Question about Dell 0Y3740 Keyboard
Fujitsu FKB8720 keyboard keys now scrambled a bit
Pressing "A" now also hits return, Pressing "F" now also engages shift lock, pressing "H" now also engages num lock.... Just started actng up "out of the blue"..... "Burped" the keyboard and rebooted cold.... still acting up.... This uses regular windows XP driver
  • 30 Answers
Try plugging in an external keyboard to see if that works - if so you may need to reseat the builtin keyboard or have it replaced
Posted on Jul 24, 2009
How do I unlock the keyboard of IBM Selectric III???
The Selectric typewriter has several "interlocks" that can cause the keyboard to be locked. When you turn the machine off there is a mechanism that locks the keyboard. When you turn it on the part should move and unlock the keyboard. Sometimes this part sticks and the keyboard will remain locked. When you type any character the keyboard is locked to prevent two keys trying to type at the same time. The machine locks and unlocks very fast. One keys is locked in and prevents others from working. try turning on the machine and hitting every key just a little bit harder and see if it then types. When you shift, as the ball is turning the keyboard is locked temporarily so it won't attempt to type as the ball is turning as that would damage the machine. Sometimes the shift mechanism can cause the keyboard to remain licked as the shift may not have finished it's complete cycle. Also, the return mechanism locks the keyboard temporarily when the carrier is returning to prevent you from typing when the carrier is moving backwards. Only a qualified technician can resolve those issues.
May 08, 2014 | IBM Correcting Selectric III Electric...
Jumbled keyboard numbers
Are you typing on your laptop and notice the text has become illegible? What should be letters, have become numbers or symbols. This odd behavior can probably be explained be peering a little closer at your keyboard. Those little numbers on the keys. These numbers and symbols normally become active when you hold down the function key, usually labeled as the "FN" key. The "FN" key is similar to the Shift key, activating a second function assigned to a key. It can become active seemingly on it's own because a key is locked in the on position.
Before performing numerous key combinations, try the simple thing of lightly tapping the "FN" or "Num Lock" 5 to 6 times. There may be a small particle of something logged under the key that you can loosen, move, or crush down. Do not bang the keys, just press normally. Next focus on the "Numlock" key which usually located with the "Print Screen" and "Pause" key on the top right of your keyboard. Press the "Numlock" key, then press a scrambled key to see if it's normal. Older model laptops may require you hold down at the same time, the "Ctrl-Shift-Numlock" keys. Newer models may require holding down the "Shift" key and pressing the "Numlock" key. Turn off the Function key with the following combinations. Hold down the "FN" key and hit the "Numlock", Hold down the "FN" key and hit the "Scroll" key and Hold down at the same time "Fn+F12+Num Lock"
Feb 08, 2013 | Lenovo Computers & Internet
Keyboard numbers are jumbled
Screen only displaying keys that are on blue on keyboard
sir if u wants to type the special characters then press the shift key before pressing that button.
Apr 23, 2009 | Dell 0Y3740 Keyboard
Problem with keyboard or input of certain keys
hi.. is that a bi-lingual keyboard that you purchased? If so, what model? If that's a toshiba laptop w/ a bi-lingual keyboard, press the left (shift+ctrl) buttons for 10-15secs then release it. You should be able to bring back the normal function of your keyboard. If your having problems pressing the "n" key and it replaces it with a number on the screen when you type it, it's most likely that you enabled the "num lock" function of your keyboard, on Toshiba press FN+F11, on Dell FN+F11 also i think, it may differ on other models, sometimes FN+ Print Screen or Pause (above F11).
Hope this helps.
Oct 03, 2008 | Microsoft Windows XP Home Edition
Scrambled keyboard
Is it giving you numbers and symbols? do this: Press and hold the function key fn while pressing the num lock key num lk . This will deactivate the integrated keyboard/numeric keypad, and the keys will respond normally.
Please remember to rate all users who assist you for free :)
Jun 30, 2008 | HP Compaq Presario V6000T Notebook
Fujitsu amilo laptop
Try making sure your 'num lock' is off and if that doesn't work, try holding fn while pressing the key.
Mar 28, 2008 | Fujitsu AMILO M-6500 Notebook
Keyboard letters all mixed up???
Make sure the "Num Lock" key isn't activated (LED Off).
Windows 2000 / XP actually saves the last "Num Lock" setting when you log off and restores it when you restart.
Feb 12, 2008 | Computers & Internet
My typing goes uppercase without hitting the caps lock
I have the HP Pavilion and cap locks does the same thing.
THIS WORKS EVERY TIME. Hit both the right and left shift lock simultaneously about 5 to 10 times. It immediately disengages the cap locks. It is a little bit of a hassle, but I'm just used to it. It may happen 3 times per week, but I LOVE the machine, so I just fix it this way!
Oct 20, 2007 | HP Pavilion dv8000z Notebook
Dell 0Y3740 Keyboard Logo
140 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
