Question about Air Tools & Compressors
Sprayer leaves lines. Adjusted pressure, canged
Sprayer leaves lines. Adjusted pressure, canged filters and tip. Graco 490 new in feb 09 worked perfect everyday use
  • 2,527 Answers
The lower ball is stuck free it
DO NOT PUT LAQUIOR THINNER INTO YOUR PUMP
Posted on Mar 26, 2015
    Scholar:
    New Friend:
  • 49 Answers
The Tip is blown out that's where the lines come from-
Need to buy a new tip-
HINT- After I clean out any Airless tip I like to put them in a new metal Quart can filled about half way with Lacquer Thinner-
I do that with all my everyday Reversa Tips and flat tips.
Perry Tradesman
Posted on Mar 16, 2015
  • 154 Answers
Needs good cleaning and air mix adj
Posted on Aug 03, 2009
Line starts wide then gets norrow.does good spraying thin products . Ian using a 319 tip. Could the paint be to thick for a 3.19
This sounds like a loss of pressure after you first pull the trigger, if that's it, your filter is likely to be full; its the tall stainless steel cylinder on the right side of the sprayer when you look forward. The filter comes out with the big knob on the top. When you have cleaned it out, or replaced it with a new one, when you screw it back, it only has to be hand tight
May 24, 2015 | GRACO INC LineLazer 3400 Airless Line...
Graco manual
May be clogged. Push out roll pin with a pin punch and remove assembly.Check plastic pices for broken parts ( black). Put pump in water make sure it's delivering material with valve out. Ports on valve are not that big and do clog.
Oct 24, 2013 | GRACO INC Ultra Max II 1095 Premium...
Trying to prime my 395 air assisted finish pro and I have fluid coming out of air holes in gun
I had the same problem. turned out I was using the rubber gasket on the tip saddle instead of the hard plastic one.
Aug 30, 2013 | GRACO INC FinishPro 395 Air-Assisted...
My sprayer is sputtering I think it's a problem with suction because if I apply a little pressure with my hand on the bottle it sprays. Also I have completly cleaned it so there is no residual
There is nosuction on this type of unit it blows air into the pot andforcesitout through the tip have a lookdown the air hose make sure it is not bblocked as low pressure will cause sspitting
Feb 17, 2013 | GRACO INC 2900 Spray Station HV2900USG
Graco Magnum XR5 electric airless sprayer won't start
It could be something as simple as you have the pressure turned down so low it won't appear to be working try to turn the pressure up and see what happens.
The worst thing could be you did not clean the sprayer out properly and now the paint has dried and the shaft is frozen to the packings and the other internal parts of the your sprayer.
Jun 27, 2012 | GRACO INC Magnum XR5 232740 Paint Sprayer
Graco magnum paint sprayer won't prime
Airless won't prime- I always start trouble shooting an Airless that won't build/hold pressure look at sump hose inlet filter (the hose that goes into the paint if its got paint debris on it clean off filter and pour the paint thru a strainer bag into a clean 5 gal bucket-also remove the filter housing on the spayer and clean and flush and replace filter and housing- the shaft or the metal sleave has two ball bearings called "check balls" that maybe stuck turn on sprayer and put a piece of wood on shaft and give it a few good taps this will knock the check balls loose if after all this fails then you need to have new packings put in becuase the old ones are worn this is pretty easy to see because the rod the compresses the paint will have signs of paint on it indicating that the packings are worn.. Note keep rod and other moving parts oiled ith graco throat seal and finally Graco sprayers with the X on them are there (Graco) home owner line of sprayers that sell at home depot they are rated for only a certain amount of Gal per year keep it in good condition and cleaned store with coro-check inside of the pump when you are done using it.....
May 27, 2012 | GRACO INC 232745 Magnum XR-7 3/4-HP...
Graco ultimate max11 490 paint sprayer does anyone know how it works because i have no instructions
Here you can find manuals for your Graco sprayer: http://www.graco.com/Internet/SiteSearch.nsf/Search?OpenAgent&Mode=M&Query=Ultra%20and%20Max%20and%20II%20and%20490
Michael
www.sprayfinishingstore.com ' info@sprayfinishingstore.com
Apr 04, 2011 | Air Tools & Compressors
Air Tools & Compressors Logo
643 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
