Question about Nikon D60 Digital Camera
I have had the D60 for over 1 year with no problems....I cannot not re-insert the 4GB chip. After pressing it into the slot it springs back.
  • 724 Answers
SD card have a small notch near the beveled edge. This I believe is the part of the stick that will accept the latch. Look inside the empty card slot. In the Card slot see if there is something binding this latch. Paper stone tree bark etc... If there is see if you can dislodge it catefully.Take a can of old fashion tuner cleaner/lub spray solvent NOT CARB CLEANER. Radio Shack will know. With a can of compressed air to clean a keyboad. Give it a spritz or two...See if what ever is lodged moves out or if the solvent lub helps. If that does not work it needs to be inspected closer to see if the latch is broken or a screw inside is loose...Not the one behind the viewer lense either...
Posted on Jul 24, 2009
How to remove/load sd card stuck in Huawai M860
The SD memory card slot is spring loaded, to insert the memory card insert the card into the SD memory slot with the SD card contacts going in first and gently push it in until it locks in place. NOTE if the SD card does not slide into the slot easily then the SD memory card has been inserted back to front, turn the SD card around and insert it again.
To remove an installed SD memory card, press the SD memory card and it will pop out slightly then you can then pull out the SD memory card.
Mar 12, 2013 | Cameras
I can't close tower cover
When your computer appears to slow down, one way to help increase its speed is by adding memory. You can easily purchase memory chips from various online sources or if you have a Dell Dimension and want to stick with Dell products, you can purchase additional memory chips from Dell itself. It is not difficult for a non computer person to add memory to a Dell Dimension, although sometimes, it is cheaper to purchase a new computer and then install additional memory.
Shut down your computer, turn the computer off and unplug it. Open your computer case. There will be two thumbscrews on the back of the Dell Dimension computer case that will release the cover. The side of the computer case will then slide backward and lift away from the rest of the box. Locate the slots for RAM. These are short off-white slots that are near the power supply on the motherboard. They will be slightly longer than the RAM you are about to add. There will be at least one RAM chip already in place in one of the slots. Place your new RAM chip into a blank slot gently. It does not matter which slot you use; any will work. When you press the RAM into place, be sure the notch on the chip lines up with the slot. There will be a guide on the slot to ensure that you do not insert the chip backwards. Press down on the RAM chip until it locks into place. There are two guides on the side of the slot that will snap into place on the sides of the chip to ensure the chip does not fall out. It will take a bit of pressure to make the chip snap into place, so press straight down into the motherboard to get the chip in place. Close the computer case, put the thumbscrews back where they belong and start up the computer. Your Dell Dimension will sense the new RAM, which will be available to the operating system when the computer starts up. Hope this helps.
Dec 30, 2012 | Dell Dimension 4600 PC Desktop
How do you lock the bits in?
Insert sds bit into chuck with slots/slot matching slot in chuck while pulling back on the spring loaded nose. If the bit does not catch try turning/rotating bit to lock. When you release the nose, a pin will drop into the indention on bit and prevent it from falling out during use. Sometimes this pin will break or wear-out thus the bit will not catch. Before you insert the bit, look into chuck for retaining pin. Pulling back on the spring loaded chuck releases pressure on the pin and allows insertion of bit. Parts are available at www.toolpartsdirect.com
Oct 12, 2010 | Hitachi H45MR 12lb. SDS Max Chipping...
I inserted my new Mexico chip into my Garmin GPS the only way it appeared to want to go in(there were no istructions other than "insert" that came with it). The chip is slightly crooked and I cannot get a...
Normally, the chip should slide into the slot and you'll feel a slight click. If you want to remove it, you gently press the chip in and it will 'unclick' and slide back out.
Nov 22, 2009 | Garmin Nuvi 255 GPS Receiver
Whenever I insert my pen drive into my pc,it restarts computer. what is the problem ?
if this is only happening on 1 usb port, there is a short in that port that is causing you PC to shut down. Your motherboard BIOS is probably set to reboot on power loss which means it will boot right back up if it shorts out.
If it happens on every USB port then your pen drive is faulty and I would refrain from inserting it anymore before you damage your hardware.
