Question about Irons
Handle gets to hot
After about 5 mins useing this iron the handle gets very very hot and is to hot to touchmany thanks keith
  • 6 Answers
You just open it and look for whats wrong in your iron.... or the handle in it is not compatable in the iron soo put some leather on the handle...
Posted on Jul 24, 2009
Tefal pro express steam generator iron. When in use the handle gets really hot. I have to put a cloth around it to use. Help.
try to reduse the temperature setting first, if it still does the same then the thermal switch mechanism is not cutting off the switch at proper temperature
need to replace the thermal switch mechanism
Oct 23, 2017 | Tefal Irons
Handle on my steam iron is too hot to touch
Could be a hidden recall. I'd check MFG website, or email their customer service.
Apr 25, 2015 | Euro-Pro Irons
What can be done about leaking steam?
ensure your iron steam button is not set into perminent steam function. leaving the iron with the point of the iron pointing upwards should reduce steam to the handle. also the iron may need to be descaled to ensure any steam switch funtion is not stuck in an on position.
May 12, 2014 | Euro-Pro Steam Generator EP8001 Iron
Users instructions elitech 2000w steam iron
alas we've had the same problem since day one, just opened it up, must be the boiler unit leaking at the start to emit the steam so the handle gets hot and now the seal is totally gone it will just leak when the water gets too hot
Dec 12, 2011 | Irons
NO STEAM COMING OUT....IRON IS HOT AND WATER IS HOT, BUT PUSH SWITCH FOR STEAM??NOTHING COMES OUT
you need to use a descaler, the holes have become clogged. you can buy this in most hardware stores
Mar 23, 2010 | Rowenta DG-980 Iron
I have an elitech steam generator iron but water does not get hot so no steam (iron works fine)
I have had this iron for 5 months and only been used 4 times. When I turn it on , there is water leaking out of the iron and the handle is too hot to touch after a few minutes
Dec 28, 2009 | Irons
Handle on iron gets too hot to hold onto. Product is an Euro-Pro Ironing Solution. Ironing system includes the iron and ironing board together.
I purchased a silicone heat protector for a pot handle and sewed it together with dental floss around the iron handle
Sep 23, 2008 | Euro-Pro EP1005 Iron
No steam comes out of iron
Hi, there is probably a something broken in the moulded plastic trigger assembly (there is a plastic broken finger that actuates a micro-switch under the rubber handle cover). If you are so inclined, use an orange stick and gently pry up the rubber handle cover on either side from the front to the rear cord end to access, inspect and troubleshoot. I am in SoCal and use the California Electric website to obtain parts or go to the Rowenta home website to locate useful manual information, PDF reader and dealer near you.
Jul 09, 2008 | Rowenta Steam Generator DG050 Iron
Cleaning a self cleaning iron
Fill the Iron with water but keep the water level below the max line. Plug in the iron and set the temp to 6 and stand iron on it's heel and allow to heat for 3 mins. Now unplug the iron and take it to a sink move and Hold the variable steam dial in the CLEAN position. There may be some hissing and spitting while cleaning so be careful. Continue to hold the dial in the clean position until all the water has emptied. If necessary rock side to side and back to front to get all the water out.When finished release the steam dial plug in the iron and heat for about 2 mins to dry out the remaining water and unplug.
May 22, 2007 | Black & Decker D2030 Iron
Irons Logo
148 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
