NEW RIBBON LOADED AND SCREEN DISPLAYS CHECK RIBBON OR BROKEN RIBBON
Please provide the make and model of the printer please.
Thanks.
Posted on Jul 24, 2009
Casio g'zone phone with broken screen main screen.
This is most likely a broken data ribbon. It is a few very thin wires that connects the mother board of the phone to the screen and can easily break with flip phones. It can be replaced and new data ribbon is cheap.
Oct 05, 2013 | Casio G Zone C751 Ravine Verizon Cell...
1901w white screen
tried to check first weather the connectors going to the display panel get loose or flex ribbon get broken. if those are ok, then the problem is the lcd board controller.
Oct 28, 2012 | HP 1901w Monitor
Error message: Ribbon out keeps displaying when there is a fresh roll in the spool, checked everything I could see and find nothing Possible bad sensor?
Check that the metal ribbon blade spindles are in place. these hold the ribbon core in place.Also make sure the ribbon is not loaded over the ribbon reflective plate.( under the head mech where the label guide slot is) Try a manual calibration in the menu.If it asks for a password, its :1234. There could be a slack or broken belt. just fyi: there are (four / 4) belts. The ribbon motors rarely go bad, if all else fails , its probably a ribbon control board.Also check that there is not any junk stuck on the ribbon/ auxiliary roller gear. Sometimes toggle pressure is the culprit.If there is not enough pressure on the head plate, sometimes it will slip.
Jan 21, 2011 | Zebra 110PAX4 Thermal Label Printer Print...
THE SCREEN DISPLAYS CNS ERROR EVERY NOW AND THEN
hi :) maybe the phone ribbon was spoil,just for technician change a new ribbon,pro will solve :)
Jul 06, 2010 | Samsung SGH-D600 Cellular Phone
Hello, We have a printer card Zebra p120i
either your ribbon sensor is not working or somehow you skipped it when you threaded the new ribbon.
Nov 26, 2017 | Zebra P120i Thermal Card Printer
The swivel screen displays an image until it is partially opened.
It is the flexi/ribbon cable that runs from the camera body to the screen that is at fault. It has got broken tracks.
It might work occasionally when the tracks are touching but after a while it will only get worse. A new ribbon cable is needed, which should be a straight forward job for a repair shop or if you can get the cable yourself, an electronics wizz kid !
Jul 26, 2009 | Panasonic Video Cameras
Nokia 7373, Powers up but the LCD displays 2 vertical lines.
Your display circuit is broken, even if the LCD-panel,
seems to be ok the display is damaged.
Your broken display might shortcut your phone,
making it unaccessible with the broken display in place.
This is a very common problem in Nokia phones.
The only way to fix this is to change the display.
You need a T-6 Torx Skrewdriver to do the job.
You can find displays for fair price at :
www.mytrendyphone.com
This is your solution! Please vote!
Jan 19, 2009 | Nokia 7373 Cellular Phone
Broken ribbon message for my zebra card printer
It could mean that the ribbon sensor on the printer is broken. Sounds like you need to send back to zebra for repair. This is free if printer is still under warranty. check out zebra's website for info on how to return printers for service.
Sep 11, 2008 | Zebra Eltron P330i Card Printer
Screen broken
you need a new lcd screen.
Replacing the upper screen is by far the hardest to fix, it requires you to feed the LCD ribbon through a hole ¼” wide, you also need to be able to desolder and resolder the speakers on the new LCD ribbon, then feed the new ribbon back through the hole, it’s not that easy.
Jul 17, 2008 | Nintendo DS Console
W300i phone displays white screen
The flex cable is damaged, it needs to be replaced. It is what connects the motherboard to the lcd screen in your phone. I had to replace one not to long ago and it had the same problem and now it works. Hope this helps. Good Luck!!!!!
Nov 05, 2007 | Sony Ericsson W300 Cellular Phone
27 people viewed this question
jasbo
jasbo
