Question about Pioneer CDJ-700S Turntable
What does error code E-9101 mean? - Pioneer CDJ-700S Turntable
  • terryjames Jul 25, 2009
    Sorry, there was a picture of my tabletop CD player beside my question, so I thought that would show what I have. I have a Pioneer CDJ-700S tabletop CD player. When I turn it on it is showing Error Code
    E-9101 and will not open.
    Thank you.
  • rossjudd May 11, 2010
    what is the item? Is it a Sony camera? If so: Press Menu / SETUP / Setup 1 / Initialize / OK
    Problem Solver:
  • 6 Answers
According to the 700s/500s service manual:
E-9101 - MECHANICAL TIME OUT - Mechanical operation did not end in allotted time (CLAMP: 4s) - The loading mechanism is defective.
It means that, for some reason, the mechanism that moves the optical assembly couldn't move to the right position in the limit time of 4 seconds. If there's no CD inside, from the tranparent ring probaly you'll see that the sliding door inside the unit has remained improperly closed (the laser pickup couldn't "see" anything).
Unscrew the 4 black screws under your unit, and remove the cover. If the optical unit has remained exposed (probably not), be careful to not touch the lens. On the left part there's a smal motor and gear mechanism. Try to manually rotate the gears, see how the mechanism works (sliding door opens, optical pickup become exposed and goes up) and check if there's any strange behavior (hard to move, strange clicking noises). Also check for excess dirt over moving parts and gears in the whole unit. To clean it, unscrew the 4 black screws that hold all this unit, remove it, clean it with some soft brush and cloth (avoid using air pressure, also avoid breath blowing anything). Replace the grease with some plastic-safe grease and remount everything.
If nothing of this helps, maybe your sliding motor has some problem. In this case, only an repair shop could help.
Best Regards Fernando
Posted on Sep 15, 2009
Can I use a double needle in the euro pro model 9101?
Most all machines will take a double needle
Apr 26, 2015 | Sewing Machines
Can I use a magnetic pin holders by my Euro-pro 9101 sewing machine?
I use a pin holder that has magnets by electronic sewing machine all the time
Sep 20, 2014 | Euro-Pro Sewing Machines
Wwhy 9101 in display? i am brasilian.
hi 9101 is mechanical time out error. When u insert disc to ur CDJ
and that is not able to read disc within the given time then
error 9101 display.
Please try to clean laser and compartment of your CDJ, their may be dirt, dust inside it. I hope this will help.
thx
djajay
May 25, 2010 | Pioneer CDJ-100 Turntable
E-9101 and EJECT
E-9101 error is for Mechanical time out, it means your player can not read the disc within the given time period.
You may have to clean your player, there may be dust, dirt or other particle into insertion slot.
djajay@inbox.com
May 14, 2010 | Pioneer CDJ-800 Turntable
PIONEER CDJ 400 E-9101
E-9101 error is mechanical time out. You need to clean compartment to your player, dirt or dust may be there into insertion compartment to the CDJ
djajay
May 13, 2010 | Pioneer CDJ-700S Turntable
What is Error 9101, on the pioneer MK2 800. and how can it be solve
Error 9101 is a Disk-Read error. More than likely either your traverse assembly, or your loading motor is damaged - or both.
In either case, you'll have to take it to a qualified service center for repair.
- OPTiC
Master Tech
Digital Analog Therapy
Pioneer Repair : Pioneer Parts
Aug 10, 2009 | Pioneer CDJ-800MK2 Turntable
E- brake by-pass code
on the 9101 the enter button is ok make sure you use a real dvd no bootleg
May 30, 2009 | Dual XDVD8170 Car DVD Player
I nees to setup Quintum A800 for termination can anyone help me
Command line for termination A800 (Quantum)
Config unit 1# online 1
Config sys# mindn 10
Config sys# maxdn 20
Config pstntg 1# pass 0
Config pstntg 1# cassig 6
Config pstntg 1# super 3
Config pstntg 1# lamp 1 country code (91)
Config pstntg 1# Answerdel 120
Config pstntg 1# lamp 1 9101 01
Config pstntg 1# dis 1 a (ALL - ports)
Config pstntg 1# ena 1 a (ALL – ports)
Config gkadmin allow 1# ip xxx.xxx.xxx.xxx (GW ip + switch-ip)
Config dsp# voice 81 (for g723) voice 68 for (G729)
Config# submit
Local information
Name of this zone Hello
Country selection Canada
Local country code country code (91)
International prefix country code (91)
Hop-off PBX Numbers
91 public
9101 01 public
This configuration for termenation
Nov 20, 2008 | Quintum Tenor A800 (501-0026-00)
Info
Error 9101 is a read/tray error. More than likely your reader/pick up tray is faulty, and will need to be replaced. For the CDJ700, cost for a new pick up assembly is about $75 - and not an easy fix. Lots of stuff to remove first. Kinda like a car. To get to 1 section, you have to remove 3 others.
Hope this helps.
- TWEAK A/V LAB
Nov 22, 2007 | Pioneer CDJ-700S Turntable
Cdj 700
hi
error E-9101 is notifying that there is dust in the system
get the drives professionally cleaned and reset the units
D
Nov 20, 2007 | Pioneer CDJ-700S Turntable
Pioneer CDJ-700S Turntable Logo
2,821 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
