Question about LG Chocolate 3 Cell Phone
Phone stuck on white "downloading" screen
The phone battery was low and it died, then I went and plugged it in and the next time I looked at it it was on a white downloading screen and I can't get it to stop. I even took the battery out and the screen was still up.
The batery of my phone is dying too quickly.
Common battery drainers are GPS, Screen intensity, CPU, WIFI & Cellular communications.
If screen intensity is low / screensaved and GPS is switched off, next is to look for excessive communications over WIFI or Cellular or Apps continuously using up CPU.
Mar 23, 2015 | Acer DX900 Smartphone
My alias 2 is stuck in USB download mode. How do I
My boyfriend has a samsung convoy and his phone does this every time it dies, he fixes his taking the battery out, then he puts the battery back in, and BEFORE you turn the phone back on put the charger in and let it charge for a min or two. Then try turning the phone back on.
Jan 05, 2010 | Verizon Communications Samsung Alias Cell...
K800i will not charge
Possible to rectify with Wotan Server to repair the EROM which is checked before firmware is flashed. You will have to buy credits and a data cable. Follow instructions pressing key 2 and 5 together. You may as well update the firmware after this process. Google around you will find this is an issue
Nov 20, 2009 | Sony Ericsson K800i Cellular Phone
Wont get off tmobile shadow white screen...
the "soft buttons are right below the screen hold both down then turn on the phone this will make the phone ask if you want to reset to default so try removing the batt first as this it the last resort you will lose all changes made to the phone except mem card and sim card stored items worked on my shadow fine good luck peeps
Mar 02, 2009 | HTC Shadow Smartphone
White screen
Have you charged the battery up for a long time ? sometimes if the battery is low on power it will power up the device and then close it off due to the low power.
If that is not the case then it seems that there could me a Software or hardware problem ! the only way of solving these problems would be to goto the sony ericsson Support website at www.sonyericsson.com and from there search for your phone, if that fails, try calling your Mobile Carrier or Sony ericsson Direct !
Hope this Helps !?
Oct 27, 2008 | Sony Ericsson K750i Cellular Phone
Screen is now white with the text --download started--, emergency @ usb.
Holding down the camera button, (samsung a870), while inserting the battery got this one working again.
Feb 27, 2008 | Samsung SCH-a870 Cellular Phone
Phone stuck in Test Mode
my did that when i plugged the charger in while the phone was off. i yanked the battery, went to the bathroom, came back and put the battery back in, and i was good.
Dec 15, 2007 | Cell Phones
Phone will not turn on
ok, take out the battery and look and see you can see a white dot pice of circular paper, if it is red, your phone somehow got water in it, look at your battery(white dot paper) if it is red than you have water in you phone. now you need to dry it! leave it on your car dast board in the sun 24hrs or use a hair dryer ( use low heat) you must dry your phone and battery completely before the next step, Next step- find a good working battery and insert it in your phone, see if this will correct your problem, sometime the battery volt are very low or maybe the battery itself its bad, but make sure you put in a new battery to test this out, don't pay for the battery until you check you phone at the counter, ask for the right model for you phone.
good luck
z
Nov 30, 2007 | LG CHOCOLATE VX8500 Cellular Phone
LG Chocolate 3  Cell Phone Logo
135 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
