Samson AH1 Professional Headset Logo
Posted on Mar 21, 2017
We use it for fitness classes. We've had this transmitter replace twice now and it will have to be replaced for a third time now. The first time it was a default in the receiver. We sent it back got a new one but this time it's the transmitter that's not working. The instructor teach an hour class and at the beginnig of the class you can hear the instructors lound and clear but after about half hour the instructor has to keep turning the volume up on our sound board and by the time the hour class is up the volume is at the highest it can be until not sound come through at all. The way to explain the problem it's like if we were using a low batterie, it gets weaker and then it just stops working because there's no juice left in it. IT that makes any sense!!
1helpful
How do you program a replacement key for a lexus es 330 2004
Here are the instructions from the factory manual. They must be followed exactly.
2004 ES330
1. Driver's door open, all other doors closed, key removed from ignition switch.
Within 5 seconds:
Insert and remove the key from the ignition switch twice.
2. Within 40 seconds:
Close and open driver's door twice.
Insert and remove the key from the ignition switch.
3. Within 40 seconds:
Insert the key into the ignition switch and close the driver's door.
4. Switch ignition ON and OFF:
A. Once to program a key remote transmitter code whilst retaining the original codes.
B. Twice to program a key remote transmitter code whilst erasing the original codes.
C. Three times to check how many key remote transmitters are currently registered.
D. Five times to erase all registered codes.
5. Remove key from ignition switch. System should now lock and unlock vehicle
once, twice or five times depending which mode has been selected. One to four
times, slowly, to indicate number of key remote transmitters registered.
6. Within 40 seconds:
Press and hold LOCK and UNLOCK buttons simultaneously for 1.5 seconds.
Within 3 seconds: Press any key remote transmitter button.
System should now lock and unlock vehicle once to confirm registration or twice
to indicate registration has failed.
7. Within 40 seconds:
To program additional remotes repeat step 60 now on each additional
remote you want programmed.
8. To exit programming mode open driver's door or insert key into ignition.
9. Step out of car with remote(s) in hand and test remote(s).
tip
How to Program Acura Remote Transmitter
Acura Remote Alarm / Central locking
Model: CL Year: 2001-2003
Model: TL Year: 1998-2006
Model: MDX Year: 2001-2006
Model: RDX Year: 2007-2009
Model: RL Year: 1996-2004
Model: RSX Year: 2002-2007
Model: TSX Year:2004-2008
System Operation
  • Pressing remote transmitter LOCK button once activates alarm and central locking.
  • Pressing remote transmitter UNLOCK button once deactivates alarm (if fitted) and unlocks driver's door only.
  • Pressing remote transmitter UNLOCK button once also activates driving position memory. Driver's seat and mirrors move into memory position specified on remote transmitter when driver's door opened.
  • Pressing remote transmitter UNLOCK button twice within 5 seconds unlocks all doors.
  • Pressing remote transmitter trunk release button for 2 seconds activates trunk release.
  • Pressing remote transmitter PANIC button for more than 1 second activates panic alarm.
  • Pressing any of the remote transmitter buttons deactivates panic alarm.
  • If vehicle unlocked and doors not opened within 30 seconds, locks are reactivated.
Synchronization.
when
  • Remote transmitter battery replaced.
How
  • Press remote transmitter LOCK button or UNLOCK button 5-6 times.
  • System should now lock and unlock vehicle to indicate synchronization procedure complete.
  • Check operation of remote transmitter
Programming
How
  • Obtain all remote transmitters.
  • Switch ignition ON.
Proceed as follows:
NOTE:Point remote transmitter at central locking signal control module (located behind glove box).
  • Within 4 seconds: Press LOCK button or UNLOCK button of first remote transmitter.
  • Within 4 seconds: Switch ignition OFF.
  • Within 4 seconds: Switch ignition ON.
Repeat procedure above twice.
  • System should now lock and unlock vehicle to indicate programming mode activated.
Within 10 seconds:
  • Press LOCK button or UNLOCK button of first remote transmitter, allowing doors to lock and unlock once.
