Question about GE Freezers
We have a happily humming away GE upright Freezer, Model # 12DACW 4.3 -- and yes, it is virtually ancient, mid-1960s. Door gasket has finally gone, generating plenty of frost and a veritable snowstorm when I open the door. For want of a gasket, do we have to give up on a freezer that still operates beautifully?
  • 3,037 Answers
Wow, amazing that it is still running. Too bad they don't make them like they used to. Anyway you can get a new gasket though you will have to make it yourself. The following website sells universal gaskets that you will have to cut out. I have posted a link to one size, but since I am not so familiar with the dimensions, you may just have to contact the company about the size you need. You will find a "Request Dimensions" spot on the page so you can get what you need. So please click on the following website link and let me know how this turns out.
http://store.appliancezone.com/servlet/-strse-45327/SU2002-refrigerator-refrigerators-door/Detail
Benjamin
Posted on Jul 24, 2009
Frigidaire frost free upright freezer door corner dripping
Hello Yellow, thank you for your post!
I understand that your Frigidaire freezer is dripping water out of the corner of the door. It is possible that with your power going out the heat may have caused the gasket to warp. Do you see any frost build-up? The water that is dripping could be coming from condensation within the freezer. I would recommend checking the gasket to see if it is allowing warm air to enter the freezer.
I recommend that you visually inspect the door gasket for defects such as gaps or tears. You can also use a dollar bill to test the door gasket. Place a dollar bill in between the door and the body of the freezer. If the dollar bill pulls out with no to little resistance, you may need to replace the door gasket. A faulty door gasket can allow warm air to enter the compartment and cause frost to condensation or a leak. I hope this information is helpful. -Matt
Sep 01, 2015 | Frigidaire 13.7 cu. ft. / 388 liter...
Why will it not come on?
The rust shouldn't make any difference.
When you plug it in, does the interior light turn on? If not, suspect the wall outlet - test it for power by plugging in something else. If the interior light turns on, listen very closely to the freezer. It should hum. If it doesn't, toy with the freezer control inside - it may just be turned off. Turn it to about midpoint and listen very closely to it again. If still no hum, wait a short while, then feel carefully on the outside of the cabinet - it may be running through a defrost cycle. The outside of the cabinet may get warm while that's happening, especially around the door gaskets. Wait a while (half an hour, an hour, for the defrost cycle to finish - the freezer should run then.
If it never hums, then the compressor isn't running, so adding freon won't make any difference. Instead, suspect the defrost timer - that's a little electronic circuit board inside.
If it HUMS but never gets COLD, then you potentially have a freon leakage problem. It's difficult at best, though, to refill a refrigerator or freezer - they don't usually have refill taps.
Oh, yes. If the internal light never comes on but you've proven that the wall outlet has power, it's entirely possible that the plug is bad and needs to be redone.
Jul 29, 2014 | Kenmore 12.1 cu. ft. Upright Freezer 2826
Frigidaire Freezer Model FFU17C3AW1 door not sealing properly?
Good Afternoon Vonaspern,
I understand that you are having trouble with the door sealing properly on your Frigidaire freezer, model# FFU17C3AW1. I see that you have already checked to make sure there is nothing blocking the door from closing as well as making sure there was nothing between the door gasket and the freezer body. Next, I would check to make sure that the gasket is not damaged or compromised in any way. If it is not damaged, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your freezer and determine what is causing your appliance to properly seal. Hope this is helpful.
-Best Regards-
WP
May 12, 2014 | Frigidaire 14.1 cu. ft. Upright Freezer...
Can i replace the door seal by myself on upright Amana freezer?
Hello.
Yes the door gasket is replacable. If the model number for your freezer is the one listed in your question (AFU2076AW) the part number for the door gasket is 4357120 it could be purchased at your local appliance parts tore or online at;
apdepot.com
searspartsdirect.com
partselect.com
apwagner.com
repairclinic.com
GENE
Sep 14, 2011 | Amana 19.6 cu. ft. / 555 liter Upright...
Sears Kenmore Upright freezer is Making a loud humming sound
change the rubber washers on the compressor should work a treat...
Feb 05, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Stand up freezer builds up frost quickly
It sounds like you may be on the right track here. If the gasket is old, hard, and brittle, it will allow moisture to be administered into the freezer, causing frost buildup. Not to mention, that old door gasket is leaking out a lot of cold air. Your best bet is to provide the model number (as you've shown here) and the serial number to an appliance parts store or authorized GE appliance parts outlet. They should be able to provide you with a brand new gasket. Removal and re-installation of the new gasket is fairly simple and you'll notice a big difference, not only in the lack of frost buildup on the inside of the freezer (especially in the summer) but you may even see a noted improvement on your electric bill as well!
I hope this helps and let me know if you need any further assistance! :)
Sep 22, 2009 | GE 20.3 cu. ft. / 575 liter Upright...
I HAVE AN UPRIGHT FREEZER THAT IS DEVELOPING FROST ON ALL THE SHELVES, I DEFROSTED IT TODAY AND RIGHT AWAY THE SHELVES DEVELOPED FROST AGAIN. THIS HAS NEVER HAPPENED BEFORE, IT WOULD GET FROST ON THE...
Sounds like an air leak. Check the door gasket. If that is sealing well all the way around, try putting a peice of foil duct tape over the two small vents in the bottom of the door.
Sep 05, 2009 | GE 20.3 cu. ft. / 575 liter Upright...
Freezer runs continually
Hello jyount130960
Welcome
This is a bad thermostat that if not repaired will cause the compressor to burn out prematurely.
You should service it right away!
Thank you,
for using Fix ya.
Please remember to leave a solved rating before you sign out!
Dec 22, 2008 | Freezers
Door gasket for Kenmore upright freezer model 2539239712
Go to sears parts direct website. It's part #3206261 and is in stock, $93.07. Good Luck! countrycurt0
Aug 08, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Up right 14.7 cu GE freezer
HI to clean the drain tube. pull fridge away from the wall .find the drain tube, by the drain tray. push a small plastic hose, up the drain tray. blow in the hose, to clear the debris. thanks the appliance doc.
Jul 28, 2008 | GE 16.7 cu. ft. / 473 liter Upright...
Freezers Logo
27 people viewed this question
Top GE Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Victor Nwachukwu
Victor Nwachukwu
Are you a GE Freezer Expert? Answer questions, earn points and help others