If the pen drive works on someone elses computer, then it sounds like the SOUTHBRIDGE chip (chip on motherboard that controls USB, PCI slots, firewire ports, etc) is going bad or is faulty.
Oct 01, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Beeping sound at boot up, screen showing auto save and not booting up
remove the memory chip, clean it, insert it back in the slot again. "be carefull" dont wrongly place the memory chip else it will burn, there r two clips on each end of the slot, and in the middle a separator. hope this will help. if u have a graphic card in it remove it, clean it, and insert it back on the slot. if doesnt work then replace the memory chip or graphic card. now if u have two or three memory chips in the slot, then test one by one. remove all, then place one, then turn on pc see if the display come, by this way u will know if the chips are good or not, then try the others.
Aug 09, 2009 | Dell Inspiron 530s Desktop Computer...
I have a memory Stick PRO Duo 4GB
YEAH, YOU MAY NEED A MEMORY CARD READER to read your memory stick. because some compters have not all type of card slots. the card reader will solve your problem.
Feb 10, 2009 | Sony 4GB Memory Stick PRO Duo Memory Card
I put two 2GB RAM in my memory slot and only one is registering, so instead of 4GB RAM, I have 2GB. Why is this and what can I do to get the full 4GB?
ok i checked on your model and it says 2gb RAM max and so it is probably seeing both chips but only seeing 1gb each since that is what the slot is made for..
But to be totally sure you might wqant to check the bios and see what it says since some bios will sometimes give more details as to how many chips are installed.
or take out one chip and turn the computer back on and see if it shows 1gb or 2gb if it shows 1gb with one 2gb chip then you will know that the slot wont read more than 1gb.
Dec 04, 2008 | Toshiba Satellite A100-S8111TD Notebook
How do you remove the driver side airbag for 2000 VW Cabrio?
You need an airbag removal/release tool. Buy it on ebay $15-17. Worth of buying it (dealer charges $280) to take off and install it back. Do not use any screwdrivers or similar tools. With a screw driver you will spend precious hours without any result. With the tool only 5 sec. There are two slots on the back of the steering wheel. Disconnect the battery (you will loose your radio code though) While the slot is on the top insert the tool in the slot tillted down (handle up), using your imagination or best tacktile feelings find the wire spring with the grove of the tool and change the angle of the tool by pressing down on the handle, this will release the spring and one side of the bag will pop out. Turn the wheel 180 degrees make sure the other slot is on top now, repeat the procedure with the other spring. The depth of the tool insertion varies, try to find the deepest possible insertion first and back out just a little bit until you feel that you caught that wire. That wire itself is the metal slot. By inserting the tool in the back of the airbag you can't hurt anything there. Everything is designed to withstand an unexperienced intruders. When the other side of the airbag pops out disconnect the airbag: have someone who knows how to disconnect the airbag plugs.
Jul 18, 2008 | 2000 Volkswagen Cabrio
Sidekick 2
Sorry, the sidekick II doesn't have a battery that can be pulled out. You need to pull back the bumper on one side to access the sim card slot.
    1. Follow these instructions to remove your operator-supplied SIM card from your device:
    2. Turn off your device by pressing the power on/off key.
    • Expose the SIM card slot by peeling back the bumper from the top-left edge of the device: t02005-2.jpg
    • Press down on the silver "catch" and the SIM card will spring out of its slot. Remove the SIM card carefully. (Always handle your SIM card carefully since the card and gold contacts can be easily damaged by scratches or bends. Be sure to keep SIM cards out of reach of small children.)
    1. Now insert the SIM card containing the contacts you want to import:
    2. Insert the SIM card into its slot with the gold contacts facing up and the cut corner facing out. t02005-1.jpg
    • When you release the SIM card make sure it is locked into position behind the catch so it doesn't spring out.
    • Replace the bumper and turn on your device.
    GrinningFool
  • www.repairmysidekick.org
  • May 09, 2008 | T-Mobile Sidekick II
    Nikon D60 Digital Camera Logo
    303 people viewed this question
    Top Nikon Cameras Experts
    Steve
    Jeff Marcus
    Are you a Nikon Camera Expert? Answer questions, earn points and help others
