SOURCE: Touchscreen offset
Here's what you do: Turn off the gps. Then, hold the power button for approximately 30 seconds. The calibration screen will appear. Follow the instructions to re-calibrate the touch screen.
SOURCE: tom tom one xl
Does the battery come off. If so take it off wait a few minute re -install and try again to restart.
SOURCE: screen keeps blinking
Perhaps you are using the Blue plug (VGA) instead of the White one (HDMI)?
Chris
Water Ionizers
SOURCE: Bottom right corner red flashing light error e 74
From the Xbox website sounds like you have a HDD failure / issue.
Try the following steps to resolve the problem:
1.
Turn off your Xbox 360 console.
2.
Removethe Hard Drive. For more information about how to attach or remove theXbox 360 Hard Drive, click the following article number to view thearticle in the Microsoft Knowledge Base:
906204 (http://support.microsoft.com/kb/906204/ ) How to attach or remove your Xbox 360 Hard Drive
3.
Reattach the Hard Drive.
4.
Turn on your Xbox 360 console.Ifyou continue to experience this problem, obtain the latest automaticupdate for your Xbox 360 console. To do this, follow these steps:
1.
2.
Detach the Hard Drive.
3.
Connect the console to the Internet through an Ethernet cable.Notes
Toobtain an automatic update without your Xbox 360 Hard Drive attached,you must have an Xbox 360 Memory Unit or an Xbox 360 that has built-inmemory.
If you cannot connect to Xbox LIVE, running a recent game (2007 or newer) causes an automatic update to be installed.
You can also obtain the latest Xbox 360 system software from the following Xbox Support Web site:
http://www.xbox.com/support/ (http://www.xbox.com/support/) If applying the latest automatic update does not resolve the problem,please contact Xbox Customer Service. If the Customer Service agentcannot help you resolve the issue, you may have to replace the HardDrive. Discuss your replacement options with the agent.
For moreinformation about how to contact Xbox Customer Support, or to submit arepair request, please visit the following Xbox Support Web site: http://www.xbox.com/support/
SOURCE: Screen has black spot in corner that spreads to entire screen
one of the floresant bulbs has fail there is a place in Haverhill Ma called Tops Electronics that can fix you up really quick but you will have to ship it to them they do good work there
their new name is pinnacle solutions group over 30 year serviceing
