Question about Garmin nuvi 250W GPS Receiver
Everything works fine on the unit no problem until
Everything works fine on the unit no problem but when I I enable FM transmitter nothing comes out of the truck stereo. It did work so I know it can. Seemed to be intermittent and now it doesn't work at all. Is there a reset button?
    Brigadier General:
  • 4,090 Answers
3. If your Nuvi has a FM transmitter, is it selected to "FM" or "Speaker"? The "FM" setting will mute the internal speaker. Setting it to "Speaker" will send sound to the speaker.
if this side of it works then the FM transmitter is faulty
Check that the sound has not been MUTED
plug the earphone into the socket to see if any sound is heard. The socket is also a switch that takes sound from internal speaker to ephone and reverse.
If no sound is hear in either FM or normal mode your unit is faulty and needs repair
Posted on Jul 26, 2009
My old unit stopped working;(worked perfect for many years) so I replaced with a new same model and I have bad interference and FM static. Sometimes the FM station overrides the express radio and all you...
The very first XM radios, (SkyFi2, MyFi, Roady2) up until they were put in red boxes, had a VERY strong FM transmitter, so strong, that when Sirius was their enemy, they complained to the FCC and they made the FM transmitters real weaklings. So unless you have one of the first two batches of XM radios, the FM transmitters now are real junk and you're better off using an AUX input on the radio or a cassette tape adapter. Okay? Thanks.
Mar 26, 2015 | Audio Players & Recorders
Great sounding speaker, but nothing but trouble with the bluetooth. It appears that I can only have one device paired at a time. In order to connect another device, it breaks the current pairing. A
Yes this is a 'feature' of Bluetooth. (I have never seen the point of Bluetooth... Wi-Fi does everything it does, but better !)
It DOES usefully enable a phone or tablet to play though headphones or speaker and to use a headset 'cordlessly'...
Consider instead a 'Bluetooth Receiver' (under US $10 from China) connected to a FM Stereo Bug (Transmitter) - Then you can use any number of quality FM Radios (including phones with built in FM) up to 50 metres or so away...
example: http://www.ebay.co.uk/itm/Wireless-3-5mm-Stereo-Audio-Adapter-A2DP-Bluetooth-Dongle-Transmitter-Receiver-/141227224470?pt=UK_Home_HomeDecor_Accessories&var=&hash=item20e1cc6d96
Dec 10, 2014 | Marshall Stanmore Bluetooth Speaker
I have Garmin 670. The bluetooth worked fine until yesterday. I have no sound.
Check your Volume mute if ithas a checkmark in it remove it.....
Check the FM Transmitter if it is Enable with a checkmark remove it.
Check the Language make sure you have one that has ( TTS ) chosen those are the only ones with voice
Hope this helps
Oct 25, 2010 | Garmin nuvi 670 GPS Receiver
My garmin nuvi 765T has no volume coming out from internal speaker but it comes from handfree, how to solve this problem? plzz help me
Power unit on
Press Volume Icon..... If there is a check mark on mute remove it
if not
Press FM Trans
uncheck Enable FM Transmitter
Love my Nuvi760
Oct 21, 2010 | Garmin Nuvi 760 Car GPS Receiver
The voice is just not working, all else is fine, no, the mute is not on...??
Do you have the unit set to internal speaker or FM Transmitter? Go to the Volume section from the menu, FM Trans, disable FM Transmitter.
Feb 13, 2010 | Garmin Nuvi 760 Handheld GPS Receiver
I have the Delphi MyFi xm2go. It is not the newer version, SA10113. My problem...It is no longer transmitting to my car's FM radio. While it is sitting in the cradle in the car, it 's display shows that it...
Make sure that this is NOT a "Sure Connect" version that has a very weak FM transmitter, but the older original model with a bland box. Make sure no earphone is plugged-in, then go to the menu and set the FM frequency and set the FM output level and you should be all set..
Jan 20, 2010 | Delphi MyFi SA10113 XM Radio Receiver with...
No sound when put on 88.3 fm
I didn't think this unit had an included FM transmitter - so I looked around for more info, and everything I've found indicates it does not.
It will however play audio via the built-in speaker or headphone jack. Use of a third party FM transmitter will allow playing audio (navigation, alerts, MP3 or audio books) when connected to the headphone jack and with both the FM transmitter and FM radio set to the same frequency.
The FM transmitter will work best when set to a frequency that is unused and has the least amount of interference from adjacent stations. Check by tuning the car radio across the FM band and note frequencies that have those qualities. Leave the radio on one of the clear frequencies and set the FM transmitter to the same displayed on the radio. You should try several to find the one that works best. Also, be aware that as you travel, you may enter an area where that frequency (or one close by) is in use by a broadcaster. This will require repeating the process as needed to reduce interference.
Oct 16, 2009 | Garmin Nuvi 350 Car GPS Receiver
My Nuvi 750 has stopped talking, still shows the map but no voice
That has happened to me several times. When it happens I go to Tools > Settings > Language. In my case, the Voice field is empty, so I click on the Voice field and then select American English-Jill (TTS) and it's okay afterwards.
May 05, 2009 | Garmin (010-00583-00) for nuvi 750/760/770
Logitech wireless headphones
Trying re-syncing the transmitter and the headphones. Hold down the power buttons on both until they alternate red and blue blinking, worked for me and now they work just fine. Got that from the Logitech FAQ website.
Feb 27, 2008 | Logitech (980361-0403) Headphones
Garmin nuvi 250W GPS Receiver Logo
225 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
