Question about kawasaki New Genuine Kawasaki Performance Accessories / Ninja ZX14 / Cover, Deluxe
ZX14 was wrecked
Bike was in a wreck was fixed but still has shakes front of bike was fixed.New tire an d rims were pun on bike
  • 724 Answers
Drain the fron end fork and replace it using a recommended approch. Even levels and not air bound or a suchion bound may cause a stiff fromt end and not flexible enough that can not be noticed standing still and pushing down on the front end, This can cause a wobble that is like a loose wheel
Posted on Jul 24, 2009
How to Replace a Blown Bike Tire Inner Tube?
unbolt wheel and using tire spoons or the handle of flat ware [as long as its strong enough to not bend ]place inbetween the tire bead and rim and pry up and over rim now either use another to pry again next to spoon or slide spoon under and slide around rim removing tire reach in and remove tube check inner tire for debris fix or replace tube install
How to change and fix flat bike tire Trek Bicycle How to Fix Flat Bike Tire
Oct 20, 2016 | Cycling
Front end shakes
I have a 98 heritage springer. Took it to the dealer and said the front end shakes. Without looking at it, the shop manager asked how many miles I had. Just under 10k was the answer. He said "neck bearings, it's a known issue with springer front ends that the neck bearings go after 10k miles." Taking his word for it, I agreed to have the work done. Got the bike back, no change. He said, well it needs a new front tire then. Changed the tire, again, no change. Took it to another dealer. Explained my tale of woe and the manager actually got on it and rode it. Agreeing there was something wrong, they took it in, jacked it up and actually looked at it. Turned out the rim was bent. So after all the BS at the first shop, it turns out they replaced the neck bearings and installed a new front tire on A BENT RIM! Start with the simple stuff first. Check the front wheel balance and rim straightness before diving into bearings.
Jul 16, 2010 | 2004 Harley Davidson FLSTC - FLSTCI...
Denali GMC 700C Women's road bike wrong tires!!!
Can you explain why you think the tires are too big? Do they NOT fit the rims? What condition was this bike in when you bought it? If the brake pads line up with the rims then the wheels are correctly sized for the frame.
May 06, 2010 | GMC Denali 700cc Women's Road Bicycle
99 hayabusa 360 tire goes flat every thee days need to change front counter and rear sproket also i need afull rear brake system there isnt one on it
It looks like Babbitts has all the individual parts needed for your bike. Check out the cost of the new parts there then Google motorcycle salvage suzuki and see what you can find off a wrecked bike. The salvage yard will normally send you the entire wheel assembly, rim, tire, brake disc, sprocket (and even the fittings if you ask and if they still have them). The cost will be a lot less than new but then again "new" is often better. Go to www.babbittssports.com/parts/partsbybrand/parts.aspx Please take a moment to rate my answer. Thanks
Jan 11, 2010 | Suzuki GSX 1300 R Hayabusa Motorcycles
Steering wheel shakes on highway and the front end
Has it been wrecked. If not could be the tires or could be that you have lost a weight on the rims. Have tire balanced or replace it the tires are bad or the alignment is out. Most of the times its the tires or weights have fell off the rim.
Dec 03, 2009 | 2007 Jeep Wrangler Unlimited Rubicon 2...
How do you change a innertube on a back wheel of a mountain bike
You have to remove the entire wheel from the bike. Then change it just like you'd change a front tire... remove oneside of the tire from the rim, pull out bad tube, clean rim, put in new tube, put tire back on rim, inflat tube... good to go. There are 1,000,000 videos on YouTube to show you this process.
Nov 08, 2009 | Bike Extreme Lite Youth Shoulder Pad
My neighbor rides a VTX1300C and is having a
motorcycle tires are made of softer compounds than car tires,to increase traction & better handling.replacement at 10K mi. is not unusual.slightly more wear on the left can result from the 'crown' or slant of most roads.if it tracks straight [hands off?] and doesn't vibrate,it's time to RE-TIRE!
Oct 13, 2009 | Honda VTX 1300 C Motorcycles
93 FXR Rear tire rubs belt guard w/axle centered.
Try just bending the belt guard or removing it and fileing some material off the guard so it does not rub. You may also be able to remedy this by adding washers to the belt guard attach points.
May 30, 2009 | 1993 Harley Davidson FXR Super Glide
My bike got a wobbly tire basically right when i bought it
The cheapest way is to buy a new tube to see if that was the problem. Sometimes tubes can inflate bigger at one area than others. If not check to see if the rim is true, meaning that it is not bent, if so replace. It could also be the tire.
Feb 21, 2009 | Mongoose Exile 26 Men's Full-Suspension...
kawasaki New Genuine Kawasaki Performance Accessories / Ninja ZX14 / Cover, Deluxe Logo
118 people viewed this question
Top kawasaki Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a kawasaki Cycling Expert? Answer questions, earn points and help others
