Question about Microsoft Computers & Internet
Windows updates has caused my MSI EX625 to crash and now i cant getwindows loaded at all, and i cant get the Recovery manager to work
I been scammed by an ugly bad scammer in yoville he stoled all ma money while in a trade he stoled 50000 i wnt it back
Posted on Jul 24, 2009
How can I recover my cr700 when after going into recovery mode I have nothing on screen.the mouse works but blank screen.i get the win logo and loading windows files but nothing after that. I have tried...
If you have backed up your data (photos, documents, etc.) on an external hard drive, USB disk, DVD's.
If there is company data, or otherwise valuable data, this is better left to a professional! If you are able to cope with the possible loss of all your data, feel free to continue reading.
If you're unable to backup your data, you might try to do so with:
Easeus Data recovery Wizard
Data Recovery Wizard Free 8 6
After you have baked up your data. You could try to recover windows from the error by:
-Pressing F3 repeatedly when the unit is powered on.
-This will get you a menu to load Windows, or Windows recovery
-After this, select "Windows Sytem Recovery Options"
-Follow the on-screen options to try and fix the issue
-If this doesn't work, power on the laptop again and press F3
-load up the Windows option that you are given
!THIS WILL DELETE ALL YOUR PERSONAL DATA AND RESTORE THE COMPUTER TO FACTORY DEFAULTS!
-Select "MSI Recovery Manager"
-IF YOU ARE SURE IT'S OKAY TO LOSE ALL DATA: "OK" > "OK"
-IF F3 Doesn't work, either your recovery files are missing, or your hard disk is failing. If this is the case, you can read on at:
Reinstalling Windows when recovery fails MSI HQ User to User FAQ
Hope this helps!
Feb 28, 2015 | MSI Computers & Internet
How to Load or Reload"HP Digitalmedia archive" file and 'EZARC.msi to my HP Pavilion a1520n desktop. (XP)
Try this one:
This document pertains to HP and Compaq Desktop PCs with Windows 7, Vista, and XP. An error appears that contains a filename ending with MSI. (MSI refers to the Windows Installer.) This error can appear while Windows is starting up or when a particular software program is opened. This error might appear after using a Registry Cleaner or Registry Fix tool.
See the following error examples. Your error might be slightly different, but it has a filename that refers to or ends with MSI.
The feature you are trying to use is on a network resource that is unavailable. Click OK to try again or enter an alternate path to a folder containing the installation package 'TrayApp.msi' in the box below.
'HPProductAssistant' the feature you are trying to use is on a CD-ROM or other removable disk that is not available.
Figure 1: Example of an MSI error
c01378399.gifUsing Recovery Manager to Restore Software and Drivers in Windows 7 HP Recovery Manager (Windows Vista)
  • HP application recovery process (Windows XP)
  • If errors persist, you can clean up the MSI registry entries by using Microsoft's automated solution. For more information, see Fix problems with programs that can't be installed or uninstalled (in English).
    Preventing MSI errors To prevent these errors from occurring, make sure that registry cleaning and spyware removal utilities do not remove files and registry entries associated with your software. Instead, if you no longer use a particular software title and want to remove all references from the registry, remove the software by using the Add or Remove Programs tool in Control Panel. The software uninstaller will remove the associated entries from the registry.
    Some products available for free on the Internet suggest that the registry needs regular maintenance or cleaning. However, use extreme caution when installing and using a registry cleaner. Many registry cleaners generate other MSI errors because they do not recognize valid registry entries and delete them. This can cause more MSI errors and prevent other programs from working.
    If you do decide to install a registry cleaner, be sure to research the product thoroughly, and then download and install programs only from software publishers that you trust .
    [img src="http://h10025.www1.hp.com/ewfrf-JAVA/Image/common/note.png" alt="" >
    NOTE:One or more of the links above will take you outside the Hewlett-Packard Web site. HP does not control and is not responsible for information outside the HP Web site.
    Jul 12, 2014 | HP Pavilion Computers & Internet
    How to load or to reload "HP Digitalmedia archive" file and 'EZARC.msi to my HP Pavilion a1520n desktop. (XP)
    Jul 12, 2014 | HP Computers & Internet
    Acer aspire 5736Z wont boot on any recovery options
    Try starting up in Safe Mode (Console mode) and type in
    "SFC /Scannow"Once its done you should be able to do recovery options.
    If not, boot from the windows 7 recovery/install CD and choose "Repair".
    Go through the recovery process using the CD and it should all be fine!
    Dec 26, 2012 | Acer Aspire 5736z 4460 Laptop
    MSI P965 Pt Continually re-boots on start-up
    You don't say exactly at what point in the boot sequence the system crashed and restarts. Many things could be at work here. You say you are using the HDD from the previous system. Did you swap this drive straight out and are still using the OS load from the previous system? Windows loads drivers at startup based upon the hardware installed. If you are using and old WIndows load with a new mainboard, this could be the entire cause of your crashes. YOu may be able to get to SAGE mode and remove the old drivers and try to restart the system, but from experience I will tell you that to get the best results when installing a new mainboard, you should reload the OS from the original OS disk, and then load the new mainboard drivers.
    Dec 31, 2011 | MSI P965 Platinum Motherboard
    I lost my webcam driver and my bluetooth driver after i undertook total recovery.please help me get them back or give me a working link(s) where i can get them.Thanks for your anticipated cooperation.my os...
    Have your windows xp updated online as it would install new drivers. If you lost your installer CD then Go to start menu and look for my computer or computer, right click and select properties, click device manager, look and click the webcam, then press update driver. You may update drivers online. If the problem persist then go to MSI website http://www.msi.com/open/ look for service tab, select live update online.
    Jan 31, 2011 | MSI Wind U100-016US Laptop
    Msi notebook. on startup it gets as far as the windows loading screen then crashes. iv tried F8 F3 rebootin and the same thing happens over again. i know that the problm is due to downloading a update...
    I think that you may need to reinstall windows or at the very least, do a repair. If you can get a USB DVD drive, boot from it and go through the repair proceedure
    Jan 06, 2011 | MSI Wind U100-030US Laptop
    Good day, My computer crashed and I had to reinstall windows XP. I could not install the sound as I could not retrace the driver of my MSI 865 PNE EO2-V motherboard. Can you please let me know where can I...
    Welcome to FixYa Solution:
    Try Following ..To get AUDIO Driver Click this Link..To get other XP drivers Click here...Hope this will help you...Thanks for Contacting FixYa....
    Jun 09, 2010 | MSI 865PE Neo2-V Motherboard
    How do i do recovery for my msi ?
    just insert the cd and boot the computer from it and then choose fix problems
    May 02, 2010 | MSI Wind U100-030US Laptop
    Tried to install update and computer crashed
    A few ways to try and eliminate.
    Upon startup F8 for safe mode: Last Know Configuraton
    Hit F8 for safe mode. Go into accessories>system tools>system restore
    Doesn't work then: need Windows CD setup. Let it run and hit R for Recovery Console. At the DOS prompt type FIXMBR or FIXBOOT.
    Mar 05, 2009 | IBM ThinkPad T30 2366 Notebook
    Computers & Internet Logo
    Top Microsoft Computers & Internet Experts
    micky dee
    Piyal Perera
    Piyal Perera
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
