Question about Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
HDMI Inputs don't work with At&t Uverse Cable box
I bought Sony Bravia about 6 months ago, at the time I had Cox Cable and connected to HDMI with no problem A couple months later I switched to AT&T Uverse cable. TV worked fine on HDMI for about a month, then when I turn on the TV I get no picture and no sound until I change the TV input to some other device, then back to HDMI 1 where the cable box is hooked up. It always works then. AT&T replaced the cable box but the problem still exists. I tried using all of the HDMI connectors available on the tv to connect to the cable box, all exhibited the same problem.
Sony bravia no tv signal but video okay
Check and replace its tuner. Contact any service technician. This is not a user repairable work. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Feb 16, 2014 | Televison & Video
HDMI INPUTS DON'T WORK
It sounds like your set needs servicing. Are the other inputs working? HDMI port failures are indicative of a problem with the main board.
Sep 01, 2012 | Sony BRAVIA KDL-52S5100 52 in. LCD HDTV
I have an HDMI cord hooked to my Bravia it is set on video 6 the cable box is powered on and funtiona and the HDMI cord is good. I am getting no sound and no picture is there any way to test the HDMI port...
if you have video im assuming you do if you can see its on video 6 look at hdmi port and make shure its video 6 if your not shure leave it hooked up the way you have it turn on cable box and go thru all inputs example put it on video 1 wait for 60 seconds if nothing happens go to video 2 and so on and so on be shure to wait at least 60 seconds before you change to another input good luck
Feb 03, 2010 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
40" Sony Bravia has intermittent audio failure.
I have a KDL-46VL130 with the same problems. Audio on the HDMI connection turns on and off intermittently when I have it connected with my ATT Uverse rcvr. I check w/ Sony online support and they led through the standard troubleshooting process ... which I knew going in would not fix the problem. Ultimately they told me to try a new HDMI cable first, or try a different video source for the HDMI, other than my ATT U-Verse reciever and see if the problem persists. Having seen other articles on this issue, i am almost certain that is not going to fix the problem... and to think that I paid $2000 for this thing.
Dec 13, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
I have a brand new LG 50 plasma and a Bravia Sony surround sound system as well as a Cox Cable HD DVR box. I currently have it connected as such: HDMI from Bravia Sony System direct into TV HDMI from Cable...
you may have to set the input value on the bravia for optical on the input from the cable box. sometimes there is more than one way for a particular input to receive an audio signal, you may have rca(red and white), a black or orange rca type for digital, and then the optical. i would suspect you have to tell the bravia how the sound is inputed into the bravia. also , just a thought.... on the cable box there should be a volume control on the front of the box........ make sure the cable box volume is ALL the way up (it is the preamp volume).
Dec 08, 2009 | LG 50PX5D 50 in. Plasma HDTV
HDMI stopped working with computer
HDMI connectors are very bad soldered inside the set,not easy to resolder for an amateur ( if you are an amateur offcourse )
Other option is the HDMI cable itself.
Jul 23, 2009 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Cannot get a connection with HDMI input
When the tv won't scroll to the HDMI inputs, it means that the tv does not detect a signal on those inputs. This either means the tv has an issue and can't receive an HDMI signal(very unlikely) or there is no signal being sent from the source(converter box) The first thing I would do is unplug all output connections from the box except for the HDMI output and see if this gets rid of your problem. If not, I would be more inclined to think you have a problem with your converter box than with your TV. You could also try using the HDMI ouput of a DVD player if you have one.
Jan 14, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Wiring problems
Not certain if HDMI can be used in a setup like this. I'd try it from the home theater (HT) to the TV, and other wiring for the other components.
For video:
All of these should have component connections (Y/Pr/Pb). You'll only need the video cables for each device:
  • Video out from cable, HT, and combo player.
  • Video in to TV. Your choice of inputs.
For audio:
Hopefully, the two output devices (the combo player and the cable box) have digital audio (fiber optic, or RCA coaxial). Otherwise, you'll only get stereo sound. VHS is stereo only anyway.
  • Audio out from cable box and combo player.
  • Audio in to HT.
The TV won't have anything to do with audio in this setup. Alternatively, you could try hooking up all inputs to the TV, and connecting audio out from the TV to the HT. Works best if this connection is digital, for surround.
Jan 01, 2009 | Sony BRAVIA DAVHDX275 Theater System
No Digital Signal to TV
make sure you have Tv on that particular HDMI input .I believe video 6 or 7 .if you do check menu make sure that input is not blocked. or you might want to try the component outputs of cable box and connect that to a component input on tv to see if that is working,,i have seen these tv HDMI input board bad..lets hoe this is not the case..
Dec 16, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV Logo
1,427 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
