Question about Atari Desperados 2: Cooper's Revenge for Windows
Upon startup of game get this error message- "unable to initialize video mode: could not set screen mode."
    Problem Solver:
  • 19 Answers
Try download n install latest driver..
Here is something you can try for now:
Many games provide an option to be started in "window"-mode instead of fullscreen.
Open a terminal, cd to the directory where the game is installed and start it from there, but append "--help" behind the command name (or "-h" if that didn't work)! Keep an eye open for an option that looks as if it starts the game in window-mode.
Posted on Jul 24, 2009
This messsage pops up when i try to start up desperados 2 copers revenge
error unable to initialize video mode: videoconfig structure did not contain valid m_hdc and m_hglrc members.
what do i need to do in this situation???
Posted on Jul 21, 2010
Video mode can not be initialized
aw this problem ik it well there are a few tangs you can do 1 try reinstalling your graphics driver or at least make sure its the latest version
but other then that i will need more info like the game the graphics card you have and such like 32 or 64 bit are you running linux or windows or mac
Oct 28, 2015 | Viva Media Helldorado
HPL1506 The input signal from pc display foe few seconds and goes off error recommended setting - 1024 x 768 - 60Hz
It can be that your PC video resolution is set higher than 1024 x 768 @60Hz for the monitor to display correctly.
Spec: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00485268&lang=en&cc=us&taskId=101&prodSeriesId=1130384&prodTypeId=382087
Try this per HP:
HP Business Monitors - What Do I Need to Do When the Message Sync out of Range Displays on the Monitor? ISSUE: What do I need to do when the message Sync out of Range displays on the monitor? When the video card signal exceeds the frequency allowed for the monitor, the following error message may occur: Sync out of Range SOLUTION: To avoid the message, lower the resolution or vertical frequency of the video card. Reboot the system and use the VGA mode to force the video card driver to lower its resolution. Follow these steps.
  1. Shut down and restart the system. For consumer systems such as HP Pavilion desktop PCs, push the Power button once. For commercial systems such as HP business desktop PCs, hold down the Power button for five seconds.
  2. Immediately after seeing the HP/Compaq logo screen, press F8 at system startup to initiate the bootup menu.
  3. Scroll down to highlight Enable VGA Mode , and press ENTER .
  4. After Microsoft Windows completes its bootup process, access the Display Properties and select a desired resolution, which is compatible to the connected monitor.
May 20, 2010 | HP L1506 15" LCD Monitor
I get a blue screen error message ''c000021a unknown hard error'' after running CHKDSK as a result of receiving an initial blue screen error message ''The Type of file system is NTFS. The volume is...
Hi, Boot into Safe Mode by pressing F8 at bootup and choose
'Safe mode with command prompt'
At the command prompt type
C:\Windows\system32\restore\rstrui.exe
Hopefully System Restore will open so choose a Restore Point a few days ago.
Please rate my response!! Thanks, SF
Jan 28, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
On startup, before menu screen, ps3 freezes
Do you recieve an error message on screen when that happens? Turn your system to standby mode (red light on the console) and press and hold the power button until you hear 2 beeps then let go. This will reset the system to factory defaults. If that does not work call Sony customer support.
Jul 29, 2009 | Sony Playstation 3 (PS3) Console
Will not display output from Computer
Probably the video resolution or the monitor Refresh Rate (eg: 50/60/75 Hertz) is set too high in the operating system, which over-drives the monitor electronics and it is unable to display anything.
If you restart the computer manually (hold in the power button for 5 seconds, the computer will shut off, turn it back on again) you will see the normal BIOS and Windows startup display on the monitor, but then as Windows completes it's startup it returns to the error message you see.
To fix this, restart the computer manually and start the computer in Safe Mode. To do this press F8 just before the computer starts to load Windows, and choose Safe Mode. Once in Safe Mode, you should see the monitor working correctly.
Now restart the computer in Normal Mode and everything should be fine.
Dec 23, 2008 | Westinghouse LCM-19v1 Monitor
Getting out of the initial set up
First try to Boot to Last Known Good Configuration.. do this by pressing F8 upon bootup...look at the prompt screen for the option mentioned OR
Attempt to boot up in Safe Mode....
Do This by pressing F8 Upon bootup, it will take you to a black Safe Mode Options screen... once there choose the first option.. boot into Safe Mode Only.. If you are able to boot into windows that way,, you can then check for problems... Like checking the device manager for errors, Check the Status of your hard drive.. etc.
Jun 04, 2008 | Dell Latitude C400 Notebook
Unable to play the PC game Crysis
AlanChong20, update you're video casr software. The radeon 9200 last update is listed at this link.
http://ati.amd.com/support/drivers/xp/radeon-prer300-xp.html
The date for the upgrade is Nov. 15, 2006 No more driver update are being made.
If you're game still gives you the same error try lowering the game graphics detail settings. If set to high, bring them down to medium. It very possible you're card does not have enough memory to play the game. The 9200 is a older card. It may be time to upgrade.
Mike
Apr 13, 2008 | Computers & Internet
Input not supported
You may have a video resolution selected on your computer that the screen doesn't support.
The reason you see the the initial startup message is because that is loaded from the bios, prior to the settings for the graphic card output being loaded.
Try booting the computer in safe mode and adjusting the display resolution.
Dec 29, 2007 | Acer AL1916W 19" LCD Monitor
Atari Desperados 2: Cooper's Revenge for Windows Logo
2,511 people viewed this question
Top Atari Video Game Consoles & Games Experts
Reggie brown
MegaByteMe
MegaByteMe
James Wishart
Are you an Atari Video Game Console and Game Expert? Answer questions, earn points and help others
