Question about Protron PLTV3250 32 in. LCD Television
Having prblems connecting DVD player...I have 2
Having prblems connecting DVD player to a Protron 32" TV...I have 2 sets of cables. One with Red, white and yellow connectors, the other with blue, green and red. I have plugged them into the corresponding colored connectors on the TV but no matter what source I choose it says no signal
    Novelist:
  • 123 Answers
The easiest way is to use a scart lead, other than that, Is your TV switched to RGB or Component. I would switch the set between component and RGB. You`ll probably find that this sorts out your problem. If you still have problems, connect the DVD to another set with scarts and double check what the DVD output is set to, either RGB or Conmponent. Ian
Posted on Jul 24, 2009
What s-video cables do i need and what size and what kind of component video cable and what kind of coaxial cable do i need
If your TV has component, then get one component video cable (green/red/blue) and a set of RCA for audio (red/white).
S-Video/Coax is obsolete for dvd players unless you have an old TV.
Oct 29, 2011 | Protron PD-DVR100 DVD Recorder
Trying to connect a PS3 to my hotel room tv. I have 3 color AV cords, and I´m putting each accordingly on yellow, white and red, but can´t seem to see or hear anything on AV source. What am I...
did you set to AV 1, 2, 3 or DVD input, it is depend to where it connected to..whether you connect to the AV input front panel, or rear. if not sure you can connect it to the front panel and sequentially sets the AV source, if still the same. you can connect the cable to the DVD input should be the type of cable TV .. PS 3 is like this:
Connect red, green blue Plug/jack accordingly to each colour on DVD INPUT the TV. set AV Source to DVD.. please Try and if the same result , you have to replace the AV cable of PS3.
Oct 20, 2010 | Protron PLTV-32 Television
I have a protron dvd pds 2315, hooked up to a Insignia LCD HDTV, the sceen is completely pink when I turn on the dvd player. I am using the 3 color coded video cable and a regular white/red cable for...
Turn on your DVD player, go to your set up button on the DVD remote, go to TV and select p-scan. It fixed my problem. My screen was all blue before I did that. Hope it works
May 07, 2010 | Protron PDS-2315 Theater System
I do not know how to connect my DVD to my 42 in
Tries use a RCA cable plug 2 connections ports holes red,white audio out input connected ur DVD player,connnect the other side the RCA to TV audio in input.Use a S-Video cable for video connection to get video.If u have the new version of a DVD player just use a HDMI cable plug one end to the DVD player the other to the TV.
Dec 15, 2009 | Vizio L32 32 in. LCD HDTV
Connecting protron dvd to dish TV
I hope you have at least 2 sets of RCA jacks for (1) the Dish receiver and (2) the DVD player. Run 2 sets of R/W/Y cables to the TV. Done. Or use S-video for a better picture instead of yellow.
If you only have one composite input on TV (possible) then either buy a 2-way or more switch for the composite signal (R=right sound W=left Y=composite or S-video instead of composite) or you can instead pass the signal through the DVD recorder on the RCAs but the DVD will be on whenever anything is on. I assume you do not have a Dish 111 with only RF output but the same could be done for just the wimpy RF, just different switch. So there will be 3 RCA cables from Dish to a recorder and 3 then to the TV. Since you do not have a recorder, then go back to the switch or find another TV input.
Ten years, hum, you may not have had composite/S-video inputs and would have to use RF only--you did not say what TV was.
-Ken
Jul 19, 2009 | Protron PD-800 DVD Player
HOW DO I CONNECT MY DVD THEATER SYSTEM TO MY FLAT PANEL TV?
just either use rca jacks from the dvd to the tv,,u know ..the red,yellow,and white cables,,,,that will do it,,,using the rca jacks ,,make sure to set the the dvd/reciever settings to anolog
May 17, 2009 | Durabrand Televison & Video
Having trouble connecting Protron Model PD-007 to cable tv
are all your connections correct, (is tv on ch 3) dvd output to tv (coaxial or digital in) using tv remote make sure the source is air (or cable/sat ).. put dvd into player press play let load a picture should show (unless you are connecting with RCA wires then the tv would be on ch "video" this would be below ch 2
Jan 26, 2009 | Protron PD-DVR100 DVD Recorder
Zenith SMS1943S made 1995 Need code to switch to dvd status
nleebrooks,
1) check the RCA cable connection from your DVD to TV screen.
make sure that each cable is in the right place (for DVD player yellow cable = video/ red and white cable = audio) (TV screen: yellow cable = video IN /white and red = audio IN
2) from your TV screen locate and check for A/V IN socket. it's either at the back/front or side of the screen.
note: some of TV screen does have 2 A/V inputs
3) Facing the front of your TV screen, locate a button indicating "A/V" or "AV" or a box picture having a forward arrow inside.
note: if you locate the said button and your screen have 2 A/V inputs press the said button until the right input where you connect your dvd cable been set.
cheers,
mark
Jan 17, 2009 | Zenith C13A05LG 13" TV
Can't hook up DVD player
I have a cable box and a Samsung DVD-V5500 player. How do I hook up the 3-part cable to the back of the player?
Jan 12, 2008 | Protron PD-007 DVD Player
Will not work
Hi, you'll want the 3 colored RCA cable to hook this up to an older TV.  Yellow is for Video Out on player and Video In on TV.  Then, on player, correspond the red and white to their holes for Audio Out, and match them with Audio In on your TV.  You may have 2 spots on your TV that are labeled Audio In.  Try them both - the one that works should very close to you Video In line.
Hope that helps!
Dec 07, 2007 | Protron PD-800 DVD Player
Protron PLTV3250 32 in. LCD Television Logo
107 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
