Question about Canon PowerShot S3 IS Digital Camera
View screen black when on & no longer takes photo's
When on & shutter open, view screen is black. My Powershot a620 now longer takes photo's. Black or empty photo's do get stored in memory. camera has not been dropped or gotten wet.
Thank you
Kevin Howard
  • 300 Answers
Sounds like a dead CCD. Contact your local Canon service center.
Tom
Posted on Jul 28, 2009
  • Canon Master
  • 4,738 Answers
A stuck shutter is another common failure mode for digital cameras, and especially for the A620. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Posted on Mar 21, 2011
Can't take any photo with my Canon S3IS any more. The view finder and the screen is black when I try to take some photo but I am able to see all photo that is already on my memory card in the view finder...
Look into the lense while setting the shutter speed at a half second or so (slow enough for you to see the shutter open and close) and click the shutter release... you should see the shutter open and close. If you don't see this, then you may have a 'sticky shutter' resulting from lubricant seeping into the shutter/aperature mechanism and preventing the shutter from functioning as it should.(Common problem reported with the S2 and S3 cameras... and probably the S1 as well)
I have gotten my S3IS to take pictures by turning on the power, then opening the battery compartment door and reclosing it repeatedly until the shutter opens (from the power surge) and an image appears on the LCD.
After confirming the sticky shutter was indeed the problem, I pursued a more permanent fix.
Jan 30, 2011 | Canon PowerShot S3 IS Digital Camera
Screen is black when turned on. view side works great on old pictures when button is pushed it flashes ,but no picture
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Sep 06, 2010 | Canon PowerShot A620 Digital Camera
Canon A620 is taking black images/ Can't see images on screen
First try pressing the DISP or DISPLAY button on the back of your camera. If that didn't fix it... A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 28, 2010 | Canon PowerShot A620 Digital Camera
A 620 canon camera iris does not open, photos seem
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
May 23, 2010 | Canon PowerShot A620 Digital Camera
My LCD screen is black. The camera seems to take
its actually probably the display. there is 3 different displays. 1. shows picture with icons 2. shows just the picture and 3. is a solid black screen. just hit the display button to cycle through until your desired display is present
Feb 07, 2010 | Canon PowerShot A620 Digital Camera
My Canon PowerShot A620 has a black screen, any ideas on how I can fix this? I can't even take pictures, all of them come out black
My A620 JUST started doing the same exact thing last night. LCD works, lens works... but something possibly wrong w/the shutter so it won't open.. everything black.
Jan 05, 2010 | Canon PowerShot A620 Digital Camera
Viewing screen is completely blank and will not take pictures
Dec 26, 2009 | Canon PowerShot A620 Digital Camera
Problem with canon a420 digicam
Note that your camera will not be able to take 15 second exposures, as per the above "fix". Instead, place the camera in manual mode, turn off the flash, and take the exposures in a darkened room. This should give you a couple seconds, just enough time to open the battery door while the red and yellow lights are flashing.
Sep 21, 2009 | Canon PowerShot A420 Digital Camera
Black screen
Simply right click on the track itself and select send to/DVD-RW or CR-RW depending on the type Compact disc drive you have. Then you will see a notification, "you files to be written to CD." Simply click on it or go to your Compact disc drive on My Computer and click “write these files to CD.” Then follow the screen instructions. IT is that simple. All you need to do is press and release the display button until the screen displays. Usually Canon Powershot cameras have 3 display modes:- colour, black & white, blank. Your camera is set to blank that is why you cannot see any image/screen displays no image. Just press and release the display button until the screen displays. That should do it.
Sep 13, 2009 | Canon PowerShot A620 Digital Camera
Canon powershot A620 black screen can't take pictures
A stuck shutter is a common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Dec 25, 2008 | Canon PowerShot A620 Digital Camera
Canon PowerShot S3 IS Digital Camera Logo
327 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
