Back to:
Tags:
Bridges
Generic problem for all Bridges
Internet
posted by Avinash81 on Nov 21, 2007
I am sharing internet connection with ICS (Internet Connection Sharing) Technology in my workgroup network and using XP-SP2 as ICS server.
Please tell me how i know about how many user's are using internet in my network at any specific time?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Nov 22, 2007
Not Rated (0)
daemonguy
Rank:Wiz Wiz
Rating: 81%, 116 votes
Hi ,
Instead of using a native solution for more controlled internet sharing you can download and install "Sygate" Internet connection sharing software .
Good Luck
Comment by daemonguy, posted on Nov 22, 2007
You are familier with linux then you can install a open source linux box with squid proxy and iptable combination
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Internet:
I don't want to Accept this solution
Solution #2
Not Rated (0)
DGolfer
Rank:Wiz Wiz
Rating: 84%, 78 votes
There is no utility that comes natively with XP to monitor traffic on an ICS connected LAN. I assume you are not directly connected to the ICS computer, and are running through a Switch or Hub? And you do not have access to this to see how many lines are connected?
If this is the case, you can download and install a packet sniffer and place it within the LAN in front of the ICS computer. It will 'see' all packets traveling across the wire, and report the MAC addresses and IP Addresses to which they are bound. Since every NIC has a unique MAC address (and IP Address), you can see how many computers (NICs) there are in the LAN, and connected to the wire.
http://en.wikipedia.org/wiki/Packet_sniffer
Ethereal:
http://www.ethereal.com/download.html
You can also use a utility like LanGuard Analyzer to search for all computers on the LAN:
http://www.gfi.com/lannetscan/
The last time I checked the trial version is fully operational for 30 days.. I use it in my Corporate LAN to monitor all 1000 computers in my domain.
One other thing to keep in mind, since ICS uses the Class C subnet (this cannot be changed), it has a limit of 254 clients that can be attached.. just an FYI..
Thank You!
Can you Help with these Bridges problems?
D-Link DI-604 4-Port Cable/DSL Router...
i have hocked ur wired router up and im getting internet...
befor 3 years i bought DI-604 , D-Link ver.2.06W, it was...
When I installed my router and tried updating my anti...
I keep getting errors when trying to set up Back to my Mac...
Bridges
Hi I recently installed a CCTV DVR for my dads business....
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
