Question about Garden
Fuel bubble cut on Stihl trimmer. ,how to start
Fuel bubble cut on Stihl trimmer.Any temporary fix?
    President:
  • 1,486 Answers
Yes you can temporary fix with puting some mastic sealer over the bubble and leave for a few hours.
Posted on Jul 24, 2009
My HS 45 seems to drip oil while cutting, I think it is damaging plants. Is it because there is too much oil in the fuel mix?
Fuel mixture for that model is 50 to 1. Stihl also sell their own premixed fuel and oil which is Ethanol free and non aromatic.
I wondered if it has a blade oiler, but it doesn't. I does however have a gearbox with oil in it. I wonder if it is leaking. Do you know where the excess oil is coming from?
You model is listed here and the Manual and details of the fuel are on his page.
STIHL HS 45 HomeScaper Series Hedge Trimmer
Oct 04, 2016 | Stihl Hs45, Hs 45 Hedge Trimmer 450mm 18"...
How to start a Stihyl gas trimmer?
here are the steps to starting most stihl trimmers:
#1 turn the choke on (should be a little black knob or an orange switch on the engine itself)
#2 press the primer bulb 3-4 times (should be a little plastic/rubber bubble again on the engine)
#3 put trimmer on ground or bench (I find ground works best)
#4 pull the pull cord fast and hard away from the engine
#5 once it starts turn the choke back off
Jul 20, 2014 | Stihl Owners Instruction Manual Gas Edger...
Why doesn't the cutting head on Stihl F38 trimmer spin?
Maybe the cutter head has come loose from the shaft. make sure the head is engaged to the drive tube properly
Jul 09, 2014 | Stihl Garden
Why wont the gas go in the bubble of my stihl F5 85 weed wacker un less i block the return fuel line ?
Most likely has a leak in the system, I suggest replacing the bulb as well as the lines, replacements are usually fairly cheep.
May 29, 2014 | Poulan/Weed Eater No. Te475 952711797 17"...
Stihl weed eater
Check the fuel tank vent and primer bubble if it has them. Check they function correctly. Vaccum could be created in the fuel tank while in use, starving the engine of fuel. Use it till it cuts out, then try removing the fuel cap and put it back on and then see if it starts again.
Apr 30, 2013 | Stihl Garden
MY sTIHL hs 81T HEDGE TRIMMER IS DIFFICULT TO START, AND THEN CUTS OUT WHEN THROTTLE IS OPENED AFTER A WHILE
Sounds like a fueling problem, Could either be over fueling or under fueling. Is fuel making it into the cylinder.? Is the plug excessively wet.?
Aug 04, 2012 | Stihl Hs 81 T Hedge Trimmer Cylinder Hs81t
Stihl hs45 hard to start when started won't rev and cut's out
Most likely a fueling issue, Check fuel line for air leaks or it could be a carb problem.
Jul 03, 2012 | Stihl Garden
Stihl saw TS400 will not get fuel through,NON START
how much fuel can be put into a stihl saw ts 400 and how long will the fuel last while in constant use
Mar 24, 2010 | Oregon Scientific Complete Carburetor for...
Cuts out on acceleration
if you have over 200 hours on this FS 80 then you may need a valve adjustment(yes this 2-stroke has valves). if you wanna try to do it yourself it should be set @ 0.1mm @TopDeadCenter. my advice is take it to any stihl dealer and let them do it. its scheduled maintenance
Jun 15, 2009 | Oregon Scientific Complete Carburetor for...
Stihl carb
Try this link. It has the carby settings on page 26 & 27 of the Stihl FS 45 manual.
http://www.mccoyslawn.com/parts-manuals/Stihl/FS45_46_Manual.pdf
Apr 17, 2009 | Worx 12" 4.5 Amp 2 In 1 Grass Trimmer/In...
Garden Logo
290 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
