Question about Verizon Communications enV2 Cellular Phone
How can i get the memory chip(?) out of my lg phone model # VX9100 , mine stopped turning on, they want to replace it and have me send mine back to verizon. i cannot get my personal information off the phone and want to take out whatever holds that info before i send it back
My phone no longer vibrates.
Try this.
Disable vibration.
Turn phone off.
Remove battery.
Wait at least 30 minutes.
Put battery back on the phone and turn vibration on.
Good luck
Nov 17, 2014 | LG enV2 EnV-2 VX-9100 VX9100 Premium Pink...
Verizon wireless lg env2 vx9100 make put a sim
Verizon phones (unless global which the env2 isn't) do not support sim cards. If you are talking about a micro sd card. It goes in under the cover on the right side for the phone. Hope this helped
May 23, 2012 | LG enV2 EnV-2 VX-9100 VX9100 Premium Pink...
LG VX9100 Driver Download
please follow the link for your driver requirement which is given in the website down.
www.lg-phones.org/lg-env2-vx9100-drivers-download.html
Aug 23, 2009 | LG VX8300 Cellular Phone
I am not able to set my ringtone as a message tone
If your LG is anything like mine (VX9100) then the setting for the message ring won't be under Ringtones, it will be under Alert Sounds
Aug 12, 2009 | LG Vu CU920 Cellular Phone
Problems with my lg env2
Unfortunately the OK button and the bottom row of keys are a design flaw. Mine has stopped working from repeatedly being sat on. When you press the OK button in various directions, sometimes it will come back to life. The best thing I can suggest (if repair is not an option) is to mess with the OK button till it springs back to live, and then quick as you can press menu, keyguard settings, and turn that off, this will allow you to still use the front of your phone when the OK button goes out again (like I said, not permanent.)
Now, about that memory card. if you haven't formatted it for Verizon, you may want to do that. to do so go Settings>Memory(9)>Card Memory, hit the soft key for Options and format. Keep in mind if you have files on there that you do not have backed up they will be wiped clean. After its been formated, you need to take it out, put it back in, and restart the phone. You should have access to your card memory then. ^^
Aug 02, 2009 | LG enV2 EnV-2 VX-9100 VX9100 Premium Pink...
LG shine KF600 not reading my meomory card why is tha
you should try taking it out, turning your phone off, then putting it back in and turning your phone back on. if that doesn't work, then maybe you dropped your phone and the memory card got damaged.
Oct 06, 2008 | LG Shine KE970 Cellular Phone
Verizon Communications enV2 Cellular Phone Logo
158 people viewed this question
Top Verizon Communications Cell Phones Experts
Computer Repairing
Computer Repairing
Bee Santiago
Are you a Verizon Communications Cell Phone Expert? Answer questions, earn points and help others
