Question about Metrologic Instruments 9520 Voyager
Metrologic MS9520 Hi I m Andreas and I am using Metrologic MS9520 serial barcode scanner. I am getting a "beep" when I try to read a barcode; and doesnt show the number to screen. How can I fix this problem?I forgive to told you that this scanner is 6 months used. Thanks a lot.
  • andreascyp Nov 21, 2007
    This scanner was using via cash register and now my customer bought a POS (point of sale) he want use this scanner
    I want any driver? which settings i have to reset or enable?
  • remoo201 Sep 01, 2008
    my metrologic ms9520 barcode doesnot read 6*24 pages
    [please send me about how to solve this problem]
  • 244 Answers
You can reset back to original setting using your manual. If you are using cash register you need to look for the right settings in order the scanner will working.
Rate me SOLVED
Posted on Nov 21, 2007
  • Cheater Cheater Nov 21, 2007
    That scanner are no need of driver it is being manipulated by the POS. Ask them if the POS they bought is supported with com port. I can offer you the best reasonable price of POS if you are interested which possible to solve your problem. Please try to check this From what country you are currently doing business. I am based in the Philippines.
We are using a Metrologic MS9520 (keyboard wedge) with QuickBooks. It won't scan barcodes provided by Quickbooks, even though it's supposed to be compatible. We've downloaded about every driver, config,...
What I would first is to bring the barcode scanner back to factory defaults. To do this you will need the manual that came with the scanner, on the first page is a bar code that say "enter/exit configuration mode" scan that first and you will hear three beeps, then scan the bar code for "recall defaults" and rescan the bar code to "enter/exit configuration mode" then retry using your scanner, if this does not work bring up "notepad" on your computer and try to scan any bar code form any retail item. This should scan, if it does net then it could be a defective scanner. See page 2 on the manual link
Nov 11, 2010 | Microsoft Metrologic MS9520 Voyager...
Microsoft Metrologic MS9520 Voyager Barcode Scanner problem
If it is using the MX009 USB Cable it wont scan with the standard configuration. You will need extra configs such as enable Rs-232 Mode, Enable Xon/Xoff handshaking etc..
These can be found on the website which will divert you to Honeywell website
May 25, 2010 | Microsoft Metrologic MS9520 Voyager...
Problem with metrologic voyager on xp,
If your voyager has the new interface then you can, by reading a barcode, change the type of connection. You must also change the cable
Sep 04, 2009 | Microsoft Metrologic MS9520 Voyager...
Trying to use Casio PCR-T2100 cash register & Metrologic scanner.
for the scanner, u need to program it to suit Casio Cash Register, eg: baud rate, parity , data bit & so on...other wise, the Cash Register cannot receive the signal from the scanner.
After program the scanner , please perform "flag clear" to the cash register.
Mar 27, 2009 | Metrologic Instruments MS9540 Voyager...
Metrologic barcode scanner - laser is a dot not a line
This would be a fault with the scan engine. The dot is created when the mirror inside of the scan engine is not oscillating. The best solution is to have the device repaired, hopefully your scanner is still under warranty, or to purchase a replacement. /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0cm; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:612.0pt 792.0pt; margin:72.0pt 90.0pt 72.0pt 90.0pt; mso-header-margin:35.4pt; mso-footer-margin:35.4pt; mso-paper-source:0;} div.Section1 {page:Section1;} --> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Mar 09, 2009 | Microsoft Metrologic MS9520 Voyager...
Incorrect Reading
Try experimenting with the different inter-scan code delays. You can find the programming barcodes in your manual.
Aug 20, 2008 | Metrologic Instruments Voyager MS9520...
Voyager scans into hyer terminal but not Notepad
Did you read the installation and configuration manuals? I download them from this website:
Your scanner might note be configured correctly.
here are the guides I downloaded:
And the MFG website where you can download the material:
The scanner and host system must use the same communication protocol. I have a feeling the scanner is not configured correctly. The USB and serial connectors are 2 different types of configuration, but there are more.
You can also download the drivers and POS software from there website.
Feb 14, 2008 | Metrologic Instruments 9520 Voyager
Locked Metrologic MS9520-37 (keyboard wedge) after unintentional programming
You programmed it for usb interface, but the scanner is keyboard wedge. Try pointing the scanner at the "recall defaults" barcode in the manual as you plug the scanner back in.
Feb 12, 2008 | Metrologic Instruments Voyager MS9520...
try to reset a bar code ,from the manual
Jan 24, 2008 | Metrologic Instruments METROLOGIC VOYAGER...
My RS-232 scanner beeps at the bar code but nothing appears on-screen.
The "Beep" just means that the scanner has been presented with a valid barcode. (nothing more) The scanner has probably not been set up correctly as this is a common issue. the settings need to be set correctly for your environment. you should have a code book with some bar codes in (part of the manual) which can set all the options within the scanner, There is an option to recall defaults here is the electronic manual
Oct 03, 2007 | Metrologic Instruments 9520 Voyager
Metrologic Instruments 9520 Voyager Logo
7,988 people viewed this question
Top Metrologic Instruments Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Level 1 Expert
Daniel Dollive
Daniel Dollive
Are you a Metrologic Instruments Computer and Internet Expert? Answer questions, earn points and help others
