Question about Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop
Lenovo 3000 N200
I´m having a problem with my Lenovo 3000 N200 and everytime I power on the notebook with battery and AC adapter pluged i, when I got to the logon screen, it shuts down. I tried power on without the AC adapter and then plug the AC adapter at the logon screen and again shuts down. I have always to power on the notebook without the AC adapter and after the windows logon I have to wait 2 to 3 minutes to connect the AC adapter. After this procedures, the unit works fine and doesn´t shuts down. I have no clue.
  • 30 Answers
Sounds like the mother board maybe on its way out - is it under warranty?
Posted on Jul 24, 2009
HI, i Have lenovo 0769-A63 laptop i have problem in my battery, when i put AC then my laptop is start,battery shows 83%(pluged in,Not charging). when i remove the AC System is cloosed is just like Cpu, its...
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Aug 12, 2011 | Lenovo 3000 N200 Notebook
Hi, my lenovo 3000 Y 410 notebook does not turn on. I removed the battery and connected the AC adapter but i don't get the power supply to the laptop. i can't hear even a beep sound when i tried to turn on...
Whenyou connect the power adapter into the laptop, does the power LED light up? Ifnot then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Dec 18, 2010 | Lenovo 3000 Y410 Notebook
Power Failure of Lenovo 3000Y400; AC adapter and its power cord are well connected to the computer and power outlet & equip the battery. But my computer still without power indicator & any...
Welcome to Fixya!
You can run the computer by just using the power adapter. Take out the battery and turn on the computer just using the power adapter. If the computer wont turn on then possible problem would be the power adapter itself or the socket where you connected the power adapter to your computer.
You need to send the computer to Lenovo depot repair center for repair.You may try to use other lenovo adapters just to check if the adapter is the problem.
Thank you for using Fixya!
Dec 02, 2010 | Lenovo 3000 Y410 Notebook
Lenovo y410 laptops turns off suddenlty while using it for long hours
hi
is the computer dissipating excessive heat from bottom ? is the heatsink fan working (is it blowing out air from fan on the side ? if not, then replace the heatsink fan. This shut down occurs to advise you that something is not working well , and to avoid damage to the CPU and/or mainboard, its letting you know that.
if the fan is working fine-- are you on the computer while the AC adapter is NOT plugged in ? Are you fully charging the battery before you use the notebook without the AC adapter ? If you are NOT using the AC adapter, running on battery life only, then do this : shut down the notebook, disconnect the power adapter, remove the battery back up from rear of notebook.
reconnect the AC adpater and start the computer -- perform normal function on the computer, run it and work with it for a few hours. if the same issue occurs, (unwanted shut down) , then perhaps the AC adapter is faulty, which is not charging the battery to full capacity.
let me know what happens-- i'd appreciate your feedback w/o receiving bad rating
Nov 15, 2010 | Lenovo 3000 Y410 Laptop
3000 c200 is dead and wont start up even though there is power to ac adaptor (warm)
Remove the battery and try to start the laptop. If the battery is totally down it may cause an issue even though it isn't supposed to. Also, check the voltage at the plug that connects to the laptop. A short at the plug will give you a warm power adapter but no power to the laptop.
Oct 12, 2009 | Lenovo 3000 C200 Notebook
My Lenovo N500 does not want to startup but there is a light that stays on all the time, it is next to the start button
The light that stays on is probably a power indicator. Remove AC adapter and battery. Hold power button down for 20 seconds. Put battery back in and reconnect AC adapter. Try to start your computer.
Jul 30, 2009 | Lenovo 3000 N500 Notebook
Will not boot up or turn on though it is getting power
The Charger could be bad, Try replacing that, or let charge, then try to turn on. The laptop might not boot with AC power. kinda stupid but maybe. If that doesn't work, the AC adapter is bad.
Jun 12, 2008 | Lenovo 3000 N100 0689 Notebook
Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop Logo
258 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Lee Durbin
Lee Durbin
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
