Question about Nokia 5610 Blue Quadband 3.15MP A2DP + Gift + WTY Cellular Phone
Connection problem with nokia 5610 unrecognized USB device
Whenever i connect my nokia 5610 it says "USB device not recognized blah blah blah" and displays it as a "unknown device",... i have already installed the nokia pc suite and it just cant finish the get connected wizard before my system "terminates" the connection ,..im not sure this is a phone problem but anyway pls help
My computer is not recognizing my mobile phone
Hi
Don't connect the phone before this procedure:
First,you need to download the LG Mobile support tool on your PC.
Install the 'USB driver' and select the models update.
Use the USB cable to connect your phone to the PC now.
Click on start updating.
Mar 06, 2012 | Cell Phones
Why my pc shows your device is unrecognized when i connect my pendrive to pc
it may be due to malfunctioning of your USB port, just try to plug out and then plug it into another Port
Nov 22, 2011 | Electronics - Others
Windows 7 does not recognize my camcorder when plugged in via usb Unidentified Device - no driver found
it recognize it as a storage device. when its plugged in if it shows an external device or unrecognized device found you have to download the software to connect it . try to download it via www.piratesbay.com as there are more software's . make sure you type your model no when searching to download
May 13, 2011 | Cameras
Whenever I connect my Nokia phone with my PC through USB cable, it says that one of the devices connected to the computer are malfunctioning and the device cannot be recognized also that the drivers for...
Check with your phone's manufacturer for updated drivers for the device. For the USB drivers check with your computer's manufacturer or motherboard manufacturer for drivers.
Mar 06, 2011 | Computers & Internet
Canon Rebel XTi not recognized when plugged into usb
Vista is your problem. Solution...buy an inexpensive card reader to download your pics to a folder you create on your desktop. From there, you can send the pics to your photo editing software.
Oct 23, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
My bose stereo speakers are having a problem getting recognized....It didn't have any such problem before and then after I started using usb hub, my computer popped some error message "One of your hard...
The problem is the USB hub, this often leads to a proper signal routing, as it splits the signals to smaller data packets. Remove the hub and all other USB ports. Let then newly recognize the PC your USB connection (not via Hub!).
Oct 11, 2009 | Bose Office Equipment & Supplies
Nokia 3110 classic usb device malfunctioned
Please try connecting your phone to a different USB port other than the one which you use normally.
If the issue is the same then try connecting it to another PC if you still face the problem then it is a hardware issue.Either your phone or the USB cable is gone bad.So replace the USB cable first with a new one and then try connecting.If the issue is till the same then it is your phone and you will have to get it repaired or get it replaced if it is under warranty.
Feb 10, 2009 | Nokia 3230
Canon EOS Digital Rebel XT will not connect to computer.
Please discard that the USB port or the USB cable are defective. You can do it if you try to hook your camera in other personal computer using the same USB cable. If it works, then follow the next instructions.
Connect your camera to the PC thru the USB cable and turn it on.
If you are using Windows, go to the Control panel - System - Hardware - Devices - and check if there is any device that was not recognized by Windows. Such devices are marked with a yellow question mark.
If so, get into the device item and with right mouse click, select to update the device driver.
If there was not unrecognized device, then you can unistall your USB port driver and then run a change hardware status to recognize the USB port again, then run the update driver routine.
Regards,
Feb 07, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Nokia 5610 Blue Quadband 3.15MP A2DP + Gift + WTY Cellular Phone Logo
127 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