  • Press LOCK button or UNLOCK button of each remaining remote transmitter to be programmed, allowing doors to lock and unlock once as each remote transmitter is programmed.
  • Switch ignition OFF.
  • Remove key
  • Check operation of all programmed remote transmitters.
Immobilizer
System Operation
  • System arms 5 seconds after switching ignition OFF. Immobilizer warning lamp flashes during this time
  • Immobilizer warning lamp illuminates for 2-3 seconds.
  • If immobilizer warning lamp illuminates for 2-3 seconds then flashes rapidly:
  • Key code not recognized.
  • Remove key and try again.
Programming
When
  • System malfunction.
  • Key added or replaced.
How
Immobilizer can only be programmed using diagnostic equipment.
Model: MDX Year: 2007-2009
Model: TL Year: 2007-2008
System Operation
  • Pressing key LOCK button once locks the vehicle.
  • Pressing key LOCK button twice within 5 seconds activates the alarm.
  • Pressing key UNLOCK button once unlocks the driver's door only and deactivates alarm.
  • Pressing key UNLOCK button within 5 seconds unlocks all doors and tailgate.
  • Pressing key UNLOCK button within 5 seconds and holding will open windows and sunroof
NOTE: Models with "Technology Package": Alarm central locking functions can be altered using digital multifunction display in instrument panel.
  • Pressing key PANIC button for more than 2 second activates panic alarm.
  • Pressing any of the key buttons or turning ignition ON deactivates panic alarm.
  • System will automatically lock all doors when vehicle is driven above 15 mph (if function selected).
  • If vehicle is unlocked and doors or tailgate not opened within 30, 60, or 90 seconds (depending on programming), locks and alarm system are automatically reactivated.
  • Pressing tailgate release button once will open, close or reverse direction of tailgate.
Programming
When
  • Key remote transmitter added or replaced.
How
  • Obtain all keys fitted with remote transmitters.
  • Ensure doors, trunk / tailgate and hood are closed and unlocked.
NOTE: A maximum of 5 remote transmitters can be programmed.
Proceed as follows:
Repeat procedure above twice. Locks should cycle when button in pushed.
  • Within 4 seconds of each other press LOCK button or UNLOCK button of each remaining remote transmitter to be programmed, allowing doors to lock and unlock once as each remote transmitter is programmed.
  • Remove key.
  • Wait 10 seconds.
Immobilizer
System Operation
  • System arms when vehicle is locked using the remote transmitter.
  • If key code is not recognized:
  • Engine starts, then shuts off.
  • Immobilizer warning lamp flashes once, then blinks until ignition is switched OFF.
  • With ignition switched OFF, immobilizer warning lamp will flash 10 times to indicate the system has reset.
Programming
When
How
Model: RL Year: 2005-2009
Programming
When
  • Remote Transmitter added or Replaced.
  • System Malfunction.
How
Remote Transmitters can only be programmed using diagnostic equipment.
Automotive and Commercial Locksmith Acura Remote Transmitter Programming...
on Mar 26, 2015 • Televison & Video
1helpful
We own a 2000 Pontiac Grand AM, 3.4 liter, 2 door coupe with front wheel drive and recently replaced the transmission and now can't find our key set. Great start We hired a local Lock Smith who...
You can purchase new Remote Keyless Entry (RKE) transmitters from the dealer or you can order them online at the web sites listed below or several others. Your vehicle provides for programming the RKE transmitters without the use of a scan tool. Follow the instructions below.
2000 PONTIAC GRAND AM RKE TRANSMITTER PROGRAMMING
WITHOUT A SCAN TOOL
1. Close all vehicle doors. Remove key from ignition lock cylinder
NOTE: STEPS 2 AND 3 MUST BE COMPLETED WITHIN 25 SECONDS OF PRESSING THE DOOR UNLOCK SWITCH
2. Press and hold door UNLOCK switch. While holding UNLOCK switch, insert and remove the key in the ignition lock cylinder twice. Do not rotate the lock cylinder.
