Question about Tomtom One XL GPS Receiver
TomTom shuts down enroute
My TomTom will suddenly, without warning shut itself off during a trip. If I press the on-button it will not turn back on. I have to leave it for 15 to 20 minutes before I can get it to start back up. Sometimes when it does this, I have a gray screen with black vertical lines (i.e. not completely turned off). It starting doing this about 2 months ago, intermittently, now it seems to do it every two hours during a long car trip. It's been a real problem since long car trips are usually in places that we aren't familiar with (i.e. don't know where we are). I have resorted to printing off Mapquest directions again, just in case we get stuck in the middle of nowhere. . .
    Brigadier General:
  • 4,090 Answers
It sounds like a low battery, if you have an AC charger for this unit use it before starting out DC does not charge sufficiently to maintain long term use. It is more of a maintenance trickle charge.
Other than that get a new battery fitted and dont start the engine with the gps plugged in to power unitil enine is going this way your battery will last longer and not spike the mother board. What you never heard of this? it is such a common happening and TOMTOM love selling new boards that;s why they dont tell you this piece of information.
But seriously the replacement battery should solve your problem
Posted on Jul 26, 2009
Headlights shut down on 1995 dodge ram
There should probably be a relay for them too.
May 09, 2017 | 1995 Dodge Ram 2500
It keeps shutting itself off ?
When does it shut itself off? Is this happening time you press the power button and during the boot cycle it shuts off without completing the boot to windows? If it shuts down after you've worked on it for a while it could be that it is running hot. If you let it sit a while to cool off then press the power button, if it completes the boot cycle and allows you to work it is definitely running hot. Normally when they run hot if you immediately try to reboot, it will fail. If you let it cool off it will boot successfully. Computers run hot because of a fan not working, dust clogging the fan vents or the Thermal Paste around the CPU and Heat Sink has become hard or too thin to keep the unit cool. If it's not running hot you might have a power supply or motherboard issue. Try removing the power cord and press and hold the Power Button for 30 seconds to release any Static Buildup. Then plug the power cord back in and try to reboot.
Mar 18, 2012 | Dell OptiPlex GX280 PC Desktop
Ps 3 stops suddenly, shuts down without warning
If the system turns itself off,then you have over heated the system.
BETTER U DOWNLOAD REPAIR GUIDE
Click here to download repair guide
Dec 24, 2010 | Sony Playstation 3 (PS3) Console
Suddenly turned off without warning Sony KDS-50A2000
All you need is to open the back cover of the television and check on for dry soldering at the power stage of the printed circuit board, also check for bulged capacitors, if found replace with same rating of voltages , but if otherwise Ur power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get ur tv power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this helout, Good luck....
Jul 11, 2010 | Sony KDS-50A2000 50" HDTV
HL-1250 shuts down by itself
Sounds as if this is an overheat or a short circuit. you may require a new laser engine or power supply. Disconnect the laser motor from the power supply and them turn it on. If your led's stay on, it's the laser engine. If not, it's the power supply.
Apr 09, 2009 | Brother HL 1250 Laser Printer
Mac Mini G4 turns itself ON
Have you looked into System Preferences>energy saver>schedule? Maybe it's set up to start itself. I have my mother's mac set to start up and shut down automatically. Just a thought.
Jan 09, 2009 | Apple Mac mini G4 Desktop
Projector suddenly shut down
you need to reset the lamp timer. turn it on, and press and hold the left arrow, right arrow, and power button until it resets.
Dec 17, 2008 | Mitsubishi ES100U Multimedia Projector
My Philips Freevents sometimes wont turn on and when it does it shuts down without me shutting it down
If the computer shuts down with no warning then it could be your power supply is faulty, which explains it not turning on sometimes. Just check the back of the PC to make sure it is plugged in properly (TURN OFF ALL POWER TO THE PC BEFORE CHECKING). if this does not help, get it looked at by your local qualified computer technician if you don't know how to replace a power supply. Also, a connection to the motherboard to the Power button may have a fault somewhere, which also means take it in for a look if you don't know what to do. If it does give you warning with 'Windows is shutting down' it can be the following things.
1- Your power button on the PC is sticky and movement causes the computer to think you have pressed it and so it shuts down, which can also explain why it wont turn on all the time. Just use some household grease cutter and spray it on the outside of the button, turn off the power supply to th computer and press it in and out a few times to get it back to working order
2- A Virus is shutting your computer down on you, but this does not fully explain why it won't turn on but this could be an effect of the virus so use a virus checker to see if this is the case
3- Your computer system is getting too hot and usually a computer has setting which shuts it down before permanent damage happens. Check your PC fans to make sure they are running and feel around where your computer sits to see if its warm or hot and replace the fans or put your PC in a cooler environment
Hope This helps
Nov 18, 2008 | Computers & Internet
Tomtom One XL GPS Receiver Logo
290 people viewed this question
Top Tomtom GPS Experts
k24674
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
