Question about Garmin nuvi 200 Car GPS Receiver
My Garmin has no sound. I reset to factory settings, Volume is at 100%. Still nothing. This has happened before. But it spontaneously started working again. What can I do to fix it?
    Brigadier General:
  • 4,090 Answers
Possibly a loose speaker or broken speaker wire. unless you are skilled take it to a tech for repair
Posted on Jul 26, 2009
Garmin nuvi 255w flashes on & off
I did twice hard reset my GPS Garmin Nuvi 1390 and nothing happening and after I tried different trick,when I turned GPS off I hold the top left corner screen.The screen exchange for calibrations and I pressed several times according request and my GPS Garmin Nuvi 1390 started work,but repairing company wanna charge me $100 Canadian dollars
Apr 02, 2013 | Garmin nuvi GPS
Touchscreen on a Garmin nuvi 1350 doesn't work
My touchscreen on Garmin nuvi 1390 not working too and .calibration it's help alsoI did twice hard reset my GPS Garmin Nuvi 1390 and nothing happening and after I tried different trick,when I turned GPS off I hold the top left corner screen.The screen exchange for calibrations and I pressed several times according request and my GPS Garmin Nuvi 1390 started work,but repairing company wanna charge me $100 Canadian dollars.I didn't connect GPS to computer
Mar 29, 2013 | Garmin nuvi GPS
Garmin Nuvi 680 no longer has any audio
Hello :
It's a common software problem with your device . To correct the problem I recommend you to reset it .
Here is how to reset your device :
1:Turn the Nuvi on.
2:Touch the tools icon on the main screen. The tools icon is represented by a wrench surrounded by a blue circle.
3:Touch the "Settings" icon which appears as a wrench.
4:Push the "Restore" button at the bottom of the screen. A confirmation message will appear asking to confirm restoring the Nuvi to factory settings. Push yes to restore the factory settings
Try this for hard reset .
Turn off Garmin device. Press down on bottom right corner of the touchscreen [ Don't let go ] , and then power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press “Yes” to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
PLEASE DON'T FORGET TO RATE !
Apr 15, 2010 | Garmin Nuvi 680 GPS Receiver
I have a nuvi 205 and it has quit giving voice commands. The volume is at 100% but there is no sound
Hello :
You have a software problem with your NUVI . I recommend you to reset [ restoring default factory settings ] your NUVI . That should fix the problem .
good luck .
please rate !
Apr 14, 2010 | Garmin nuvi 205 GPS Receiver
My garmin nuvi 205 has no sound with volume @ 100%
Whenever these devices start acting up, I recommend performing a hard reset of your Gamin Nuvi 205. Also, use Garmin's WebUpdater service to make sure you have the latest software on your device.
I hope that helps.
Nov 03, 2009 | Garmin nuvi 205 GPS Receiver
Yamaha yst ms35d speakers problem/Vista...volume surges to 100%
U may try to check(if u have) multymedia keyboard! i have same problem and the botton for + volume was stuck ! i just pull it back and everything was OK!
Aug 27, 2009 | Yamaha YST-MS35D Computer Speakers
My nuvi 200w had voice yesterday, but today won't talk to me. I have the mute box unchecked and have also tried it in the checked position as well. No luck. Roger
Try changing the announcer's voice first to see if you have any sound. To do this tap TOOLS - SETTINGS - LANGUAGE on your main screen.
Try a couple of different voices. Select ones that end in TTS (Text-To-Speech)
If you still do not have any sound, check again that the mute box is not checked and increase the volume to 100%.
If that doesn't do it, reset the unit to factory default settings.
Aug 09, 2009 | Garmin nuvi 200W GPS Receiver
I have only used it maybe 10 times. Suddenly it sounded like someone talking and it stopped working. I know nothing about it and of course lost all papers.I think i pushed something wrong :(
There may be a reset button on the back of the device under the flip up antenna. try pushing the reset button and it should reset the device back to the original factory settings. Sounds like your device froze up or got muted. If you still have no luck, call Garmin at:1-800-800-1020 . I hope the reset works for you, if not maybe Garmin could give you a few suggestions. Good Luck!
Aug 02, 2009 | Garmin nuvi 265 Car GPS Receiver
It just stopped talking. No voice directions, on
Hit the menu buttom, go to settings, then go to volume and see if it is muted. Sounds like the mute or volume down button got inadvertantly hit and turned down or muted. If this does not work, turn the unit over and look under the fold up antenna for a reset button. Depress this button until the unit restarts and should reset the unit back to factory default settings and get you on your way. Good luck!!! If these don't help you, call the garmin support number at :1-800-800-1020. Hope this helps!
Aug 01, 2009 | Garmin nuvi 885T GPS Receiver
My garmin nuvi 205 quit talking. volume is at 100% and not on mute. beep sounds work but when in route i have no next turn or direction sounds. screen map does work.
I have a 750. I went to settings, language and restored the defaults. The Voice was blank when I went to that screen. I am not sure if the 205 has the language setup or not, but this should solve other Garmin problems. And as a bonus, if you want to solve the problems with the US, Fire Congress check out http://FireCongress.org
Nov 07, 2008 | GPS
Garmin nuvi 200 Car GPS Receiver Logo
122 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
