100m runs of cat5e outdoor for video survillance. get run over by vehicles. What should i use to perform a filed splice? replcaing cable runs not safe. cable is sometimes 50% buried and some sometimes not at all.
  • 724 Answers
If you can afford outside video peek a boo then either go with a wifi setup or run 100m of pvc below frost line and snake new wires.
What is not safe to run cat 5 wire ub PVC?
$$$ that is all!
Posted on Jul 24, 2009
What type of cable should I use to hardwire my shop for ethernet? Approx 100m from the router, running along existing powerlines.
I would run cat5e There is no cable that allows runs longer than 100m without a switch or repeater.
Jul 13, 2016 | Computers & Internet
All weather camera
Uniden cameras need to pair with Uniden radio recievers. The reciever is connected to your PC via a USB cord.
You can go to the UNIDEN web site and by knowing which camera you have find the receiver that is correct for you
Mar 29, 2014 | Uniden UDWC25 Wireless Video Survillance...
Video matrix switch uninitialized?
Use a Hyper terminal, Hercules SETUP utility is user friendly for this. Attach a Serial cable to the unit (straight through cable not null modem) or use a USB to serial cable.
Set the Baud rate to 115200
Data size 8
Parity none
Handshake OFF
Mode Free
do not check the box for Hex
For the 12x8 digital/ analog audio matrix switch cat5 enter the command [S,M,Q]
12x8 digital/ analog audio matrix switch [S,M,L]
8x8 component video digital/ analog audio matrix switch cat5 [S,M,C]
8x8 component video digital/ analog audio matrix switch [S,M,B8]
12x8 component video matrix switch [S,M,I]
12x8 component video matrix switch cat5 [S,M,H]
8x16 digital/ analog audio matrix switch [S,M,G]
8x16 digital/ analog audio matrix switch cat5 [S,M,E]
8x16 component video matrix switch [S,M,F]
8x16 component video matrix switch cat5 [S,M,D]
12x16 component video matrix switch [S,M,J]
12x16 component video matrix switch cat5 [S,M,O]
12x16 digital/ analog audio matrix switch [S,M,K]
12x16 digital/ analog audio matrix switch cat5 [S,M,R]
Oct 31, 2013 | HDTV Supply 12x8 stackable digital/analog...
Belkin n300 wifi extender
didn't have much luck with this unit at the limits either.
Mar 04, 2013 | Belkin 330 ft. Network Extender 4PORT HDMI...
I have two des-1005d network switches. i want to communicate betwwen them with a cat5e cable. the cable is made as cross through and distance is about 70 meters. with one switch pc is connected and at...
Max distance for Cat5e cable is about 100M, but that is the best case scenario, essentially a straight line, down a building. If you have any kind of interference, like flourescent lighting, high voltage lines running parallel to the ethernet cable, the distance will be much less than 100M. Although it looks like you have 60 feet to spare, anything interfering with the cables will cut the signal down. Try to move the switches closer together, make the cable from pc to switch longer and ADSL modem to switch longer and cable between switches shorter. Use a known good straight through ethernet cable, as modern switches don't require crossover cables.
From Wikipedia: http://en.wikipedia.org/wiki/Category_5e#Maximum_cable_segment_length
According to the ANSI/TIA/EIA standard for category 5e cable, (TIA/EIA 568-5-A[5]) the maximum length for a cable segment is 100 meters (328 feet). If longer runs are required, the use of active hardware such as a repeater, or a switch, is necessary.[6] [7] This 100 meter limit is all inclusive. According to some authors,[who?] the practical limit for permanently installed cable is about 90 meters, leaving 5 meters at each end for the patch cables that connect the end equipment to the wall panel.
Hope this helps.
Sep 27, 2010 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
I have 2 buildings about 500 Ft apart connected with 2 conductor telephone cable, formerly used for a radio tie line. I would line to connect to the internet from the other building.
326 feet is a max run for cat5/cat5e cable. You would need a repeater for runs longer than that. Wireless will not work properly either without a singal repeater. You could look for outdoor repeaters and run a drop line to the 2 building but this will be costly
Feb 14, 2010 | 2wire (1000-400108-001) Router
What is the difference in CAT 5 and CAT 6 cable
CAT-5 is rated to 100M with 24 gauge wire
CAT-6 and CAT6e is rated to 550M with 23 gauge wire
But as a note .. Cat 6 really has not been been approved and has no definitive specs yet .. Use Cat5e
Feb 21, 2009 | Intel PIII 600MHZ/ 512KB/100MHZ SECC2 p/n...
HP Procurve 1700-8 working upto 10m UTP cable only.
It is not a distance limitation of the switch, rather the cabling in the walls and ceiling. If the cable is Cat5 it can be up to 100M, but this can be drastically reduced with things like EM interference from fluorescent lights, kinks in cable and more. The switch auto detects the maximum reliable speed and this interference would cause it to drop to 10MBps. If you don't have a cable certifier (very expensive) you may want to consider simply replacing the cabling run with Cat6 following best installation practices. You can learn more at http://www.lanshack.com/cat5e-tutorial.aspx.
Feb 14, 2009 | HP ProCurve 1700-8
Phone to Cat5e cabling - How do I wire the wall plate
Wire your phone box using your Cat5 cable, use 4 wires instead of 8 wires of Cat5.
Nov 20, 2008 | Cat5e Unshielded Twisted-Pair Patch Cable...
CAT5e
The max distance that Cat5e or Cat6 can be run is 90 meters or 295 feet. As cnavarro stated, signal repeaters would be best utilized in your situation up to 590 feet otherwise fiberoptics are the next and more expensive route. You should also divide the run equally with the repeater as it would not be effective with an offset balance.
Sep 14, 2008 | Cat5e 100 Foot Shielded STP 350mhz Network...
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
