Question about ASUS Eee 4G Notebook
When i turn on my pc it will power up but i can not open any program and the only way i can turn it off is by taking out the battery
  • jconzatti Jul 24, 2009
    i can see all of the desktop programs but when i click on them they do not open i have tried going through start and opening programs that way still will not open. i have tried rebooting my pc still no luck and the only way it will shut down is buy taking out the battery. here are the numbers off the back TKMB6-9VHBG-G2CTJ-4MM7Q-CTXKW EeePC 900HD FCC ID MSQEPC9GE703 IC 3568A-EPC9GE703 CCAF08LP0320T2
    I FORGOT TO ADD SN 8C0AAQ227783 VN 5516
  • 1,555 Answers
Kindly elaborate your problem a little bit. After starting up your pc what happens you said you can't open your program means you are unable to see anything neither task bar or desktop or anything. Which operating system you are using and what is the model of your pc.
Posted on Jul 24, 2009
  • Aruna Singh
    Aruna Singh Jul 24, 2009
    You told you have to take out battery for switching it off so i presume its not your desktop its your laptop. What I wanted to know was just your laptops company brand name and model. Anyways once you have switched on your laptop and nothing works have you tried pressing Ctrl+Alt+Delete just press it. If task manager pops-up simply go to processes and scroll down to explorer right click on it select end process tree. Wait for 2 minutes and then go to applications and click new task and type explorer over there and ok. Now try to open your programs and kindly let me know the current status
How to. Factory reset on sharpe xe-a206
Take the batteries out. Turn the power off. Turn the key to REG mode. Turn the power on. Re-fit the batteries.
Now ready for programming. If you need a manual, one of the users has it here:
http://the-checkout-tech.com/manuals/cashregisters/Sharp_XE-A206_operation_manual.html
Jun 25, 2014 | Casio Parts Cash Register PC Desktop
Casio se-s300 int number
This means the machine has no program.
Try taking the batteries out, turn key to REG mode, turn power off for 5 minutes, then back on. Put batteries in.
If anyone needs a Casio SE-S300 manual, try here:
http://the-checkout-tech.com/manuals/cashregisters/Casio_SE-S300_users_and_programming_manual.html
Jul 04, 2012 | Casio Parts Cash Register PC Desktop
Battery has been charging to 100%. Suddenly would only charge to 76 percent. Now, after two weeks, will max at 62 percent. Computer is 1 year old. Can battery meter be recalibrated?
Pulled from Gateway's website:
Do not interrupt the battery recalibration process. If recalibration is interrupted, you must start the process over again.
  1. Close all open files and programs.
  2. Connect your notebook to AC power and allow the battery to completely charge.
  3. Disconnect the AC power and restart your notebook.Note: If the power cord plug.gif or battery baticon.gif icon does not appear on the taskbar, click the show hidden icons showhidden.gif button. If the icon still does not appear, verify thatAlways show icon on the taskbar is checked on the Power Options Properties Advanced tab.
  4. Completely discharge the battery by doing the following:
    1. From the desktop, right-click on the power icon, then select Adjust Power Properties.
    2. Click the Power Schemes tab.
    3. Click the arrow button to open the Power Schemes list, then click Always On.
    4. Click the Alarms tab.
    5. Click to remove the check mark from the Low battery alarm and Critical battery alarm checkboxes. Let the battery drain until your notebook automatically turns off.
  5. After the battery is completely drained, reconnect your notebook to AC power.
  6. Charge the battery completely until the yellow battery status indicator goes out.
  7. When you are ready to use your notebook again, do the following:
    5. Click to select the Low battery alarm and Critical battery alarm check boxes.
Mar 11, 2011 | Gateway Netbook N450
How do i set my desktop i want to go to the internet with out so long
lilonerice,
If you want your laptop to turn on faster, I would consider the "Sleep" and "Hibernate" options instead of turning your machine off.
Sleeping uses up a tiny amount of power over time. So if your battery runs out while the machine is asleep, it'll turn off and anything you have open will be lost. But it does turn on the fastest.
Hibernate turns the machine completely off, and saves the information about what programs are open. Unlike sleep, it doesn't use any power, but it does take longer than sleep to go into, or come out of. It is still significantly faster than shutting down your machine.
Mar 01, 2011 | Lenovo IdeaPad S10-3 Netbook
Have a brand new TE-2200. The machine hung up in the middle of programming and would not allow a reset. I unplugged it from the wall and removed the backup batteries in an attempt to reboot. After...
Firstly, try this:
Turn key to PROGRAM mode Turn power off at wall Hold RECEIPT FEED down - keep holding it Turn power on at wall. Wait 10 seconds Let go of receipt feed. Press SUBTOTAL once
If display does not come on,
Turn power off at wall Turn key to REG mode Take one battery out. Wait at least an hour. Turn power back on at wall (you will now need to fully reprogram it at this stage)
If it is still dead, let me know
Feb 06, 2011 | Casio Parts Cash Register PC Desktop
When i try to open it it says it is open but i can't see it= And if i start it with Run, it starts opening till i restart the pc i even have problems with restarting it because the programe keeps opening...
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
Oct 26, 2009 | Computers & Internet
Unable to program
Hi. You have battery failure and you have lost everything. If it is a powerful machine, it may require a lot of system programming. Do not put any user programming into it until it has had a battery and system settings performed by a dealer.
Mark
Feb 03, 2009 | Casio Parts Cash Register PC Desktop
E500 won't shut down
It is probably not shutting down because there is a program running that will not shut down. Unnstall programs you no longer use and do a virus scan, often the programs that refuse to shut down are malicious. Holding down the power button for 5 seconds should shut down the computer (it signals the motherboard to power down). As for the black screen, not enough detail for me to say.
Jan 02, 2009 | Compaq Armada E500 Notebook
Power
No beep and no fan can be a dead circuit in the powerpack, however if you have quiet fans like i do (virtually silent) then it maybe the bios or a dead motherboard. I recommend opening the computer case, discharge your body from any static (usually you can do this by touching the metal side of the computer) look for the CMOS or BIOS battery (which looks like an oversized watch battery) take it out and leave it out for 1-3 hours. After that you will have to program you BIOS ( date and time mainly) if it turns on..if not, then more than likely you have a dead motherboard and/or you might want to take it to a qualified computer expert asap.
Jan 01, 2009 | HP Media Center m1170n Photosmart PC...
Camera will not operate with USB cable connected
It's a long shot but it might be a problem with the cable itself, or it could be a problem with your USB ports on your PC, not supplying enough power.
Jul 27, 2007 | Nikon Coolpix 4200 Digital Camera
ASUS Eee 4G Notebook Logo
57 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
