Question about Dishwashers
The dishwasher is leaking from the inside front left corner. it ahs two small covers over this valve. underneath it has two electrical wires. when you turn it on, it leaks from that valve to the floor.
  • 2 more comments
  • eelt5 Jul 24, 2009
    the dishwasher is an amana master clean 5000
    it is an amana master clean 5000
    i have an amana master clean 5000 dishwasher that is leaking from the front left valve when it is running
    i keep asking you, but you haven't given me any other answers
  • 6,784 Answers
HI. this is a inlet assembly issue. The water inlet valve can be identified by the water hoses connected to it. One hose will lead from the valve to the pump/motor assembly in the center of the dishwasher. Check that the hoses are securely connected to the valve and that there are no kinks in the hoses which could restrict water flow. There are two wires (four, if it has two solenoids) connected to the water inlet valve. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
Use a continuity tester or multimeter to test for continuity. Set the multimeter to the ohms setting X1. Touch one probe to each terminal. A reading of infinity indicates a bad solenoid that must be replaced. Different brands and models will have various measurements, but the valve should show some resistance if it is functioning properly. If your valve has two solenoids, test the second one in the same way as the first.
If the solenoid is working properly, but water leaks through the valve even when the dishwasher is off, then the valve itself is the problem. Debris may be preventing the valve from closing. If the valve cannot be cleaned, it will have to be replaced. The valve can also fail mechanically. So even if it passes the electrical test, it may still require replacement. If you have ruled out all other possibilities, go ahead and replace the valve.
***(((NOTE-- It i possible that the valve housing has cracked as well. make sure that the hoses are connected properly during your testing. If there are no hose issues, this will be a defective va;ve assembly)))
Posted on Jul 24, 2009
  • 3,037 Answers
Sounds like you just need to replace the valve or if it is leaking from the connection, then some plumbers tape from a hardware store. Is it the inlet or drain valve? Can you give me the make and mode number of the unit? You can order a new valve from www.repairclinic.com if it is a common brand. Let me know how this turns out.
Benjamin
How does water actually get into the tub of a GE Model GSD2200G00WW dishwasher and to clean the overflow area how do you get it out I have cover off, down to rubber, got some stuff out, ? filter
First--Water enters the dishwasher through the water inlet valve which is the plastic electric valve that the house plumbing attaches to. On GE's its usually under the left front corner once you remove the small access panel. Power is applied by the the timer during the fill cycle. Second-- there is no other filter down in the area you are trying to clean. To remove that rubber boot/sump area you would need to un-install the dishwasher and remove the motor pump assembly from underneath. Here are a couple of things to check for poor cleaning. 1---internal water level---should be about 1/2 inch at door front edge. If not, that inlet valve may be partially blocked and need replaced. 2---water temp needs to be at least 120 minimum. If not hot enough it will not dissolve soap. 3--- look closely at all the little holes in the spray arms. Pay close attention to the end holes that are used to spray out water like a jet engine and spin the arms. Any blocked holes need to be cleaned with something like a toothpick. 4--- check dishwasher at cycle end. If tub has excessive amount of water left inside you may have a blocked drain hose from dishwasher to house drain system. Remove and clean. A small amount of water in sump area is normal but none u near door.
May 02, 2015 | GE Dishwashers
Lights come on and it beeps when u select cycle but it wont run
Do you hear the water going in? If not, the float switch is probably stuck . From the inside you can see the cover usually on the front left corner on the floor of the dishwasher by the bottom rack. Remove the screw and float cover. The you see a small piece sticking up, gently push on it many time to try to free and clean it. This is actually pushing the float switch. Clean the plastic covers of soap gunk. Reassemble and try. The switch can be accessed from underneath if you want to replace it. Also a clogged or defective water valve will not allow water to enter.
Mar 24, 2014 | GE Dishwashers
I have had water leaking from underneath my dishwasher and have found that on filling, water overflows top of the water inlet unit
My Miele 828 dishwasher started to leak at the front left corner. The leak became worse. I tipped the machine on its side and removed the rubber moulding connecting the base of the drum to the pump. I cleaned it out and refitted it finding two small coins inside. The leak persisted. I took off the top of the machine by unscrewing the two screws on either side and pushing the lid backwards. I switched the machine on and, with a torch could see that the detergent dispenser had detached from the delivery pipe under it. Using advice elsewhere on Fixya I undid the three bolts around the door and the three screws around the detergent dispenser; one is deeply recessed and easily missed. Than I unclipped the drain pipe behind the little door at the bottom left hand corner at the front. The front then hinges out from the left with hinges at the right side making the leaking connection easily accessible. Make sure you get the rubber flange well up the plastic tube as there is no flange on the tube to secure it. A possible design fault but the unit has functioned for ten years before the connection failed.
