a 2gb sd card in there...why can't I store more than 500 texts?
But...500 is a lot more than 10, there's definitely a problem here.
I know there's a way to change the default storage location, although I'm not sure it will change the location of texts or not. Here's how to do it:
Go to the main menu and select "Settings". Scroll down to "Phone Status" and select it. Then select "Download Location" and finally, select the memory card.
Now...What concerns me the most is the 4Tb message flood O_o
Aug 27, 2008 | Motorola Mobility MOTORIZR Z3 Cellular...
Recover deleted text messages
You may try this mobile recovery software which helped me before. You can download trial for free
http://www.asoftech.com/adr/
Please be noted that your phone memory should show as a drive letter in your explorer, if not, you need to take out your memory card and connect using a card reader, or plug-in to card reader slot if there's any on your computer.
Mar 27, 2008 | Cell Phones
TEXTING
Press the down button. (Arrow pointing down.) That will make the message go down.
Sep 12, 2007 | LG KG800 Cellular Phone
AT&T CECT Unlocked i68+ Quadband GSM FM Mobile Phone+Free gift Smartphone Logo
186 people viewed this question
Top AT&T Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
