Question about OCE Office Equipment & Supplies
Oce 7056 copier code 0501 low toner how to reset
Copier keeps flashing code 0501
  • colin_rembra Jul 27, 2009
    have tried this i think need service codes to reset
    thanks will give it a try
  • OCE Master
  • 19,396 Answers
You do not need to reset NVRam to clear a code 0501. 0501 is cleared simply by unplugging the machine from power and restarting, as toner concentration is checked at startup, and every time you do a print.
Try refilling a new toner, unplug power, then try switching on and off several times, until the sensor detects right toner concentration.
If that does not work toner sensor may be faulty.
In that case contact Oce here: Océ Customer Service Center.
Regards.
Posted on Jul 27, 2009
  • 1,555 Answers
Take any stick shake toner a bit inside toner box with it and switch on and off your gopier many times. If this does not help just comment back.
  • Aruna Singh
    Aruna Singh Jul 27, 2009
    Now I've got your service codes but to whom I shall give. Because you didn't bothered to comment back anyways heres your final solution.
    You shall always add toner as soon as the add toner light comes on.
    If the machine runs dry it generates this code.
    Now add some toner and enter service mode go to -3 enter +3 enter and that will force toner supply let it run for 2 min and switch the machine off and on and that should solve the problem.
    If it does not work repeat it 2 or three times worst case is that you will have to remove the dev unit and spread the toner around by hand.
    Good luck
    I know I won't be getting money for this solution.
  • Aruna Singh
    Did you received my final solution.
HI.How can i reset a copier minolta konica bizhub36?
  • Code: 0501
  • Description: Fusing heaters trouble (edge)
    • Detected temperature of the heating roller thermistor (TH2; edge) does not go up a given range of temperature even after a lapse of given period of time at warm up. • The warm-up is not completed even after the set period of time has elapsed after the warm-up is started.
  • Remedy: 1 Check the fusing unit for correct installation (whether it is secured in position). 2 Check the open/close operation of the right door. 3 Check the fusing unit CN30-PRCB CN16, fusing unit-relay CN4AC-DCPU CN2 for proper connection and correct or change as necessary. 4 Change fusing unit 5 Change PRCB 6 Change DCPU
This is from manual, try to reset trouble code:
1-Turn the machine "OFF".
2-Press the "STOP" button on the basic panel.
3-Keep the button pressed and turn the machine "ON".
4-Do not release the button, until the machine warm up.
5-After few seconds Error code will remove and machine will reset.Basic menu will show no error on LCD screen.This means error code has been removed and photocopier machine is ready to use.
Hope it helps
May 29, 2017 | Minolta Office Equipment & Supplies
How to fix errore code 0501 ?
meter count, stop00 stop 01 enter access code
Jul 01, 2014 | Konica Minolta Bizhub 42 Laser Copier /...
C350 malfunction code c-0501
After replacing the fuser unit, if you got a c0501 code you must open the front door where the toner is. On the right side (hinge side) next to the black toner and drum unit there is a plastic pannel/cover. In the lower portion of that pannel there is a hole where a trouble reset switch is loacted. With a flashlight you may be able to see it. You are ment to use a thin screw driver or the like to push the button. You do this while the machein is on and desplaying the code. As soon as you press the button the copier will clear the code and start warming up. Thats it! If you are un certin of the button placement you can take out three screws from the pannel and loosen one screw from the pannel above it and and pull the pannel off the unit. You will see the board and it is the button on the (left), as there are two of them. Tho you only have access to the one thru the cover.
Oct 02, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
0501 error on a Oce' 7055
1)0501 is low toner concentration problem
fill new toner and then off and on main switch many time
2)check toner motor.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 18, 2009 | Office Equipment & Supplies
0501 error with Oce' 7056
Well, error 0501 is low toner concentration problem
fill new toner and then off and on main switch many time, if the problem persists then you need to check the toner motor.
Good Luck!!
Jun 04, 2009 | OCE 3140 Copier
Oce 9400 error code 0501
Good Luck!!
Thanks
Jan 12, 2009 | OCE 3140 Copier
499 people viewed this question
Top OCE Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Are you an OCE Office Equipment and Supply Expert? Answer questions, earn points and help others