Sep 24, 2013 | Dishwashers
LG front load washer is leaking underneath the front left corner, the display code is FE.
Why don't you simply find out what the FE code is alluding to? Go to web site or do a google search and then you can check for the issue further.
Sep 17, 2017 | LG WM2487H Front Load Washer
Cleaning valve
hi friend,
Unplug your dishwasher for safety reasons, and double check that it is no longer connected to its power source. Depending on your dishwasher, you may have to turn off its power from the circuit breaker or remove a fuse. Shut off your water valve and turn off the water supply to your machine. You may have a hose that runs from the faucet.
  • Step 2 Find the panel underneath your dishwasher, often referred to as the kick plate panel. Some panels need to be unscrewed from their position; others fold down because they are hinged to the machine.
  • Step 3 Locate your inlet valve. In most machines, it is located in the left or right corner of the panel and should be visible to you. Your inlet water valve will have hoses connected to it--one that takes water to the machine and another that takes water away. This is a good time to check that your hoses are in good condition, not corroded or kinked. Take the hoses off the dishwasher intake valve. You should probably place a container underneath before disconnecting in case there is water left in the hoses.
  • Step 4 Disconnect the wires from the inlet valve. Write down where the wires go so there are no problems reconnecting later. Not using the wires but the connectors instead, disconnect the wires. You may have to use pliers to do this.
  • Step 5 Unscrew the inlet valve, remove it, and save the screws. Now, place your new water inlet valve where the old one used to be, and screw it in place with the old screws.
  • Step 6 Replace the hoses and wires. You may want to turn on the water, and check if the hoses are secured in place and not leaking. Put panel back in place and turn on the power to the dishwasher.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
    • It is most important to be safe. Be sure to disconnect both the hoses and the electrical power to your dishwasher before you begin work.
    hope this helps u
    please rate me.....................
    thank u for using fixya
    regards
    sivaranjini
    Nov 26, 2009 | Maytag Dishwashers
    Leaking from underneath
    make sure valve cover is very tight and o-ring is in place inside the valve.
    ensure rubber seal did not fall out of fill hose end (if you removed it )
    ensure hose clamps are tight.
    ensure the curved hose from the fill valve to the booster is not brittle and cracked.
    thats it!
    Aug 20, 2009 | Hobart LXiGC Dishwasher
    When washing dishes, the dishwasher starts leaking water through the base of the door.
    The leaking could be caused by a couple of things. First check to see that the lower door edge and cabinet seals are intact and haven't been moved out of position, etc. (some DW's only have one seal, others have two) - can't be exact without model numbers, etc.)
    Also check the water level switch, normally in the left front corner inside the wash tub. It is usually under a cover that is either held in place by a plastic clip or a small 1/4" screw holding it to the tub bottom.
    Remove the cover and clean the float underneath, it's possible that it's gotten gunked up over the years and is sticking or has a buildup inside it that is causing it to not float properly, hence it'll allow for overfilling of the wash tub.
    Put it back together and run a short rinse cycle to see if that has resolved the leaking. If not, it could be the float switch has moved out of position, but that is not a typical problem unless the DW has been removed recently and got damaged, etc.
    Hope this helps resolve your problem! Best Regards!
    Jul 31, 2009 | Kenmore Dishwashers
    Dishwasher tub will not fill with water
    If there's no water entering your dishwasher, check these:
    Water-inlet valve
    Float switch
    Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
    Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
    May 24, 2009 | Dishwashers
    Leaking water from front of door
    I replaced the seal part # 154576501. The notch is on the right facing the dishwasher. Just pull it out and insert the new one.
    I've fought this problem for over a year, thinking it was an adjustment. I am now running it through the third cycle and I am positive it fixed my leak. Also, while you have the cover off, check and trim the tie-wrap around the wire loom. Mine was interfereing with the seal, but the seal was also slightly distorted allowing the splash to come underneath.
    BnoGno
    Nov 16, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
    Maytag PDB3600AWE leaking
    Here is a tip that I wrote about dishwashers and them leaking.
    Leaking Dishwasher
    heatman101
    Jan 11, 2008 | Maytag PDB3600A Built-in Dishwasher
    Dishwashers Logo
    41 people viewed this question
    Top Dishwashers Experts
