Question about Mitsubishi WD-52525 52" Rear Projection HDTV
TV gets vertical colored lines, then shut off, green blinks conti
Tv will get vertical colored lines and freeze like this, after a little bit will shut off with continuously blinking green light. Sometimes the system reset will work, other times must unplug for a while. Sometimes the green light will start to blink when the TV is off -- i.e. you wake up in the morning and it is blinking. Again sometimes reset will stop it. Tv has turned itself on a couple of times too.
  • 668 Answers
Bad Capacitors in the Power Supply could cause this. This Chassis has be famous for bad capacitors through out many boards. If you are not comfortable with working on the unit, and most are not, I would call a professional. The Chassis may need to be sent to Mitsubishi to be refurbished. This is a expensive repair and it would be advisable to call a Mitsubishi Professional to confirm diagnoses. Mitsubishi's Customer Service Number is 1800-332-2119. They also may be willing to help with the cost of repairs.
I hope this helps,
Skyassoc
Posted on Jul 25, 2009
LG vertical green line
LG plasma vertical line repair - YouTube
? 2:33
https://www.youtube.com/watch?v=24FkcQoeGPg
Feb 10, 2013 - Uploaded by Matt Mayer
I have an LG plasma, my vertical line is in the middle, as if one would have ... Panasonic Plasma TV TC-P50X5 Vertical GreenBar Line Fix ...
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ..
Jan 16, 2016 | LG Televison & Video
Vertical green line
? 4:45
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ...
I Have An Lg Plasma It Has A Green Line Down The Center What ...
www.diyforums.net/i-have-an-lg-plasma-it-has-a-green-line-down-the-ce...
i have an lg plasma it has a green line down the center what. .... Essentially I just disconnected the flat cable around where the vertical line was, sprayed it with a ...
LG 50PK550 Plasma Single Thin Green Vertical Line - Fixya
www.fixya.com/.../t12061168-lg_50pk550_plasma_single_thin_green
Mar 10, 2008 - Posted on Mar 17, 2012.
TV is not working
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
Mar 10, 2014 | Sylvania LD-320SS8 32 in. LCD TV/DVD Combo
Green vertical line
hi this may be a bad tab/ribbon fault which is connected to the screen, there is little test you can do when the lines appear you get some freeze spray, spray the area where the line are if they disappear then you have a have , bad tab, you can repair this temporarily by bonding the tab with rubber and tape to stop it flexing which could ,make the tv last a bit longer, but no means is this a repermanent repair hope it helps
regards
shaun
Jan 04, 2014 | LG 42LC2D 42 in. LCD HDTV
Screen freezes
the electronics are failing after it has got warm. Replace the TV.
Dec 15, 2013 | Dynex DX-19L150A11 720p 60Hz 19in Flat...
I have vertical colored lines and cant read menu on my l32w761 envision lcd It seems to be shutting its self off also and the light blinks an orange color in place of the usual green
On all the plasma tvs there are control boards on the lower part of the screen that control the vertical images. If one of the chips on one of the boards fail, have a bad connection, or no ground it will result in a thick black line down the screen.
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Good luck and take care in handling it ........
Jul 07, 2010 | Envision L32W761 32 in. LCD TV
Freezing, no audio/video/red circle
ONE THING YOUR CORDS ARE WACKED OUT AND THE COLOR DISTORTION SIMPLE NOT YOUR XBOX IT IS YOUR TV
Aug 17, 2009 | Microsoft Xbox 360 Console
PROSCAN 42' LCD COLOR TV MODEL 42LA45H
I am sorry Sir, the display panel is bad. If you purchased it new, it should under factory's warranty. Please call Proscan for a warranty repair.
Proscan Customer Service:
1-800-968-9853 (US and Canada)
May 31, 2017 | Proscan 42LA45H 42 in. LCD TV
Plasma tv vertical lines
I am getting a vertical green line on my lg 50 incs is the screen or have you a solution
Sep 03, 2006 | Sony WEGA KZ-42TS1 42 in. Plasma...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
117 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
