Question about Cell Phones
My ringtone on my Palm Centro seems to be stuck on one ringtone. Whenever I try to change it, it shows that it has been changed but when I receive a call, the same old ringtone plays! What is the problem?
Calendar on phone is good, calendar on computer is gone I tried hot sync with just the calendar only, but that freezes. what should I do
1.Bought Palm centro with freezing up problem then returned and got another one.
2. Second Palm centro again with freezing up with additional screen flickering problem....buy one problem take another problem....good huh? buy one take one..
3. Third Palm centro after returning the second, now I stil have and inherited the freezing up problem .....you always inherit the freezing up problem even as many times as you changed your PALM CENTRO.
conclusion:
I WILL NEVER BUY PALM CELLPHONE AGAIN.
Jun 15, 2010 | Palm AT&T C/PHONE PALM CENTRO S64801
Palm Centro Freezes on Power Up
try clearing up your web history, sms, or unwanted software....on the browser, click on blazer top left corner, click on history and clear all..tested if it doesnt work back up your phone and perform a master reset
Mar 23, 2010 | Palm Treo 500 Centro
Pal m centro touchscreen disables after receiving
Hello 150pilot,
To manage an active call when the touchscreen is disabled, use the hardware buttons on your Centro (on left side of the Centro).
- OR -
The keyguard feature might be accidentally enabled. To turn off Keyguard, do the following:
• When the screen is off, press the red power button to wake up the screen.
• Press the center (Palm) button to turn off Keyguard.
You can change how quickly Keyguard turns on, or you can disable this feature altogether. To change the Keyguard settings, do the following:
• Press the Home button
• Select System from the category drop-list at the top of the screen
• Select Prefs
• Select Keyguard.
• Select the Auto-Keyguard pick list, and then do one of the following:
-Select how quickly you want Keyguard to turn on: When power is turned off, 5 seconds after power off, or 30 seconds after power off.
-Select Disable to completely disable the Keyguard feature until you turn it on again by pressing Option + Power/End when the screen is on.
4 Select Done.
More information about the keyguard feature canbe found in the Palm Centro User's Guide:
http://www.palm.com/us/support/handbooks/centro/centrosprint_ug.pdf
Have a great day,
martyshaw152
Jan 16, 2010 | Sprint Palm Centro Smartphone
How do i change my ringtone on my Palm Treo Pro Smartphone? I cant seem to change my ringtone at all!
I have synced Gooldle calender withoutlink calender and then ActivSync 'ed to my Palm Pro, the phone calender does transfer the meetings, but all the metings are 1 hr delayed. For instance, a meeting in google / outlook calender at 9am transfers to 10am on Palm - any advise?
Oct 16, 2009 | Palm Treo Pro Smartphone
Hi, my palm centro has no sound. i.e, no speakerphone, no dial tone, no audio on videos but the alarm works that's it.
Hello rossgreni340,
First, make sure the ringer switch is set to 'ON'. It's the little button on top of the Centro. It's turned on when it's pushed to the left. If that doesn't help then check the Sounds settings. The Palm Centro sounds settings can be accessed and changed from the 'System' screen like this:
•Press the 'Home' button on the Centro.
•Tap the 'System' category (top of sscreen).
•Tap 'Sounds' to change the sound settings as you desire.
I hope this helps to resolve the sound problem.
I thank you for giving a rating to this solution if it has been helpful.
Have a great day,
martyshaw152
Jul 29, 2009 | Palm AT&T C/PHONE PALM CENTRO S64801
The phone button on my palm centro is going to the calendar. I tried to change it back to phone in the preferences menu, but it's already on phone, and you cannot change it. Can I correct this problem...
Hello cyssy,
The Palm Centro 'Buttons' settings can be accessed and changed from the 'System' screen like this:
•Tap the 'Prefs' icon
•Tap 'Buttons' to change the Buttons settings as you desire.
Have a great day,
martyshaw152
Jul 17, 2009 | Palm AT&T C/PHONE PALM CENTRO S64801
How can put ringstones on palm centro
Download the free app..."minitones"
Jan 03, 2009 | Palm Treo 500 Centro
I need my ringtones to transfer from my pocket tunes to somewhere
You would need to put Minitones on your device in order for your ringtones to work. It's a program that allows you to place ringtones on your memory card and then load them onto the phone. You can get the program & directions here: http://mytreo.net/downloads/minitones,1053.html
Dec 25, 2008 | Palm Treo 500 Centro
NEED TO CHANGE RINTONE AND HAVE LOST BOOK
not sure if this will work but go into downloaded ring tones pick one see the options and see if it says set as ringtone or message tone it should work also try going into profiles and perzonlize and go to ringing tone and pick downloaded tones hope that helps
Jun 30, 2008 | Palm Treo 500 Centro
Palm treo 500 smartphone
yeah its simple. go to the file and press options. then edit then copy. then go back into the ringtones folder and paste. and then go to profiles and change it across till you find this one. pls leave rating
Apr 16, 2008 | Palm Treo 500 Centro
Cell Phones Logo
46 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
