Question about Car Audio & Video
What Kind Of Car Amplifier Do I Need?
I bought a speaker box for my car that has 2 subwoofers and 2 tweeters built into the box. What kind or what channel amplifier do I need to make this speaker box work? I need an amplifier that will make the tweeters work as well as the subwoofers. The speaker box says it is 800 watts. It is 400 watts RMS. Any help would be greatly appeciated. Thankyou very much.
    Sergeant:
    Champion:
  • 253 Answers
A kicker amp with full range out put that has a switch for the range you most like. do not go over 400 watts rms or the tweeters will blow.
Posted on Jul 24, 2009
2011 holden cruze radio wiring diagram
2011 Chevrolet Cruze Car Radio Wiring Guide
Car Radio Battery Constant 12V+ Wire: Red/Dark Green
Car Radio Accessory Switched 12V+ Wire: N/A
Car Radio Ground Wire: Black
Car Radio Illumination Wire: N/A
Car Radio Dimmer Wire: N/A
Car Radio Antenna Trigger Wire: Dark Blue
Car Radio Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Tweeter Size: 1? Tweeters
Car Audio Front Tweeter Depth: 1?
Car Audio Front Tweeter Location: 1?
Left Front Speaker Positive Wire (+): Dark Blue
Left Front Speaker Negative Wire (-): Brown/Dark Blue
Right Front Speaker Positive Wire (+): Yellow
Right Front Speaker Negative Wire (-): Yellow/Black
Car Audio Front Speakers Size: 6 1/2? Speakers
Car Audio Front Speakers Depth: 3 1/4?
Car Audio Front Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Dark Green
Left Rear Speaker Negative Wire (-): Dark Green/Black
Right Rear Speaker Positive Wire (+): White
Right Rear Speaker Negative Wire (-): Dark Blue/Black
Car Audio Rear Speakers Size: 6 1/2? Speakers
Car Audio Rear Speakers Depth: 3?
Car Audio Rear Speakers Location: N/A
Car Subwoofer Speaker Positive Wire (+): N/A
Car Subwoofer Speaker Negative Wire (-): N/A
Car Subwoofer Speaker Size: N/A
Car Subwoofer Speaker Depth: N/A
Car Subwoofer Speaker Location: N/A
Jan 02, 2016 | Holden Cars & Trucks
How to install spr-17s
The six 1/2 speakers are your woofers,connect the positive and negative wires from the speaker to the 2 connections labeled on the crossover as W(woofer)+ pos and W(woofer) -- neg,hook the tweeters to the crossover connections labeled T(tweeter)+ pos and T(tweeter) -- neg,then hookup the 2 remaining connections labeled Amp to your amplifier,amp must be 2 or 4 channel stereo capable and give out enough power to properly drive the speakers so they achieve optimal performance.
Mar 05, 2011 | Alpine SPR-17S Car Speaker
Hello, my problem is when I insert a CD(mp3), the Subwoofer gets disabled and only the speakers works. However, when I use only radio, the woofer works fine, it's only when I play CDs. My receiver is new...
it sounds like you are using the blue wire (antenna remote turn on) instead of the blue/white (amplifier remote turn on) wire to turn your amplifier on.
Jan 17, 2011 | Kenwood KDC-MP335 CD Player
I have the stereo except for speakers sony SA-H7900. what to do
hi ,
as far as i understood you, you need speakers for the stereo mhc-h7900? so the originals are the sa-h7900, active (built in mono amplifier) and they have electrostatic tweeter plus some special kind of bass-control system called i not remember now. in this case maybe impossible to find some, but you can connect any kind of "active" speakers, even a crappy active 2+1 subwoofersystem would do it to get a sound out of it.
Jan 01, 2011 | Audio Players & Recorders
What is the impedance and do they need a capactor on or is crossover built in?
Product MPN MPN RTC 19 Key Features Car Speaker Type dtrquestion.gif Component Car Speaker Function dtrquestion.gif Tweeter Size 1" Nominal Power Handling dtrquestion.gif 70 Watt RMS Technical Features Peak Power Handling 130 Watt Frequency Response 2500 Hz - 32 kHz Sensitivity 87 dB Impedance 4 ohm (Dual Coil)
please be advised you need the crossover that came with it, or you will need an active crossover dedicated to an amplifier to run these.
Aug 14, 2010 | MB Quart RTC 19 Car Tweeter
2003 Cadillac DTS w/Bose, has rear sub & adding Pyle dual 10 sub
two channel will do with the same power power rating of your speakers ex. your speaker is 500 watts per piece so you need to buy a 500 watts per channel amplifier
May 16, 2010 | Pyle PLHB10 Car Subwoofer
How do you install dome tweeters?
tweeters get installed almost like any other speaker. you pick a mounting spot, then mount them, or cut the hole for recessed tweeters, etc. run the wire to the closest speaker wire from your stereo, and just splice it in. you will however need some kind of crossover to prevent the low frequencies from being played through the tweeters. if you buy new tweets, they usually come with their own crossover, or there are a few different styles you can get.there are the passive crossovers, the ones that look like small boxes. there are also the inline filters. these are the ones that you splice into the positive speaker wire to filter out the low frequencies. and some aftermarket stereos come with some kind of filter or equalizer built in, depending on your model. what I would do is buy one of the inline filters for each tweeter. theyre inexpensive, and easy to install, and they work great. so basically, just mount the tweeter, run its wires to an existing speaker wire and splice it in, and install an inline filter on the positive wire for the tweeter. oh, one last thing. if your interior speakers are powered by an amplifier and not by the stereo, then just run the tweeter wire to the speaker outputs on the back of the stereo. too much power will definitely destroy any tweeter. good luck!
Sep 08, 2009 | Car Audio & Video
Sub box
are you gong to use this in your house or car?? any type of enclosed box air tight.. will do if your useing it in your house a box you can face the cone faceing down would be good with a port in the front about 3in would be good. be sure to purchase a cover for the speaker you dont want the cone smashed .you dont want any air leaks .. you can go to any car stero shop and have a box built.if you have good wood working skills build it your self 1/2 in partical board works ..you can also get the port tube at like a raido shack.and speaker port for conections weather it be rca or speaker wire type
do not nail your box wood glue is best
Jan 29, 2008 | Cerwin Vega 154 Car Subwoofer
Im not sure how to hook these speakers up
answer depends on what kind of Ohm Load your amplifier is capable of as a lowest allowed setting. ie if you have a 1400W at 4 Ohm amplifier, the connection would need to be different than a 1400W at 2 ohm amplifier. also, on the speaker what is the rated ohm load per coil since it's a quad coil speaker (should say somewhere on it's box, or in it's manual. I'd assume 4 ohm per coil) we'll do that math after you get those figures in to me.
Aug 16, 2007 | MA Audio MA 1200XL Car Subwoofer
Car Audio & Video Logo
311 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
