Intermittent problem with my 2420dn not printing from tray 2
Intermittent problem with my 2420dn not recognizing paper being in tray two. I have to reboot printer several times and sometimes I even have to reboot my computer. I will work fine for a few printings and then does it again.
    Scholar:
  • 136 Answers
Chances are you could have a formatter Board Problem the eprom on this board.
Yup common problem, here's what I would do, I would reload the drivers one more time if this doesn't resolve the issue then possible problem witht the formatter, the formatter is what communicates with your computer and the printer at the same time.and it also converts the cumputer language to anaolg so your printer can process your printing requests.
Posted on Jul 24, 2009
Printer recognizes tray 2 but will not print from tray 2.
its not reading there is any paper in the slot so will not load from this draw. the is a switch that when paper is installed it lifts it to tell printer paper loaded. like any switch they can fail.
Jul 03, 2017 | Lexmark T630 Laser Printer
Duplex printing in HP 2420dn on Mac OS X Lion 10.7.4
According to the specs, this printer does not have a duplex unit and therefore cannot print double sided prints.
DOUBLE SIDED PRINTING USING A SINGLE SIDED PRINTER
If your printer does not have a duplex unit then the printercannot print double sided pages automatically.
You can print double sided pages but you have to do it one page at a time.
First print Page 1 then place the page back into the paper tray, but turn thepage upside down and the print Page 2.
Then print page 3 on one side then page 4 on the other side and repeat for therest of the document.
I suggest you try a test page first, to get the printing the right way up onboth sides of the page so it reads correctly.
Jul 17, 2012 | HP LaserJet 2420 Printer
We have a laserjet 2420dn which prints fine from Tray 1 but constantly jams when printing from Tray 2. It only prints OK from tray 2 when there is ONE sheet in the tray. I changed the pickup roller in...
In addition to the pickup roller, the separation pad in the tray should also be replaced. This pad keeps more than one sheet from feeding at a time. When we do maintenance on a printer we always replace both to stop this from happening. The part number you want is RM1-1298-000. It is used in quite a few different HP printers.
Apr 16, 2011 | HP LaserJet 2420 Printer
Tell me please hp laserjet printer 2420 paper tray setting
    1. Remove the packing material from the printer.
      1. Remove the all orange tape from the outside of the printer.
    1. Load all paper trays.
      1. Pull the paper trays completely out of the printer.
    2. Press the blue tab on the rear paper length guide and adjust the rear guide so that the pointer matches the size of the paper to be loaded. c00318778.gif
    3. Move the side width guides outward to match the desired paper size. c00318779.gif
    4. Add the media to the paper trays, make sure that it is flat in the tray at all four corners. Keep the media below the height tabs on the sides and rear of the tray. Push down on the metal lift plate to lock it in place. c00318780.gif
    6. Install the print cartridge.
      1. Remove the print cartridge from the packaging.
    7. Rock the print cartridge back and forth several times to "mix" the toner. c00318783.gif
    8. Pull the sealing tape from the end of the print cartridge to remove the entire length of the tape. c00318784.gif
    12. Connect the LAN cable (optional). (HP LaserJet 2420n, 2420dn, 2430tn, and 2430dtn models only) c00318788.gif
    Jan 13, 2011 | HP LaserJet 2420 Printer
    My Lexmark T640 does not seem to recognize paper "tray 2". I want to print legal, but it only prints from tray 1. How can I get the printer to recognize and use tray 2 so I can print legal AND letter?
    2 things
    1st make sure the paper guides are set correctly on the trays for legal make sure it's exactly on legal or it put the tray into universal mode. (To clarfiy the guides in the back which allow you to put legal in the tray.)
    2nd Go into menu and then to paper menu and adjust/ confirm the settings for tray 1 and 2. Based on your question tray 1 is letter and tray 2 is legal, so make sure both of the tray size and type are set correct.
    Oct 21, 2010 | Lexmark T640 Laser Printer
    I want duplex printing for hp 2420
    The only way to duplex print on a standard 2420 is to print the first page, then take that page and re-insert it into the paper tray face up. Then print page 2 onto the back of page 1. If you want to automatically duplex print then you need a 2420DN printer which has the duplexing paper path as well as the formatter board with the duplex firmware.
    Good Luck and Thank You for using Fixya.
    Sep 23, 2010 | HP LaserJet 2420 Printer
    The metal plate on the drawer for hp laserjet 2420dn is stuck down how to free this up so that the paper will feed?
    remove Tray 2, loock at the bottom on it you will found small plastic piece, push it and voala :)
    Tip:
    when you remove tray 2, try to push up metal rake a little bit (not so hasrd). Then put back paper tray. If you are lucky tray 2 should be unlocked :)
    Good Luck!
    Jul 11, 2010 | HP LaserJet 2420 Printer
    Does not print, get error message
    unplug, wait a minute, replug in. try it
    check cartridges and rollers to insure nothing is blocking the printing formation.
    is there too much paper in the tray?
    hp has an awesome trouble shooting web site as a last choice.
    Apr 29, 2010 | HP LaserJet 2420dn Printer
    HP Laserjet 2420dn - Faint ghosting of printed matter above & below actual print. Have tried cleaning page twice but no better Grateful for any suggestions
    • Please perform a half page test, by printing a test page from tray 1.
    • Open the top cover as soon as the paper is 70% through from tray 1 so that the media
    • Check if the ghosting appears, if yes, fuser needs swap out.
    Oct 30, 2008 | HP Office Equipment & Supplies
    Tray output
    You should configure TRAY 1 as Legal only.
    and Tray 2 as plain letter.
    Specially when you specify from what tray/paper type to print.
    This can be easily configured from the Printer Properties within the Printers and Faxes section of the Control Panel.
    Jan 26, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
    k24674
    jasbo
    jasbo
