SOURCE: Phillip PET710 Portable DVD Player
The back light of the monitor might be defective. or the drive signal might not be getting to the screen you will need a schematic, multimeter, and an oscilloscope to troubleshoot this issue. This is how you will have to go about this using the schematic locate the screen test points measure the voltages with the multimeter and look at the signals with the oscilloscope. this will lead to you finding the exact problem.
SOURCE: RCA CONSOLE TV will not work with DVD Player
what is the model of your tv and the method in which you are trying to connect the dvd (ie rca cable, component, composite, hdmi) and do you hear audio
SOURCE: Hooked up dvd and vhs player good picture no sound please help
look carefully whether you jacked the audio out from DVD and audio in into the TV
> the TV is having a Audio out and in jacks
>if you jack a the audio out from DVD into Audio Out in TV you wont have audio
SOURCE: only getting sound but no picture!
Well, i had a look at the back of that Toshiba TV - make sure that the red, white, and yellow cables are hooked into the Video-1 slot of the Toshiba and that the Toshiba channel is changed to Video 1.
Then check your nameless DVD player and make sure the red, white, and yello cables are all hooked to OUTPUT slots that are in the same column or row - if I had you DVD manufacturer and model #, I could suggest some additional steps to check. Also, make sure your dvd player is in dvd playback mode.
-Tha Mp3 Doctor
SOURCE: proscan tv surround sound hook up
This depends on whether you have digital cable box or not. If you have a Digi Cable Box look for the red/white RCA output and connect this via RCA cable to the Red/White Audio input on your surround.
If just Basic Cable look for a red/white audio output on the back of your televison. connect this to the Red/white in on your surround. Could be called tv in or auxillary.
