Question about One For All URC-8910 LCD Remote Control
I have 2 DirecTv boxs on my bar each connected to
I have 2 DirecTv boxes on my bar each connected to a different TV. Since the boxes are right next to each other, the remote control changes both boxes at the same time. What can I do (other than move the boxes away from each other) to create different signals for each? Thanks
    Novelist:
  • 123 Answers
Unless there`s a facility on the remote for A/B or Rem1/2 selection, you`re snookered I`m affraid, Back to plan "B". Ian
Posted on Jul 24, 2009
How do i FIX THE COLOR PROBLEMS I HAVE WHILE WATCHING DIRECT TV? Dynex DX-L42-10A 42 in. LCD TV
My guess is that your DirecTV box is outputting in a format your television does not recognize. Some models of the DirecTV box have a button on the front of the box for formats (480,720,1080) and you may be able to press that button until the picture comes in clear.
If there is no button:
1: Try an alternative connection tyoe to the TV from the box (if available, like RCA or coax), then switch the TV to that new input. If you get a clear picture with that connection, then in the settings menu for the receiver there should be format settings where you can select which formats to output. one of the selected formats chosen would be causing the problem. Change or remove one of the formats. (. I.e. if 720 is selected, deselect it.) After that switch back to the original connection and input to test.
or 2: The DirecTV box could be connected to a different TV and in the settings menu for the receiver there should be format settings where you can select which formats to output.
Another unlikely possibility is that the HDMI cable or slot on the TV itself is bad. Try switching the cable or try a different slot in the TV if available.
Jun 03, 2014 | Dynex DX-L42-10A 42 in. LCD TV
White lines on screen after reconnecting Directv D12-100 Box to TV
d12-100 box does not have an hdmi port what it does have is a problem the signal level coming out of the box is to high install a 4 way splitter between the box and the tv line out of the box to the in of the splitter any port out of the splitter to the tv the problem you are having is called ghosting
Feb 22, 2012 | Directv D12-300/100 DTV Receiver
Sony Bravia LCD No picture, no sound I can pull up direct tv guide and all menu's but no pic or sound.
have you check other sources connected to the tv? if you can pull up directv box menu then tv is good. issue with directv box. try to unplug directv box for 1 min
Oct 18, 2010 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Want to run my dtv receiver through new digital converter box.
You will not be able to record local station from a DTV converter connected thru a directv receiver unless there is a a/v input on the directv samsung receiver. Also check the user manual for this receiver if recording from an external source such as a DTV converter box is possible. The answer to seperating the DTV converter box from the directv samsung receiver is possible if your tv has multiple inputs. Try connecting the DTV box to the RF input and the directv samsung box to an a/v input then change inputs using the tv remote. you will need an av cable (yellow/ red/white) for the directv box and a rf jumper cable for the DTV box.
May 17, 2009 | Samsung SIR-S4040R DirecTV DTV Receiver /...
Vizio 42" LCD. Flat screen. Won't display CC on setup screen using HDMI input. Have a Sharp tv on another Directv box and it shows CC via HDMI connection. Problem with receiver or with TV? Costco's "Help"...
CC is a feature of the TV. All TVs are different in features and the Vizio is limited on its features due to cost. To eliminate the directv receiver connected to Vizio TV just swap with the receiver connected to Sharp TV and see if CC is displayed.
Mar 05, 2009 | Vizio VO42L 42 in. LCD TV
Connection problem with Denon 589 and direct tv
If the RCA TV has HDMI input connect as follows:
1. Connect an HDMI cable from the Directv box to an HDMI input on the Denon.
2. Connect an HDMI cable from the HDMI out-put on the Denon to the RCA TV
3. Select input the DirecTV is connected to at the Denon, at TV select HDMI input Denon is connected to TV.
4. On front of denon press the input mode button to select auto
If the RCA TV has Component input (Green,Red,Blue) connect as follows:
5. Connect Component Video and Audio cables from the Directv box to a Component Video and Audio input on the Denon (TV, DBS,VCR).
6. Connect a Component Video cable from the Denon to the RCA TV Component Video input.
7. Select input the DirecTV is connected to at the Denon, at TV select component input Denon is connected to TV.
8. On front of denon press the input mode button to select aut
If the RCA TV has Composite input (Yellow) connect as follows:
9. Connect Composite Video and Audio cables from the Directv box to a Composite Video and Audio input on the Denon (TV, DBS,VCR).
10. Connect a Composite Video cable from the Denon to the RCA TV Compositet Video input.
11. Select input the DirecTV is connected to at the Denon, at TV select composite input Denon is connected to TV.
Feb 08, 2009 | Denon AVR588 Receiver
Remote contol will not work
http://www.directv.com/DTVAPP/global/contentPageIF.jsp?assetId=P4380052#h:1020.989
directv remotes are not guaranteed to work w/ all types of TV's. when programming remote to TV, make sure you are holding down MUTE and SELECT both at the same time for about 4-5 seconds. until it blinks twice at the top of the remote. also the slide switch must be under the "tv" mode on the right hand side. the website i provided is by directv, and has a list of their codes for the brand of tv that you have.
if you are trying to program a remote to a directv box, and none of the codes are working for the directv box, contact directv to have them send you a new remote.
Jan 22, 2009 | Directv D11 DTV Receiver
I have a 27" color flat screen tv by Samsung which I bought from Best Buy in Lakeland, FL 4 yrs ago never had a problem til now. I had a power outage in my home but the tv wasn't on nor was the...
Try to use your directv box with a different A/V connection to the TV and see what happens?
EX. If you have a basic directv box using coaxial cable connection,try to use RCA(yellow,red/white) cable to a RCA input behind the tv.
solutiondoct
Nov 22, 2008 | Televison & Video
How to hook my directv to digital input to lcd tv j32l637
I don't know what flat screen tv you have,but you must be aware of the coaxial input behind the TV.It could be analog input,digital input and OUTPUT!!
Anyway,if you connect your basic directv box to your digital input,it will not serve you any purpose to get HD channels and you don't have the HD directv box.The TV will not display digital channel for you because if you use coaxial input to TV,you should be under either channel 3 or 4 and be sure either channel had been saved under memory.In order to change channels,you will need to change it from your directv box.
JUST LIKE a VCR connect to TV.TV will be under channel 3 or 4,and you will change your channels from the VCR.Don't forget to scan all the channels from the VCR!
solutiondoct
Nov 11, 2008 | Televison & Video
Phillips TVO Directv DVR keeps freezing up...what can I d to correct this?
Try resetting reciever by holding power till it turns off then pull the card. let it reboot and ask for the card, reinsert card and it will reboot again. I problem keeps happening, try to force software updade by, restarting. On the Directv screen (first screen while restarting) press 02468. keep pressing it over and over if you have problems catching it at the right time. It will then go to a blue screen with a load bar. this should solve any conflicts.
Sep 13, 2008 | Philips DIRECTV R15
One For All URC-8910 LCD Remote Control Logo
118 people viewed this question
Top One For All Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
