Question about Samsung YP-K3 MP3 Player
Same problem I plugged mine in overnight into the USB. Stated it was charging and then nothing. Can't seem to solve this and it has been over 4 months. Still won't work. THere is a battery inside and I need to check that. May have gone bad. YOu might try that.
  • 4 more comments
  • kelly593 Jul 24, 2009
    I wish that is what it was but I am very careful with it. It worked fine until about 4 months ago.
    It won't even stay on with the USB cord plugged in
    the computer won't recognize it when I plug it in. THe device says charging and then it turns off
    yep, looked at the K3 manual and everything. Samsung Media Studio will not recognize it when plugged in either
  • kelly593 Jul 27, 2009
    about two seconds :)
  • kelly593 Jul 29, 2009
    awesome!! Thanks so much for your help! You were more help than the actual Samsung company!
  • 55 Answers
Well if you dropped your mp3 in the water or simply droped it that could have mangle the inside mother board or your chips so all that is going threw it is the information that is directly linked to it it will not be able to function on its own that is why you needed the third party the computer to make it light up. take it to a specialist so he can open it up and fix what is wrong with it
good luck
Posted on Jul 24, 2009
  • 3 more comments
  • Dillon Gaus
    Dillon Gaus Jul 24, 2009
    well i think you might have short circuited something inside of your multi media device see sometimes when you leave them on for to long you can over heat the motherboard and the flash drive conected but all your information is still on that flash drive the mother board problably is fried do u have any problems with accessing the information on your my computer when you have the mp3 pluged in?
  • Dillon Gaus
    have you tried to troubleshoot the device?
  • Dillon Gaus
    i believe your battery may be fried. how long does it indicate that its charging ?
  • Dillon Gaus
    Dillon Gaus Jul 29, 2009
    yup you need a new battery you should go to the nearest electronic store that can give you tech help and replace your battery for you unless you already know how.
  • Dillon Gaus
    no prob
How do you thread a SewPro1541S
If someone has the same problem (mine was Lenovo Yoga and after mobo failure and replacement it was stuck at 0% Plugged in, charging) - i stuck the battery in freezer overnight. Next morning it charged as normal. AmanStino Ultra Slim 4 Port USB 3 0 Data Hub white AmanStino
Nov 24, 2016 | Sewing Machines
Charging battery
Sometimes if charged too long or your not around when the light does go off, after awhile the battery looses its charge. when that happens the charger will start to charge again and it will seem that it isn't working right or charging. in your instruction booklet it should tell you how long it should take to charge. some say 45 min some say hours. set a timer once you find the time recommended for your device, once it goes off unplug if light is off. good luck
Dec 07, 2013 | Case Logic IKBT-50 Bluetooth Keyboard...
Why do you send usb connection to charge jwin jb-th130, why not receptical plug. do i plug into computer and how long to charge?
The standard connection is a USB plug (mini or micro USB style). You can plug it into your computer or any wall plug that has a USB connector on it (the bigger rectangle shaped plug like your computer has). The USB standard is 5 volts so if it comes from your computer or a wall adapter or your car charger - as long as it is a USB connector and likely says 5 volts, they will all work the same way.
Every headset I have worked with seems to charge about 50 to 75% in 2 hours (it is ok to do a quick, partial charge). Leave it plugged in overnight for full charge (8 to 12 hours).
Jun 14, 2011 | Jwin BLUETOOTH HEADSET Wireless Headset
Flashing orange triangle on usb when charging. No charging taking place New battery inserted and used successfully When battery flat, problem repeated itself. Don`t know if problem is the plug charger,...
Mine did this too. It's a warning to say that your battery is faulty and needs replacing , I replaced mine and It now works fine , charges fine and operates ok. You just need to replace the SLB-10A for another battery of this kind and It should be okay. Charge it overnight and in the morning iot might be ok , if not then you have another malfuntion , so take it to the camera shop for them to check or send away to samsung for repairs.
Sep 02, 2010 | Cameras
Sansa clip sandisk 2gb won't charge. Thought it was low and after plugging it in to computer overnight it wasn't fully charged but worked the next morning but suddenly died. Now it won't charge. Sansa...
I had the same problem this morning, albeit with my 8G Clip. Nothing worked -- the thing seemed dead as roadkill -- until I found a link about "forcing MSC mode." Basically, it told me to hold down the center button while plugging my Clip into my computer using my USB cable. Suddenly, boom! It's awake and alive and happy again. I'm unsure how that works, but that did it for me.
Nov 03, 2009 | SanDisk Sansa Clip MP3 Player
Using USB in car as external power
the unit uses power EQUAL to what it is being charged with, when plugged into the USB.
you need to leave it on the DC (cigarette lighter) charger overnight to charge it fully, or use an AC plug for the Motorola Razor (min-USB) to charge it in the house
Feb 12, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Charging time
I called Garmin re this question. They said about 4 hrs in the car, about 6-8 on the computer. I left mine plugged to the USB port overnight and have a full charge. BTW Radioshack sells an AC adapter for about 30 bucks. If if also works for the latest iPod I think I will go with it. 4hrs.. says Garmin
Dec 28, 2008 | Garmin nuvi 250W GPS Receiver
My zune wont charge at all even when its plugged in
OK this seems weird but if you have like a Nintendo Wii or a PlayStation 2 or 3 take you sync cable and plug your zune into the usb port on the system because sometimes the battery is just so dead that it dosent have enough power for the computer pick it up. mine done this a few days ago and i left it plugged into my Nintendo Wii over night and it started working again
Nov 11, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zen Touch
Plug the Zen into a self powered USB hub that is not connected to a PC and leave overnight. You may also use other devices such as a printer USB port etc.
It recharges very slowly over USB but it will recharge.
Apr 11, 2008 | Creative Labs Zen Touch MP3 Player
Samsung YP-K3 MP3 Player Logo
306 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