3. Insert the key a third time, leaving the key in the lock cylinder. Keep the lock cylinder in the LOCK position for the remainder of the procedure. Release the door UNLOCK switch. The chime will sound 3 times to signal that the programming/diagnostic mode is active.
4. Press and hold LOCK and UNLOCK at the same time on the RKE transmitter for approximately 4 seconds. The chime will sound 2 times signaling that the transmitter has been programmed.
5. Repeat step 4 for each transmitter being programmed. (You can program up to 4 transmitters.)
6. To exit program mode, turn the key to the RUN position then back to the LOCK position and remove the key. Your transmitters should now work to lock and unlock your doors.
2000 Pontiac Grand Am Transponder (direct links)
- autotransponder.com
-keylessremotes.com
-ikeyless.com
Replaced batery in key fob and now there is no connection between fob and security system...I can lock and unlock doors with the key and I can start car ...fob doesn't work; does not lock or unlock...
reprogram the remote transmitter. first leave driver door open all other doors closed,key removed from the ignition switch. insert key into the ignition switch,then remove it.press lock and unlock on the vechicle door lock control switch at 1 second intervals 5 times. close and repoen drivers door.press lock and unlock on the vechicle lock control switch at 1 second intervals 5 times. insert key into ignition switch. switch ignition on and off twice to program a remote transmitter code whilst erasing the original codes or three timre to check how many remote transmitters are currently registered.remove key from the ignition switch.system should now lock and unlock.twice to indicate programming mode or one to four times,slowly to indicate number of remote transmitters registered.for the solara press and hold lock and unlock remote buttons together, press lock remote button for a second period of 1 second. system should now lock and unlock vechicle.once to confirm, twice to indicate registration has failed.if required repeat button procedure to program remaining remote transmitters.note to exit programming mode close drivers door or insert ignition key.maximum of 4 remote transmitters can be programmed.if akk failed let dealership reprogram remote transmitters.
1helpful
How do I reactivate the wireless remote control transmitter for a 2004 Toyota Camry XLE? I replaced the battery and the transmitter still does not work.
To Program Wireless Remote Transmitters:
Begin with:
The driver's door open and unlocked.
Key out of the ignition.
1.Insert and remove the key from the ignition switch 2 times within 5 seconds.
Steps 2 and 3 should be performed within 40 seconds.
2.Close and open driver's door TWICE.
3.Insert the key into the ignition and remove it.
Steps 4 - 6 should be performed within 40 seconds.
4.Close and open the driver's door twice.
5.Insert the key into the ignition.
6.Close the door.
7.Turn the ignition switch from "Lock" to "On" and back to "Lock" at about 1 second intervals to select the desired mode:
1 time for ADD mode.
2 times for REWRITE mode.
3 times for CONFIRMATION mode.
5 times for PROHIBITION mode.
8.Remove the key from the ignition.
9.To confirm your mode selection, the power locks will now cycle "lock" to "unlock" a number of times corresponding to your key cycles in step 7.
If Confirmation or Prohibition modes have been selected, opening the door will complete the procedure.
10.For Add or Rewrite modes do the following within 40 seconds of Door Lock confirmation:
A.Press both transmitter Lock and Unlock buttons simultaneously between 1 and 1.5 seconds and release.
B.Within 3 seconds of step A press the transmitter Lock button for more than 1 second and release.
^If the transmitter has been successfully programmed, the power locks will cycle "lock" to "unlock" once at this time.
^If there are problems with the transmitter or the procedure up to this point, the locks will cycle twice. If this occurs, verify that you have received the correct transmitter, and then repeat the above procedure.
C.If multiple remotes are to be reprogrammed, repeat steps A and B.
11.Open the driver's door to conclude programming mode.
The security system won't let car start key not being read
From General Motors Corporation....
Method 1-No Tools Required
In the event that a transmitter is lost, program the old and the new transmitters into the memory of the remote control door lock receiver. Up to 4 transmitters may be programmed.
Important
Once entering this procedure, programming the first transmitter erases all previous transmitters. You must program all transmitters.
Program one vehicle at a time. One transmitter could be programmed into other vehicles that are also on program mode in close proximity.
