Question about Apple iPod touch
I got it wet, dried it out, it has been working on my station but now it dont, when i plug it in to charger there is a PICTURE OFA BATTERY FLASHING BUT NOTHING ELSE COMES UP ON THE SCREEN
  • dustynnelson May 11, 2010
    How wet did it get and how long did you dry it? What did you use to dry it?. I too got mine wet but it fully recoverd after a day of fans on it and my quicly turning the power off after it got it out of the water. (standby and home keys pressed together).
    Scholar:
  • 82 Answers
This might sound a bit silly, but take a bowl, fill it with rice, and put the ipod in it for the night. Rice absorbs moisture, which would make sure the iPod is drier on the inside. Then you can try recharging it, don't forget to give it at least 10 minutes before trying to turn it on cause it sounds like the battery is completely empty.
Posted on Aug 07, 2009
I have a cc 500 bat push mower the battery charger was leftout on rain the light dont come on for charger is it fried also does it have a plug that i can plug extenstion cord in or do I n
The charger lead should have been connected to a Residual Current Device, or Earth Leakage Breaker that should have flipped the power off. There should be a reset button on the plug.
Charge the mower for 14 hours before initial use. Charge mower indoors in a dry area out of the weather. DO NOT charge in rain or wet locations. IMPORTANT: Use only the battery charger provided with this mower. Plug the battery charger into the battery first, and then into any standard 110/120 volt household electrical outlet. See Fig. 3-9 for B battery charging location. A C NOTE: If an extension cord is required, use one that is at least wire size 16 AWG. Connect the extension cord to charger before plugging extension cord into electrical outlet. NOTE: You may charge the battery with the battery removed from the mower. IMPORTANT: Always recharge battery fully. It takes 14 hours to recharge a completely discharged battery. A flashing light on the battery charger indicates the battery is less than 80 percent charged; a solid green light indicates the battery is 80 to 100 percent charged. A full charge will be achieved in less than 14 hours if the batteries were only partially discharged. NOTE: It is recommended that the mower be charged once every two months during storage. IMPORTANT: Always disconnect battery charger (or extension cord, if used) from the electrical outlet first, then disconnect battery charger from battery. NOTE: It is recommended that the mower be charged immediately after it has been discharged. Storing batteries in a discharged state could reduce future performance. WARNING: The battery contains corrosive fluid and toxic material - HANDLE WITH CARE. Keep away from children. Do not puncture, disassemble, mutilate, or incinerate. Explosive gases could be vented during charging or discharging. Use in a well ventilated area, away from sources of ignition.
Cub Cadet CC500 BAT Operator Manual Charging The Battery
Cub Cadet CC 500 BAT Review Pros Cons and Verdict
It is a 48 volt battery, so the charger for this is special. contact Cub Cadet direct for a replacement.
Service Parts
Aug 09, 2017 | Cub Cadet Garden
My phone got damp in snow today, screen is black. I plugged it in to charge and on screen it shows C3590, goes off then shows a picture of a battery. It did not get very damp and battery was fully charged...
It sounds like it is damp inside. It needs to dry for several days with the power and charger off.
One popular method is:
Remove the battery from the phone, if possible, or at least turn the phone off. ...
  1. Disassemble the device, if possible. ...
  2. Blow compressed air on the device to remove as much water as possible. ...
  3. Fill a container three-quarters full with dry, uncooked rice.
Here are some links that may help:
How to Save Wet Cell Phone
Here the Right Way to Rescue Soaking Wet Smartphone WIRED
How We Drowned Nine Phones and Found The Truth About Rice
Mar 02, 2015 | Cell Phones
My Electrolux Rapido wet&dry won't start. The battery is empty and the blue light flashes when I plug in the charger.
this sounds totally silly but is the power button on the vacuum actually off? Had the same problem, where the battery was completely empty i didn't know my son had switched the vacuum on put it on charge and the light was flashing. I took it off the charging stand pressed the power button then put it back....now charging perfectly. Anyone who doesnt have this appliance will think you sound stupid but its just a clicky button so visually the button looks the same on or off.
Apr 04, 2013 | Electrolux Zb4106wd Rapido Wet And Dry...
LG NEON GW370 CELL PHONE WON'T TURN ON
Check the battery first, connect into charger. If phone was wet, you need to clean it in isopropanol. Or just dry for few days (you can use hair dryer) carefull to dont overheat phone. Even if you think phone is dry it can be still wet. Check if connectors from charger are not dirty. (Check charger, and battery) best way is to borrow battery from friends phone
Oct 21, 2011 | LG Neon GT365 Cell Phone
We have a scunci recharge cordless wet-dry vac model # 52033. The battery does not charge. What can we do to fix this?
if the charger is working, and the battery does not hold a charge for very long, you will need a replacement battery. this is the most likely problem. if the battery does not charge at all it may well be the charger and you will need to replace that. hope this helps
Jun 08, 2011 | Scunci 52033 Canister Wet/Dry Vacuum
Does not work, we tired a new battery, but no help.
Instructions
    Technical Difficulties
  1. If the phone doesn't turn on, make sure battery is charged and fully plugged into phone. Remove battery from phone and use rag to brush away dirt that may interfere with connection. Reconnect and try again. If using cigarette-lighter adapter, make sure it's properly plugged in. Make sure charger is properly plugged into outlet and into battery.
  2. When the battery doesn't charge, plug lamp or other electrical device into outlet to verify that outlet works. Borrow friend's charger to see if charger or battery is problem. Replace charger or battery if necessary.
  3. In case the phone gets wet, remove the battery from the phone and allow both to dry thoroughly. If rust or corrosion develops, wipe it off with a stiff brush. If phone still does not work, replace it.
  4. Should the display not be working, try getting it to room temperature, extremely cold or warm conditions may affect display functions.
  5. If the keys don't work, look for a display of a symbol that looks like a lock. The keypad may be locked. The display often tells you how to unlock it. If not, check owner's manual.
Jan 24, 2011 | Lands Phones
My mum has a evesham laptop she run it pluged in mains before she plugs into computer the charger is just green and when she plugs it into laptop it starts to flash and laptop will not swicth on can u help
Sometimes this is caused by a bad battery, you could try taking the battery out and run it off the mains, however, with this make of laptop, like Gateway and Hi Grades, the issue probably lies in a burned out or faulty power board. The flashing light on the charger indicates that power is being, for want ofa better expression, "rejected" by the laptop... current has nowhere to go, so it is not flowing and the blinking light is indicating this.
As to repairs.. suggest it needs stripping down, oddly enough,the problem might just be a simple short caused by a screw working loose and shorting out a component
Jan 03, 2011 | Computers & Internet
I have a ryobi impact drill and battery charger that has stopped
yes, most chargers have internal fusses.
Oct 23, 2009 | Drills
Phone got wet
try taking out the battery and blow-drying where jack goes. Keep air on high fan and heat on cool. Also blow dry where battery goes.
Dec 16, 2007 | LG VX8300 Cellular Phone
Charger light flashing, battery not charging
What you can do is call their tech support department and they should be able to replace the battery for you. Tech support will take your information and request you to send in your battery before they replace it.
Jul 23, 2007 | Casio Exilim Card EX-S600 Digital Camera
Apple iPod touch Logo
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
