Question about Microsoft Office Professional 2007 Full Version for PC
Word doesn't open properly
When I try to open a file saved in word, it doen't allow me to view the file. It says cannot find file/file cannot be found... I have not changed any of my files locations, so I do not understand the complication! I cannot open anything for the first time straight from the folder it's located in, unless word is already opened, or I've tried it for the second time.
  • Neurophile Nov 24, 2007
    I can't open Word files from the Start menu (where the most recently used documents are displayed). I click on the file, it appears to be working but it only opens the Word application, not the file. I then have to click Open, click the file, and then it opens. Very frustrating.
Dear Shell,
This could be because of file assosciation problems on your pc. What you need to is that right click on word file while pressing shift, then select open with and choose default program MS word. Then it will always open file in MS word on double click.
Also Try running winword /r (from the Run dialog box). This should fix any file association problems.
If this solution was helpful kindly press solved.
Posted on Nov 25, 2007
Thank u very much
Posted on Jul 15, 2008
I can't open my docs yet I KNOW they haven't been deleted because I am able to email them. How do I fix this?
MS Word offers several different views in which you can read and work on documents.
The view you are using when you save a document will be the default view when you open that same document the next time.
Likewise, if you open a document created by someone else, the view in which they saved it will be the default for that file unless you change it and save it again.
You can change your default Word template, though, so that new Word documents always open in the view of your choice.
Close any Microsoft Word documents or windows on your computer.
Locate the \"\" file on your computer.
This is the default template for all new Word documents. If you are using Windows XP, navigate to \"c:\\documents and settings\\username\\application data\\Microsoft\\templates\", changing \"username\" to your user name on the computer.
For Windows Vista or Windows 7, go to \"c:\\users\\username\\appdata\\roaming\\Microsoft\\templates\", again, changing the username to your user name on Windows.
Right-click \"\" and select \"Open.\"
A new Word document will open, which is actually the default document template.
Change the view to the one you desire.
To do so in Word 2003, go to the \"View\" menu and click on the view you want to use.
In Word 2007 or 2010, go to the \"View\" tab and select a view.
Type something into the document and then delete it.
This allows Word to recognize that a change has been made to the template without adding any unwanted items.
Click the \"Save\" button or press the \"Ctrl\" and \"S\" keys to save the changes to your default Word template.
Aug 29, 2013 | Microsoft Word 2010
Looking for word document I did not save
The power just went out while you working on an important document you forgot to save.
Do not panic because Microsoft Word comes equipped with a feature that automatically will recover files you did not save.
Typically, this feature works by default.
The program allows you to change how often Word saves your documents and you can adjust the location where Microsoft Word saves these "Auto Recover" files.
Open up Microsoft Word.
Do not click on a file to open the program.
Instead, open the program by double-clicking on the program's icon.
Allow the program to load for a couple of minutes before clicking on anything.
Look on the left side of the screen.
If Microsoft Word recovered the file, a "Document Recovery" task pane will load.
Find the file's date.
Double-click on the file in the "Document Recovery" pane.
This will open the file in Microsoft Word.
Click on the "File Menu" and select "Save As."
Save the document as a ".doc" file type, and type a name for your document in the "File Name" box.
Open Microsoft Word to determine if the program auto-recovered your document.
If your software is set to auto-save your document every couple of minutes, when the program is restarted, any document that was not saved prior to closing, may appear in the auto-recover window on the left side of the screen.
Click on your document, and the last-saved file will open.
However, anything you typed after the last auto-save is gone, but at least you haven't lost the entire document.
Search the auto-recover files manually if the auto-recover pane did not appear when you opened MS Word.
Click the Start menu at the bottom of your computer screen, and click "Search." Some operating systems have the search option as a part of the Start menu.
Search for "*.asd" to search for any recovered files.
If you find the file, open Word, and click "Open" in the menu.
Search through all files, and locate the file that ended in .asd. Click "Open" to view your file.
If you are using Word 2002 or 2003, you need to restart your computer after clicking "Open." Re-open Word after your computer re-boots to view the recovered file.
