Question about Logitech Marble (904351-0403) Trackball
Jumpy trackball - Logitech Marble (904351-0403) Trackball
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 12 Answers
Usually you will need to clean dust or lint build-up off the rollers... you will see these after the ball removal
Posted on Jul 24, 2009
Trackball not functioning
if ur trackball doesnt work because its dirty theres a perfect way to clean it. my trackball get dirty all the time from greay hands and once that trackball starts to feel buttery and greasy its not going to work (usually a htc snap trackball feels rough and vibratety when you scroll with it). I'm not sure if htc trackballs come out so it sort of scratch the trackball with my fingernail, this scratches the grease of until if feels rough again. if the trackball moves around to much when you clean it, press it in with the other fingernail. if this doesnt work i guess you could get some rubbing alcholon a cotton ear bud (q-tip) and clean it but i havent tried this. if a greast trackball is the not the problem to your malfunctioning then i guess you should get a new trackball or get it repaired in a shop. :D
Feb 26, 2010 | HTC Snap S522 Cell Phone
The ball wont roll on my blackberry. Help!
The trackball is easily removed for cleaning by just pulling the trim ring around the trackball off with your fingernail. Remove the trackball and clean with alcohol. Reverse the process to clean.
Feb 06, 2010 | Blackberry Curve 8350i
Ball on blackberry wont navigate up or down
Hi. BlackBerry smartphone trackball fails to roll in a particular direction because, debris is lodged in the trackball.
The trackball user interface found on certain BlackBerry smartphones is similar to the trackball used in a mouse in a desktop computer.
Using for certain period debris comes in contact with the trackball and affects the usability of the BlackBerry smartphone, rapidly roll the trackball up, down, left, or right to potentially correct the problem.
If rapidly rolling the trackball does not correct the problem, please contact your wireless service provider for support options.
I hope this information will be helpfull.
Nov 11, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Unable to save to contacts folder and unable to copy from sim to contacts folder, pls help my contacts folder is empty and i can't save nor copy to it. using bold 9000.
To add your SIM contacts to your BlackBerry Address Book.
1. Press the 'Menu' key.
2. Highlight 'Contacts' and select (press the trackball).
3. Press the 'Menu' key.
4. Highlight 'SIM Phone Book' and select (press the trackball).
5. Press the 'Menu' key.
6. Highlight 'Copy All to Contacts' and select (press the trackball).
To add your Black Berry Address Book contacts to your SIM.
3. Highlight the contact you wish to move and press the trackball.
4. Highlight the number and then press the trackball.
6. Highlight 'Copy to SIM Phone B...' and press the trackball.
7. Press the trackball and highlight save and press the trackball again.
hopes it helps better.
Jun 12, 2009 | RIM BlackBerry Bold Smartphone
As I try to guide the mouse to the right postion it takes off by itself wherever it may want tio go
This is a TRACKBALL, and does not rely on any surface underneath it. It is WIRED, and has no batteries to replace. Clean the bearings, yes, and the ball. A few Q-Tips, some rubbing alcohol, a couple paper towels aer all you need. After a tint bit, only a drop or two of pretty much any oil will also help everything run smoothly. But if it has not just an unsmooth feeling, but the cursor is actually jumping around on the screen, the most likely culprit is hair/lint/fibers/etc. inside the little oval opening behind the ball, which is being sensed by the optics and causes the jumpiness. Q-tip, toothpick, or such may help, or some compressed air, or a quick "poof" by mouth usually does the trick.
May 12, 2009 | Computers & Internet
Blackberry 8830 wont track down - trackball stuck
This is usually caused by the trackball getting dirty.
Use a q-tip dipped in IPA and clean it. Roll the trackball around and swab the q-tip around to clean.
If cleaning fails then you will need to replace the Blackberry trackball.
Check the following link on instructions on how to do that.
Blackberry 8800 Trackball Replacement Guide
Apr 16, 2009 | RIM BlackBerry ® 8830 Cellular Phone
Expert Mouse scrolling problem
I have the same problem running under win7 64 bit, I have just pulled apart my expert mouse\trackball to clean it and found that the scroll ring works by using a little infrared diode ... so no cleaning required ...
the screws for the base are located under the little rubber feet.
So I think the problem may be more related to drivers\software...
at the moment I cant find a win 64bit driver or mouse works application anywhere
Feb 05, 2009 | Kensington Expert Mouse Trackball
Trackball Is Brocken!
Good evening!
Trackballs are VERY easy to replace! You can take it to your cell phone provider but there is a good chance they will claim the phone is broken.
I would recommend searching on Amazon.com, Ebay, or just googling Blackberry Trackball replacement. They are inexpensive, range from $2 to $10 depending where you look and the quality of the trackball.
I personally have replaced my Blackberry's trackball with a new one off of Amazon. It is very easy to replace. You just need to be careful with handling the trackball due to they are very fragile.
Here is a bunch of replacements you can look into on Amazon:
http://www.amazon.com/s/ref=nb_ss_gw?url=search-alias%3Daps&field-keywords=blackberry+trackball&x=0&y=0
Youtube even has a few videos on replacing the trackball.
Glad to help you out and good luck with your Blackberry!
Jan 16, 2009 | RIM BlackBerry 8700g Cellular Phone
Kensington 64215 PS2/ Serial Trackball on USB Mac?
Is the trackball supported by the MAC operating system? If available try the same setup, using the adapter, on a windows based computer to troubleshoot whether it is the trackball or the Mac.
Mar 24, 2008 | Kensington Expert Mouse Trackball
Logitech Marble (904351-0403) Trackball Logo
65 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
