Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ge ice tube filler freezes up - GE (PSS26MSRSS) Side by Side Refrigerator
  • GE Master
  • 4,654 Answers
Defrost the fill tube with a hair dryer this should get you going. Sea Breeze
Posted on Jul 24, 2009
  • John Tripp
    John Tripp Jul 24, 2009
    If for some reason the water control valve has a small leak causing this then we need to check the water control valve to see if it is sticking open. Sea Breeze
  • John Tripp
    John Tripp Jul 25, 2009
    Thank You for your rate! If you have anymore problems feel free to let me know. Sea Breeze
  • 49 Answers
This happen to me to i did what this guy said but the solution i found that fix this was turn down the freezer to just below recomended setting..worked for me//oz
Posted on Jul 25, 2009
The filler tube for the ice maker freezes up between the box and the ice maker. I replaced the ice maker but it didn't cure this problem. What do I need to do?
Replace the dual water control valve because although it is off water seeps by and freezes once it gets inside the fill tube. What is your model number?
Appliance 911 Sea Breeze
Aug 06, 2015 | Refrigerators
Filler tube in back leaks or shoots off fitting going to ice maker
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Sep 07, 2011 | GE (ESS25KSTSS) Side by Side Refrigerator
I have a hotpoint refrigerator freezer that works fine except i am having issues with the ice maker. The tube carrying the water to the ice maker goes through a support cup. Water has started freezing in...
Make sure tube is pushed all the way into back wall tight.Then make sure tube angles downward so water completely drains. This is a goofy GE problem.
Aug 16, 2011 | GE Refrigerators
Kenmore 10670187000 Refrigerator. freezer filling with water/ice
You pull it out from inside the freezer but I would try melting any ice that may be stopping it up first with a hairdryer. The water inlet valve on the back of fridge is probably leaking and when the water gets to to fill tube it freezes and partially blocks the tube causing it to spray out. Disconnect the line coming out of the water inlet valve to see if it has a slow leak. You may need to replace the valve.
Sep 03, 2009 | Refrigerators
GE TFH27PRSA ice maker water fill tube and receving bucket on ice maker keeps freezing closed. No other problem with unit including water despenser to door. Once the tube freezes closed, water is leaking...
all is normal with the defrost heater getting red hot.
as far as the inlet tube freezing, you most likely need a new water inlet valve. it may not be closing all the way and water is slowly dripping into the icemaker and freezing up right away. a new valve should fix your issue. here is the part that you need. http://www.repairclinic.com/SSPartDetail.aspx?s=t-TFH27PRSA-%3d%3di1032629&PartID=1032629
Aug 21, 2009 | GE Profile PSW26P Stainless Steel Side by...
I ice maker keeps freezing in our side by side GE fridge.
This annoying problem can have a variety of causes. Check these four things first:
  1. Make sure the water supply is greater than 20 psi. If too low, thewater valve won’t seat properly and it’ll “weep.” Common causes of lowpressure are gunked-up saddle tap valves, kinked water supply line, andusing a reverse osmosis filter to supply water to the icemaker.
  2. Check between the valve diaphram and valve seat for sediment. If found, do not attempt to repair, buy a new valve.
  3. Check to see if the black, flexible portion of the fill tube iswrinkled, twisted, or kinked which can cause ice dams that block thefill tube.
  4. Find out if the water has been shut off while the icemaker has kepton cycling. This, too, can cause the fill tube to freeze up.
If all the above checks out and you’re still getting fill tube freeze-ups,then best get a service guy to take a look. It could be a complicated repair.
Jun 24, 2009 | Whirlpool ED2FHEXN Side by Side...
Ice forming on condenser copper tubing GE referigerator
is your drain line plugged up under that coil? another thing to check is if the door asket pinched that wold allow ait to infiltrate into the freeze and freeze up the coil. remember to clean under the unit once a year to keep the unit working properly and not having to struggle to condense the refrigerant. Hopt this solution's work for you and have a Happy New Year.
Jan 05, 2009 | GE Profile 21.6 cu. ft. Side-by-Side...
Ice maker tube freezing up
  • change the water valve on the back of the machine.
  •  the water valve is slowly leaking water up to the icemaker where it freezes and builds up ice, blocking the water flow.
Jun 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
167 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