Check your backup files.
If you have the "Always create backup copy" option selected in Word, you may be able to find a backup copy of your document.
Find the location where you last saved the document.
Check for the extension .wbk.
If there aren't any, search your whole computer for files with that extension.
Open your file by clicking "Open" in Word, and search all files for the .wbk extension.
Once you locate the file, click "Open."
Look in the temporary files on your computer.
Complete a search for files that end in the extension .tmp by typing "*.tmp" into the search box.
Narrow the search down to specific dates of when you were working on the document.
If the file does not show up, try searching for the "~*.*" convention.
Some temporary files are in this format instead.
If your document is now in your temporary files, you will need to recover the damaged document.
Search for it within Word.
Click "Open and Repair" when you find it.
Hope this helps
Nov 06, 2012 | Computers & Internet
Hi I bought a SankDisk Cruzer Edge 4GB and I tried to run it but I can't. It says that I must install RunSanDiskSecureAccess-Win.exe, but it doesn't let me do that because it immediately opens a...
The Cruzer drive comes with its own enabling software (the program name you mentioned). You should be able to view that drive using Windows Explorer (to view the files). Then right-click on the RunSanDiskSecureAccess-Win.exe file and select "Run as Administrator". This should execute the program and allow you to utilize the drive after it installs completely.
Sep 22, 2017 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
The file i download is deleted when i shut down my computer
It depends on the way the file was saved that it will be retained in your PC. Some files cannot be downloaded as some websites do not allow. So you will need to copy and paste scuh documents.
Any other files make sure it is saved into a FOLDER marked with a title so that you can look into..
Secondly you can reset your system to go OFFLINE and then open the files to see if this was saved. Can also be checked from the HISTORY files.
Open from TOOLS, internet options, then settings and view files.
Jan 11, 2011 | Computers & Internet
I took pictures in RAW and cannot open /save pics on my pc??
Tou need software that allows you to view RAW files: Nikon Capture, the software that may have come with the camera, Adobe Photoshop, Adobe Lightroom, Others. Just google "view NEF file software
Dec 19, 2010 | Nikon D80 Digital Camera
Windows mail and powerpoint viewer
From windows mail choose Options Then Security Tab. You can change some security behavior here for allowing viewing of attachements, however it will only work for certain file types. Others are prohibited regardless. IT's a measure Microsfot feels is protecting folks forcing them to save the file then open it. This allows Antivirus programs to fully scan the file before use. But it's fairly impractical.
If you get frustrated with WM, you might try Thunderbird from Its free and far more flexible and robust than WM.
Jan 05, 2009 | Microsoft Windows Vista Ultimate Edition
Can't view file in Kingston 8GB Pendrive.
Try this,
Format the drive using HP disc format tool after backing up the data.
Make sure you select FAT32 as file system.
You can download this tool from the following link,
Please let me know if the issue persists.
Nov 26, 2008 | Electronics - Others
Sending attachments in Outlook 2003
Try saving the document to your local drive first, then send the file as an attachment. When the file is opened from your Outlook, it resides only as a temp file while you are viewing it, then to try to send that temp file, it causes issues with outlook. Save the file first, then send it, but don't try to send the file from the temp view whilst opening the file that is still in another e-mail
Nov 03, 2008 | Microsoft Office Outlook 2003 for PC
Printing a 2007 Word document on Word 2000 and yes I've tried the Converter but to no use.
Open the document in word 2007, click file, save as and in the save as dialog box at the very bottom is a field "save as type" Click the down arrow and scroll down to and select Word 6.0/95(*.doc)
In the File Name: field type a new name so that you don't save over your original.
Click save.
The new file will open in word 2000.
Dec 28, 2007 | Microsoft Office Professional 2007 Full...
Won't open files
check if the page will open in a web browser. if it does open, copy the html from the web page and paste it into the html are in front page. and now try saving it.
Jun 10, 2007 | Microsoft Office FrontPage 2003 for PC
Microsoft Office Professional 2007 Full Version for PC Logo
1,201 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
