Question about Dell Dimension 2350 PC Desktop
Memory upgrade problems
Am trying to upgrade from 256MB to 1Gig (2-512 MB modules) Tried Dell's offerings as per their website. No go. The monitor stays black when the computer boots up. Returned them to Dell. Ordered from CDW, and the same problem. Tried various configs. with the memory modules, and still nothing happens. But when I Install the original 256MB back in by itself, everything works. Original is a 256MB PC2100 DDR 266MHz. The new modules I got are the same, except that they are 512MB each. Modules are seated correctly each time. What am I doing wrong?
  • James Carr
    James Carr Jan 06, 2009
    I have the same problem with my bell dimension 2400 desktop and my HP pavillion505n desktop. The memory is hynix and it gives me a beeping sound in both comp's and will not boot up or show that it is booting up. Does this mean i bought three bad sticks or is it a compatibility problem?
  • 54 Answers
Hmm if the pc takes DDR Ram , it should deffently take 512 sticks, have u tried booting the computer with just the one 512 stick ? or try putting the 256 stick in and 1 x 512 stick , test it that way with both sticks , some older computers there is a bios setting for upgrading to higher amount of memory, but in your case with DDR ram i dont think so , i mean it may be worth a shot going into bio's and load optimized defaults , press f10 to save settings, try one stick at a time after that , if still no go , there is a jumper pin on the mother board that u can move over a slot which will restet the bios, if u dont know this jumper pin or where it is, just remove the round battery on the motherboard for 30 seconds , then put it back in , try your new ram then , u will be asked to save settings on boot up , if it still dosent work the ram is either faulty or incompatible, alot of the time with Dell , HP /Compaq desktops there fussy with the type of ram they take, but if u ordered from dell it should have worked !! whats the brand name of the ram u have is it hynix? /HP this brand of ram has alot of issues with compatibility,
Posted on Nov 21, 2007
Dell Precision 530 with dual Xeon CPUs. Uses Rambus memory. (4) 256mb ECC modules are installed. It should be a total of 1 gb. However, BIOS only shows 256mb total even though it shows all 4 rambus...
It sounds like like you have multiple issues. When all memory slots are filled with 256 sticks the computer boots but only sees 256 MB instead of 1 gig.
When you install the Crimms it won't boot at all.
You may have an open circuit on one of the Crimms.
As for the computer seeing only 256 MB you may have a bad memory slot on the motherboard.
Here's a link regarding Direct Rambus DRAM or DRDRAM (sometimes just called Rambus DRAM or RDRAM:
May 15, 2011 | Dell Precision 530 PC Desktop
Cannot upgrade memory on my Gateway MX3215
Use Corsair Value Select VS1GSDS533D2.
Aug 17, 2009 | Gateway MX3215 Notebook
Dell Optiplex GX110 currently runs 128mb sdram pc125 cl3.0 . Am I correct to assume maximum upgrade would be 2 x 256mb sdram pc133 non-ecc unbuffered 3.3v ? Maximum memory per slot being 256mb ? Is my...
If I remember correctly, that Dell has two memory module slots, so 2 512 mb modules of non-ecc pc133 memory is the max that the system board will allow.
This is controlled by the system board chipset, and not by the bios.
Dec 15, 2010 | Dell OptiPlex GX110 PC Desktop
My system is recognizing only half of the new module's memory
Do you have the right memory for your Dell?
Memory Upgrade for Dell Dimension 1100 Computer, the Dell Dimension 1100 Computer takes the PC2700/3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. Memory Type, and comes installed with 128 MB (removable) of Memory. You can upgrade your Dell Dimension 1100 Computer to up to a maximum of 2.0 GB Memory, the system has 2 sockets to install Memory, already with 128 MB (removable) standard Memory installed. For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
Choose the following Memory Upgrade for Dell Dimension 1100 Computer.
Nov 20, 2010 | Dell Dimension 1100 PC Desktop
I have a DELL with XP-Home Edition - version 2002 service pack 3, Intel(R) - Pentium(R) 4cpu 2.66ghz, 2.66ghz, 512 MB of RAM My daughter plays games and has 24 of them in the computer - she tells me I...
Hello, Jim.
Dell's official position is that the maximum memory for this PC is 1 GB. But, it may be able to support 2 GB, per Intel's specs.
But, to answer your question - yes - you can increase your memory amount to 1 GB. Since the system has 2 memory slots, you could conceivably have (2) 512KB modules (total 1 GB). If your system already has 1 module of 512 KB, you could add another. Just be certain it's the same type and speed.
Or, you could have a 1 GB module.
I don't think that your computer's life is in jeopardy, but additional memory always helps the speed of your computer.
Hope this helps.
Sep 19, 2010 | Dell Dimension 2400 PC Desktop
I want my Laptop Dell Latitude C800 physical memory upgraded to 128 mb to 256 mb I myself already installed 256 mb Ram but it still showing 128 mb of memory...can I get help in this regard ?
I assume you installed another 128Mb of RAM to give you a total of 256Mb.
It is most likely the 2nd RAM module is not compatible with the other RAM module. Try using the same make.
Purchase and install a single RAM module 256Mb or 512Mb these are not expensive.
Dec 20, 2009 | Dell PowerEdge 2600 Server
Upgrading memory on n232 motherboard
Check the specs on your motherboard from dell
Jul 26, 2009 | Dell Computers & Internet
I want to upgrade my ram what type of ram should i use and how what is the maximum amount of ram i can upgrade to?
Memory Upgrade for Sony VAIO PCG-K35 Laptop, the Sony VAIO PCG-K35 Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB = 256 MB (removable) + 256 MB (removable) of Memory. You can upgrade your Sony VAIO PCG-K35 Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB = 256 MB (removable) + 256 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Jun 29, 2009 | Sony VAIO PCG-K35 Notebook
RAM Recognition 835GM PC Desktop
the memory is dual channel, so you have to use matched memory for it to work 1gig in each slot if possible, check the 1 gigs and 512's to see if they run at the same bus speed, if they are not matched there is your problem try a gig and a 512 in slot 0 to see if it picks the memory up, also there is sometimes an option in the bios to dissable dual mode
Sep 18, 2008 | Gateway 835GM (835GH) PC Desktop
Sorry for the delay in my response.
Your computer will accept a maximum of 1 GB of memory. If both memory modules are the same brand and part number then it is possible that one of the sticks are bad.
Try each 512 MB memory stick in the first memory slot, without installing a second stick. This will troubleshoot to find out if one of the 512 memory sticks are bad. If both check out ok, then the problem is with the video adaptor.
Have you tried adjusting the refresh rate on the monitor as I described in my first response?
My final possible solution would be to upgrade the bios. Below is a link to the webpage for your computer system. You will find links for troubleshooting guides, driver and software downloads, product specifications, etc. If you click on driver downloads, then choose your operating system, you will be directed to a page that should provide the latest ROM (bios) update.
Jul 28, 2008 | Computers & Internet
Dell Dimension 2350 PC Desktop Logo
134 people viewed this question
Alun Cox