Sit in the driver's seat.
Remove the ignition key from the ignition lock cylinder.
Press and hold unlock on the door lock switch.
While holding the door lock switch in the unlock position, insert and remove the ignition key twice. Do not rotate the ignition lock cylinder.
Insert the ignition key a third time leaving the key in the ignition lock cylinder. The ignition must remain in the LOCK position for the rest of the procedure.
Release the door lock switch. You will hear three chimes. This chime feedback indicates that transmitter programming is active.
Press and hold the lock and unlock buttons at the same time on the keyless entry transmitter for 12 seconds. You will hear two chimes.
This chime feedback indicates that the transmitter has been programmed successfully.
Repeat step 8 for the rest of the transmitters (for a total of 4 transmitters).
Exit this procedure by removing the ignition key from the ignition lock cylinder.
Hope helps (remember comment and rated this).
1helpful
Key fobs do not lock/unlock doors, horn or trunk release. Batteries in key fob is good, fuses are good. What's next/
Retrain the fobs following the procedure in your owner's manual:
1. Sit in the driver's seat.
2. Remove the ignition key from the ignition lock cylinder.
3. Close all vehicle doors.
4. Press and hold unlock on the door lock switch.
5. While holding the door lock switch in the unlock position, insert and remove the ignition key twice. Do
6. Insert the ignition key a third time leaving the key in the ignition lock cylinder. The ignition must remain
7. Release the door lock switch. You will hear three chimes. This chime feedback indicates that transmitter
8. Press and hold the lock and unlock buttons at the same time on the keyless entry transmitter for 12
seconds.
You will hear two chimes. This chime feedback indicates that the transmitter has been
9. Repeat step 8 for the rest of the transmitters (for a total of 4 transmitters).
10. Exit this procedure by removing the ignition key from the ignition lock cylinder.
1helpful
THE REMOTE DOOR LOCK ON A 2000 BUICK CENTURY HAS QUITE WORKING. THE FOBS ARE GOOD BUT WON'T OPEN ANYTHING.
The transmitter may have lost programming,
IMPORTANT:
  • Once entering this procedure, programming the first transmitter erases all previous transmitters. You must program all transmitters.
  • Program one vehicle at a time. One transmitter could be programmed into other vehicles that are also on program mode in close proximity.
  5. While holding the door lock switch in the unlock position, insert and remove the ignition key twice. Do not rotate the ignition lock cylinder.
  6. Insert the ignition key a third time leaving the key in the ignition lock cylinder. The ignition must remain in the LOCK position for the rest of the procedure.
  7. Release the door lock switch. You will hear three chimes. This chime feedback indicates that transmitter programming is active.
  8. Press and hold the lock and unlock buttons at the same time on the keyless entry transmitter for 12 seconds . You will hear two chimes. This chime feedback indicates that the transmitter has been programmed successfully.
4helpful
2answers
Remote controls for factory alarm system are not working.
Resynchronization may be necessary due to the security method used by the remote keyless entry system. The transmitter does not send the same signal twice to the passenger door module (PDM). • The PDM will not respond to a signal that has been sent previously. This prevents anyone from recording and playing back the signal from the transmitter. • The panic button should still operate normally when the system is out of synchronization. • Resynchronization may be necessary under the following conditions: - The battery in the transmitter is very weak. - The battery in the transmitter was replaced. - The battery in the vehicle has been in a low or no charge condition for an extended period of time. • In order to resynchronize the transmitter with the PDM, perform the following steps: 1. Stand within 1.5 meters (5 ft) from the vehicle. 2. Simultaneously press and hold the LOCK and UNLOCK buttons on the transmitter for 7 seconds. The door locks should cycle in order to confirm resynchronization.
3answers
Prg3601p oven
I also have this problem Ihave replaced the igniter twice this helps some for a while  I AM GETTNG READY to order my third one. had dealer replace once they had no answer cut lighting time from fifteen to twenty minutes to maybe five
Top Samson Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Samson Radio Communication Expert? Answer questions, earn points and help others
