Good day, my tv picture looks like a cushion. what could be the problem
It is AN OLD MODEL TV, TEDELEX MODEL 9628
    Top Expert:
  • Televison & ... Master
  • 74,666 Answers
MikeNJ1964
  • 398 Answers
SOURCE: RCA Model # 20F510TD TV/DVD
What makes you think the picture tube is bad? What exactly are the symptoms you see? The RCA 20 inch picture tube is a good quality long lasting tube and I doubt I have ever seen a bad one.
Posted on Jul 05, 2007
  • 8 Answers
SOURCE: Westinghouse 32" LCD TV
It seems your pixelsare burning out. contact the NY Service Center for Westinghouse. web is www.asnyonine.com
Posted on Jun 30, 2008
marked
  • 6487 Answers
SOURCE: PRIMA HT2778P pin-cushioned blue screen - service menu reset needed
Try this one:
1. Unplug your power cord from the box (NOT THE
WALL!)
2. Wait 3-5 min... No more than 5 MIN (very important)
3. Hold down the power and select button at the same time and don’t let go.
4. Have someone plug the power back in… and keep holding the power and select button.
5. Don’t let go until it gets to 0 (it's about 5 min)
6. Once it gets to 0 then it will stop counting down, that when you let go!!
7. Don’t touch anything,
8. The screen will reset and it will go blank. nad that's it
Hope that helps....
Posted on Jul 10, 2008
racer7x
  • 42 Answers
SOURCE: hitachi projection tv.7years old.can i clean or change the bulb,w
Remove the front screen
Carefully Remove it
Pull the bottom off
Then remove the screws on the bottom of the screen
when you have them off lift the screen assembly up
be careful of the wire going to the panel
you can move the screen to the side and gain acces with out unplugging the wire but again be careful
clean the mirror and the projection bulbs
with glass cleaner and spray only on to the rag not the mirror or projection bulbs
Put it all back together and your picture should be bright as before
Posted on Feb 10, 2009
  • 108 Answers
SOURCE: panasonic projection tv model # pt56lcz7 no picture, bulb out?
This unit does not have the usual lamp assembly that most do. On this unit the whole light engine has to be removed to replace the lamp assembly. Part number is LFS4000PA1 and cost is $1,351.95 @ www.partstore.com.
Posted on Sep 01, 2009
I have tedelex EC2159 remote codes it should be 3 digits not 4
Pilot remote control codes for TEDELEX:
30 results. Displaying page 1 of 1
NR Brand Model Type Pilot Supertel* Easytel Unitel 1 TEDELEX 1452 R/C P1679Y 2 TEDELEX 1452 TV P1679Y 3 TEDELEX 1455 TV P1655Y 4 TEDELEX 1458 TV P1655Y 5 TEDELEX 1459 TV P1655Y 6 TEDELEX 2052 TV P1679Y 7 TEDELEX 2056 TV P1690N 8 TEDELEX 2092 TV P1679Y 9 TEDELEX 2096 TV P1690N 10 TEDELEX 2098 TV P1655Y 11 TEDELEX 2099 TV P1655Y 12 TEDELEX 2122 TV P1545Y 13 TEDELEX 9227 TV P1690N 14 TEDELEX 9422 TV P1655Y 15 TEDELEX 9427 TV P1655Y 16 TEDELEX 9628 TV P4263 17 TEDELEX EC 2528 TV P4190N 18 TEDELEX EC 2909 TV P4264 19 TEDELEX G 148 TV P4263 20 TEDELEX G 149 TV P4263 21 TEDELEX G 202 TV P4263 22 TEDELEX G 209 TV P4263 23 TEDELEX N 9034 SA VCR P1814 24 TEDELEX RC 94 R/C P1655Y 25 TEDELEX RC 97-PI TV P4263 26 TEDELEX RC 98A R/C P4190N 27 TEDELEX RC 98D TV P4264 28 TEDELEX SOME MODELS VCR 29 TEDELEX SOME MODELS VCR P4205N 30 TEDELEX STUDIO 3000 G TV P1690N
* Note: Supertel, Minitel and PRO-TEL universal remote controls will share the same code.
Feb 26, 2017 | Televison & Video
I have an old Tedelex tv and want to install a diffrent remote on it. the tv work by by pressing buttons per hand. I am in hospatal and can'nt stand up
I usually get remotes from a cheap Chinese shop. They have codes for most TV makes. Incidentally, they also do remotes for aircon units. If no local shops, you'll get one on ebay.
Feb 08, 2015 | Televison & Video
Cant find where the antenna cable must plug into Tedelex Flat view TV Model EC-PD5000
When looking at the back of the TV it is towards the bottom furthest right of all the connections!
Nov 16, 2014 | Televison & Video
I WANT USER MANUAL OF SONY TRINTRON KV-XF34M65
If I am not mistaken this sounds like an older model tv and your best bet is to google the word tedelex and go into the Tedelex - South Africa title and contact them they should have a copy for you.
Apr 14, 2013 | Sony FD Trinitron WEGA KV-32FS120 32" TV
The background color on the tv is starting to bow in different directions. the original picture looks good but it looks like there is a shadow below it that is a different clor and wavy.
Hi, it's look like you have a convergence module defect and pin cushion problem;/after replaced the module the tv set will need to be adlust.....
that as to be done by a tech
hope that gives you an idea
have a nice day...
Apr 13, 2010 | Hitachi 51F500 51" Rear Projection...
Pin cushion falt
Circuit diagrams are available online from 5-20 dollars. I doubt it will do you much good, as you will need to be an expert at tv repair in order to read the diagram, and trace the problem. It sounds to me like a bad capacitor near the horizontal deflection circuits, or a resistor near the pincushion adjustment could have blown. If you really want to learn how to fix your tv, you should visit some learning websites that explain the different areas of a tv circuit board and their functions.
Dec 06, 2008 | Philips Magnavox 27MS343S 27" TV
Sony kv-32hv600 picture problems
Problem 1. Color patches at lower corners. These are caused by magnetic sources close to the TV. Do you have any Speakers close to the sides of the TV? Are they Magnetically sheilded? No? Move them away from the TV. Problem should then resolve itself in a couple of days. Problem2. Screen Slumping. Most likely a problem with the Pin cushion correction ckts. Get a good technician to have look. cost should not be much. Under 100$ plus Technician fees.
Aug 18, 2006 | Sony FD Trinitron KV-32HV600 32" TV
Televison & Video Logo
1,301 people viewed this question
Top Televison & Video Experts
Electro Med Services...
